adding ram
Hello,
I've seen many options for adding EEPROM memory to a stamp, but I'm
wondering if extra RAM can be added to a stamp? I've got an application
where I need to generate a long list of numbers, and then transmit them to a
motor controller every few seconds in a loop, and I'm afraid that EEPROM
might get worn out quicly or that it might not be fast enough.
Stewart
Stewart
There is a RAM pack available on Solutions Cubed's site, the 'RAM Pack B'
that may be what your looking for it's at
http://www.solutions-cubed.com/rampack_main.htm Hope this helps, at least a
little ;-)
Chris Shuster
http://www.cpuman.f2s.com/
Sent: Monday, September 24, 2001 1:20 AM
Subject: [noparse][[/noparse]basicstamps] adding ram
> Hello,
a
> Thanks,
> Stewart
http://www-us7.semiconductors.philips.com/pip/PCF8570T/F5
I like the i2c interphase requiring fewer stamp pins, but the memory size
isn't as large. Do you know if i2c is faster than 9600 baud serial? I
think I may re-think my application and how it works so I don't need the
extra memory after all, but thanks for the link.
stewart
Date: Monday, September 24, 2001 04:08:00 AM
Subject: Re: [noparse][[/noparse]basicstamps] adding ram
Stewart,
little ;-)
Chris Shuster
> Hello,
a
> Thanks,
> Stewart
>stewart
Hi Stuart,
On the Stamp, the comparison of speed between 9600 baud vs I2C has to
start with the question of whether you are using a BS2P or one of the
earlier Stamps. The BS2P has built-in I2C, while the implementation
of I2C on the earlier chips requires a lot of bit-banging, and is
therefore very slow. On the BS2P, one I2C instruction will be roughly
comparable to one RS232 instruction.
The Atmel dataflash chips also have RAM buffers of 264 to 528 bytes,
accessible via SPI interface (which is present on the earlier stamps
as well as on the BS2P).
http://www.atmel.com/atmel/products/prod9.htm
http://www.emesystems.com/BS2flash.htm
-- regards,
Tracy Allen
mailto:tracy@e...
have used this 512k x 8 chip successfully in the past
http://www.jameco.com/cgi-bin/ncommerce3/ExecMacro/Jameco/searchResult.d2w/r
eport?sort=&search=157358
Jay
> Hello,
a
>http://www.jameco.com/cgi->bin/ncommerce3/ExecMacro/Jameco/searchResult.d2w
/r
I forgot to mention that you load and retrieve all 8 bits at a time.
Moreover, this approach can be used for random access of all 512k bytes.
The biggest disadvantage is that takes lots of Stamp I/O pins.
Twelve pins for serial access through a 4040 counter chip, probably 29 pins
for random access. More if you want more ram.
Jay
