Wire Question
I am using an LM34 temp sensor in conjunction with my BS2SX to take
some temp readings. The problem is that what I am measuring is 6-8
feet away from the stamp, and when I use wires in between the LM34
and the stamp, every so often I get a reading that is way off. But
when the LM34 is in the breadboard it works fine. I am using solid
22 guage wire, should I be using something else?
the stamp end (0 volts for the stamp supply) and the screen left
disconnected at the sensor end.
Chris
Sent: Monday, September 24, 2001 11:38 AM
Subject: [noparse][[/noparse]basicstamps] Wire Question
Depending on the cable capacitance, the LM34 output can go into wild
oscillations that show up as bad readings. If you have a 'scope you
can see the instability. The LM34 data sheet proposes a couple of
fixes. The easiest is to put a 3kohm resistor in series with the
output of the sensor, maybe also ~0.1uf across the cable. The
shielding Chris suggested is also a good idea if there is noise
pickup, however, the shielding can aggravate the oscillation problem,
so you will still probably need the resistor.
-- regards,
Tracy Allen
mailto:tracy@e...
http://www.emesystems.com
or solid wire?
take
6-8
LM34
But
solid
wild
problem,
> -- regards,
> Tracy Allen
> mailto:tracy@e...
>or solid wire?
>take
>6-8
No big difference electrically. Whatever you need for mechanical
considerations. Twisting the wires together (~3 turns per inch)
helps with cancelling magnetic fields. Shielding helps reject
capacitively coupled noise from electric fields. Worst from the
noise standpoint is two independent wires dangling in midair!
However, by bringing the wires close together, twisting and shielding
them, you are increasing their mutual capacitance, which leads to the
oscillation problem in the LM34 output. That then calls for the
resistor between the sensor output and the cable.
-- Tracy
