washing machine — Parallax Forums
washing machine
edited 2001-09-28 00:35 in General Discussion
Please help,
I have a speed queen washing machine that died. The
machine is computer controlled and the processor
intermittently locks up and the replacement board is
$262.00!!! So what does a stamp programmer do? Build a
new controller and program it with a stamp, and that's
exactly what I did. However, I don't understand
something about the operation of the motor. In one
direction(ccw) the motor causes agitation to happen
and the pump to recirculate water, in the other
direction(cw) the drum spins and the pump drains the
tank out. The problem is that I can't get the pump to
drain without causing the tank to spin. When the
machine is loaded with cloths, you should be able to
drain off the water before spinning the load. The
motor is controlled by two relays,(I am using the
original high level driver board) one supplies the
main winding and the other is a double pole double
throw type that causes the motor direction to change.
It may be that these relays need to be energized in a
certain sequence or delay time. If anyone has any info
about the motor or machine operation I would greatly
appreciate it.
Scott
__________________________________________________
Do You Yahoo!?
Get email alerts & NEW webcam video instant messaging with Yahoo! Messenger.
http://im.yahoo.com
    edited 2001-09-23 04:14
    From what little I have watched a washing machine in action, it seems
    that the spin and drain go together. The centrifugal action forces the
    water out of the clothes. Would love to see your code when done. This
    sounds like a real neat application for a stamp.
    Leroy HAll
    Scott Sutton wrote:
    > Please help,
    > appreciate it.
    > Scott
    > Do You Yahoo!?
    http://im.yahoo.com
    edited 2001-09-23 07:06
    I was thinking on most washing machines there was a wig-wag solenoid that
    shifted the transmission from agitate to pump. On the Sears washers the look
    like two solenoid coils next to each other on one assembly.
    > appreciate it.
    edited 2001-09-23 10:40
    Subject: Re: [noparse][[/noparse]basicstamps] washing machine
    Yes, and this is an application that our wives will appreciate !
    (finally...) :-)
    I don't know if I'm the only one in this situation, but my wife always say
    that I'm 'playing' when I work on my central heating control project...
    Phil.
    edited 2001-09-23 18:15
    Do you have a stamp on your heating system too ??? What kind of tasks
    does it do? I have some of the clock chips if you need one. 6355 I
    think is the number. They are serial..
    Leroy
    Philippe Derenne wrote:
    > From: "Leroy Hall" <leroy@f...>
    > (finally...) :-)
    > Phil.
    edited 2001-09-24 01:11
    Hi Scott,
    Some of the machines trigger the spin after pumpout mechanically I
    think. The late model Sears (Whirlpool) I have will pump, then stop
    briefly and some mechanism latches. When the motor reenergizes it spins
    and pumps.
    Don
    Scott Sutton wrote:
    > Please help,
    > appreciate it.
    > Scott
    > Do You Yahoo!?
    http://im.yahoo.com
    _________________________________________________________
    Do You Yahoo!?
    Get your free @yahoo.com address at http://mail.yahoo.com
    edited 2001-09-24 01:13
    Ooops forgot to mention. On my machine if I interrupt the pumpout by
    raising the lid I hear the latch engage as the motor slows. When I
    close the lid it spins and pumps. So your machine may not have an
    electrical method of engaging the spin. It may be mechanical.
    Don
    Scott Sutton wrote:
    > Please help,
    > appreciate it.
    > Scott
    > Do You Yahoo!?
    http://im.yahoo.com
    Do You Yahoo!?
    edited 2001-09-24 14:10
    Thanks for all the help!
    As it turns out, the speed queen set-up uses a spring
    loaded idler that supplies that tranny with power for
    the spin cyle. The idler disengages the belt to the
    drum when the drum is loaded (water and clothes) but
    the pump continues to run at full speed, when the drum
    empties the water the drum becomes lighter and the
    idler gradually engages the belt for the spin mode. By
    the way, a bs2 comtrolled washing machine is
    great!!And the wife finally appreciates one of my
    projects>
    Scott Sutton
    --- Don Denhardt <dondenhardt@y...> wrote:
    > Hi Scott,
    > mechanically I
    > pump, then stop
    > and pumps.
    > Don
    > Scott Sutton wrote:
    > > Please help,
    > The
    > is
    > Build a
    > that's
    > happen
    > the
    > to
    > to
    > change.
    > in a
    > info
    > greatly
    > > appreciate it.
    > > Scott
    > > Do You Yahoo!?
    > messaging with Yahoo! Messenger. http://im.yahoo.com
    > Text in the Subject and Body of the message will be
    > ignored.
    > Do You Yahoo!?
    > ignored.
    Do You Yahoo!?
    http://im.yahoo.com
    edited 2001-09-24 22:10
    Hi Leroy,
    Well, Im currently working on this system.
    The stamp is controlling 2 pumps (one for each floor), and the fuel burner.
    I use 3 DS1620 to get the room temperature, outside temperature, and the
    water temperature.
    So I can control the water temperature (if the weather is colder, I set the
    water temperature higher). Also, as I'm working on differents shifts, I need
    heating at different moments. It's very simple to program that (plus
    summer/winter mode, holidays...). The system has a LCD and a 6-key keyboard.
    I begin to make some tests with the DS1302 (Dallas Semiconductors). I think
    it's a nice chip, with real-time clock, 31 bytes of RAM, 3-wire interface,
    and it may be backuped by a super-cap. And it's cheap (about 3$ in
    Belgium...)
    Phil.
    Sent: Sunday, September 23, 2001 7:15 PM
    > Leroy
    edited 2001-09-25 05:44
    Hey if you want really white whites try this for cycling
    1. Prewash tepid water (not warm-not cold) (20 minutes)
    Use thermistor to monitor temps using RCTIME
    Engage hot or cold as needed
    2. Spinout
    3. Pause (add soap and bleach)
    4. Hot water wash (20 minutes)
    5. Double rinse
    Boy you could really have fun with that project using LCD. Use KISS
    concepts to avoid having wife get confused. Would be really slick if
    you could do custom cycles by menu selection for custom washes and
    retain some standard cycles also. 'Course that will keep you
    programming for a few months. I can picture wife tapping toes wondering
    if she'll ever get to use the machine again. AND, if so, if it will
    take a doctorate degree in engineering to figure out how to work it.
    Have fun
    Don
    > projects>
    > Scott Sutton
    > > Hi Scott,
    > > mechanically I
    > > pump, then stop
    > > and pumps.
    > > Don
    > > Scott Sutton wrote:
    > > > Please help,
    > > The
    > > is
    > > Build a
    > > that's
    > > happen
    > > the
    > > to
    > > to
    > > change.
    > > in a
    > > info
    > > greatly
    > > > appreciate it.
    > > > Scott
    > > > Do You Yahoo!?
    > > ignored.
    > > Do You Yahoo!?
    > > ignored.
    > Do You Yahoo!?
    http://im.yahoo.com
    Do You Yahoo!?
    edited 2001-09-26 19:19
    I already told my wife about this post. She's loving the idea of
    totally customizing the appliances. She's been sending me things she
    wants in the code. Settable extended soak, pause and chime after
    rinse (to remind her to add the fabric softener), auto re-rinse if
    the clothes sat in the washer overnight. She wants to customize the
    dryer too, with a short cool tumble every 20mins after it stopped
    drying (to prevent wrinkles) in case she forgets to take the clothes
    out right away.
    It looks like I'll be doing this for my next project. Thanks for the
    ideas.
    > 2. Spinout
    > 5. Double rinse
    if
    wondering
    > Have fun
    > Don
    > > projects>
    > > Scott Sutton
    > > > Hi Scott,
    > > > mechanically I
    > > > pump, then stop
    > > > and pumps.
    > > > Don
    > > > Scott Sutton wrote:
    > > > > Please help,
    > > > The
    > > > is
    > > > Build a
    > > > that's
    > > > happen
    > > > the
    > > > to
    > > > to
    > > > change.
    > > > in a
    > > > info
    > > > greatly
    > > > > appreciate it.
    > > > > Scott
    > > > > Do You Yahoo!?
    > > > > basicstamps-unsubscribe@y...
    > > > ignored.
    > > > Do You Yahoo!?
    > > > ignored.
    > > Do You Yahoo!?
    Subject and Body of the message will be ignored.
    > Do You Yahoo!?
    edited 2001-09-26 20:01
    You should write up a detailed project notes in case anyone else has a
    problem similar.
    -Rich
    > projects>
    > Scott Sutton
    > > Hi Scott,
    > > mechanically I
    > > pump, then stop
    > > and pumps.
    > > Don
    > > Scott Sutton wrote:
    > > > Please help,
    > > The
    > > is
    > > Build a
    > > that's
    > > happen
    > > the
    > > to
    > > to
    > > change.
    > > in a
    > > info
    > > greatly
    > > > appreciate it.
    > > > Scott
    > > > Do You Yahoo!?
    > > ignored.
    > > Do You Yahoo!?
    > > ignored.
    > Do You Yahoo!?
    http://im.yahoo.com
    edited 2001-09-26 21:22
    Hey you guys forgot about one of the best features!!
    How about having a automotive windshield washer pump inject the soap???
    When you bring home liquid soap you could just set it on the floor and
    drop the suction tube in it. The stamp could inject different amounts
    depending on,
    A. Water Level
    B. User defined grade of soiling
    Light
    Medium
    Heavy
    I don't know if those little plastic pumps could handle bleach. But it
    might be worth a try. They are only $10-$15.
    Probably the easiest reminder for wife to do clothes is to have the
    Stamp automatically hang up the phone for her [noparse]:)[/noparse]
    > out right away.
    > ideas.
    > > 2. Spinout
    > > 5. Double rinse
    > if
    > wondering
    > > Have fun
    > > Don
    > > > projects>
    > > > Scott Sutton
    > > > > Hi Scott,
    > > > > mechanically I
    > > > > pump, then stop
    > > > > and pumps.
    > > > > Don
    > > > > Scott Sutton wrote:
    > > > > > Please help,
    > > > > The
    > > > > is
    > > > > Build a
    > > > > that's
    > > > > happen
    > > > > the
    > > > > to
    > > > > to
    > > > > change.
    > > > > in a
    > > > > info
    > > > > greatly
    > > > > > appreciate it.
    > > > > > Scott
    > > > > > Do You Yahoo!?
    > > > > ignored.
    > > > > Do You Yahoo!?
    > > > > ignored.
    > > > Do You Yahoo!?
    > > Do You Yahoo!?
    Do You Yahoo!?
    edited 2001-09-26 22:01
    It might not be a good idea to use "liquid soap" in your washing machine,
    unless it is of a special type for this appliance. You risk producing too
    much foam!!!
    Good luck, it's nice to hear that computing can keep a wife happy and
    enthusiastic on your programming activity!
    Jose Luis
    >depending on,
    >A. Water Level
    > Light
    > Medium
    > Heavy
    > > out right away.
    > > ideas.
    > > > 2. Spinout
    > > > 5. Double rinse
    > > if
    > > wondering
    > > > Have fun
    > > > Don
    > > > > projects>
    > > > > Scott Sutton
    > > > > > Hi Scott,
    > > > > > mechanically I
    > > > > > pump, then stop
    > > > > > and pumps.
    > > > > > Don
    > > > > > Scott Sutton wrote:
    > > > > > > Please help,
    > > > > > The
    > > > > > is
    > > > > > Build a
    > > > > > that's
    > > > > > happen
    > > > > > the
    > > > > > to
    > > > > > to
    > > > > > change.
    > > > > > in a
    > > > > > info
    > > > > > greatly
    > > > > > > appreciate it.
    > > > > > > Scott
    > > > > > > Do You Yahoo!?
    > > > > > ignored.
    > > > > > Do You Yahoo!?
    > > > > > ignored.
    > > > > Do You Yahoo!?
    > > > Do You Yahoo!?
    >Do You Yahoo!?
    edited 2001-09-27 13:26
    >problem similar.
    >-Rich
    Agreed, it would make a good candidate for the LOSA archive :-)
    Cheers
    Derryck Croker
    edited 2001-09-27 21:28
    MAke it a network device. Have it order more soap when it runs low.
    -Rich
    > depending on,
    > A. Water Level
    > Light
    > Medium
    > Heavy
    > > out right away.
    > > ideas.
    > > > 2. Spinout
    > > > 5. Double rinse
    > > if
    > > wondering
    > > > Have fun
    > > > Don
    > > > > projects>
    > > > > Scott Sutton
    > > > > > Hi Scott,
    > > > > > mechanically I
    > > > > > pump, then stop
    > > > > > and pumps.
    > > > > > Don
    > > > > > Scott Sutton wrote:
    > > > > > > Please help,
    > > > > > The
    > > > > > is
    > > > > > Build a
    > > > > > that's
    > > > > > happen
    > > > > > the
    > > > > > to
    > > > > > to
    > > > > > change.
    > > > > > in a
    > > > > > info
    > > > > > greatly
    > > > > > > appreciate it.
    > > > > > > Scott
    > > > > > > Do You Yahoo!?
    > > > > > ignored.
    > > > > > Do You Yahoo!?
    > > > > > ignored.
    > > > > Do You Yahoo!?
    > > > Do You Yahoo!?
    > Do You Yahoo!?
    You would probably enjoy the article "Homedaddy does the Laundry"
    by Todd Pinsky, which addresses the issue of highly-customized
    washing machines... It's in "Funny Times" magazine/newspaper
    October issue page 21, available at most Borders/Barnes & Noble.
    Reg Neale
