Making a terminal program work — Parallax Forums
edited 2001-09-22 19:59 in General Discussion
Hi ...
I've been having great fun writing and running programs on my BS2.
I have no problems running a debug window and getting DEBUG output.
But I want to capture serial data from the stamp in another program.
As a first step, I'd like to see data from the stamp in a terminal
program. I have a fine terminal emulator called SecureCRT
(www.vandyke.com).
I connect to the stamp at 9600 baud, 8 data bits, parity off, 1 stop
bit. I turn off all the flow control. It seems like the data should
come rolling in.
I see typed characters echoed back to the terminal program, so that
would seem to verify the physical connection, right? But no data from
my program that writes perfectly to the stampw debug window.
Any ideas?
Best regards,
Mojo
Morris Jones <*>
San Rafael, CA
mojo@w...
http://www.whiteoaks.com
    edited 2001-09-19 09:05
    Are you sure your terminal program keeps
    the DTR line low (better still, disconnect the DTR line).
    greetings peter
    Oorspronkelijk bericht
    Van: Morris Jones [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=MmStxCEOu-I9fWWTYfNpPpVrwSNrLIaw4iOyKeuOj40et2CDJqfkRQQ0ilnSmlCJy_jnJf9QXtRjQQ]mojo@w...[/url
    Verzonden: woensdag 19 september 2001 08:52
    Aan: basicstamps@yahoogroups.com
    Onderwerp: [noparse][[/noparse]basicstamps] Making a terminal program work
    Hi ...
    (www.vandyke.com).
    come rolling in.
    Any ideas?
    Best regards,
    Mojo
    Morris Jones <*>
    San Rafael, CA
    mojo@w...
    edited 2001-09-22 18:39
    I wrote this last Wednesday, and got no responses. So that tells me
    that my problem is something fundamental and I'm not getting it, but not
    a common problem. [noparse]:)[/noparse]
    Meaning no one else has trouble making a stamp write data to a terminal
    program.
    Still, though it appears that the stamp is running a program that does
    nothing but write to the serial port, and I can see the output fine in
    a stampw debug window, all I can do from a terminal program or from my
    own program is get echoes back of sent characters.
    If I unplug the stamp from the serial port, the echoes quit.
    I just don't quite understand why the BASIC Stamp Editor debug window
    would work, but a terminal program wouldn't. Does anyone have any
    insight to offer on this?
    I'm on Windows 2000 with a generic PC, and I'm writing in Visual C++,
    or using any number of serial comm programs for testing.
    Best regards,
    Mojo
    On Wed, 19 Sep 2001, Morris Jones wrote:
    > Hi ...
    > (www.vandyke.com).
    > come rolling in.
    > Any ideas?
    > Best regards,
    > Mojo
    Morris Jones <*>
    San Rafael, CA
    mojo@w...
    edited 2001-09-22 19:09
    Mojo:
    The Stamp programming connection echos back any character sent to it (it's a
    hardware thing and can't be changed or disabled). Your software needs to
    filter the echoed characters. The Stamp DEBUG window "knows" about this and
    deals with it accordingly.
    -- Jon Williams
    In a message dated 9/22/01 12:41:24 PM Central Daylight Time,
    mojo@w... writes:
    > program.
    edited 2001-09-22 19:29
    Jon, I really appreciate the response.
    But I only tried "sending" characters to see if the connection was live.
    The problem is that I'm not getting any characters at all from the stamp
    program whether I send any or not, except if I use the debug window.
    I'm going to try tracking down a serial port monitor today and see if I
    can tell if data is being sent out the port or not, or if the program
    is running or not.
    (There's no reason to believe that a program stops running when you close
    the debug window, is there?)
    Best regards,
    Mojo
    On Sat, 22 Sep 2001 jonwms@a... wrote:
    > Mojo:
    > -- Jon Williams
    > mojo@w... writes:
    > > program.
    Morris Jones <*>
    San Rafael, CA
    mojo@w...
    edited 2001-09-22 19:36
    Hi Morris,
    You did get a response from Peter, which pointed out the likely
    problem. Your terminal program is probably holding the DTR line
    high. That is the reset signal into the BASIC Stamp that goes into
    pin 4 on the DB9 connector and into pin 3 on the BASIC Stamp IC. The
    debug terminal leaves that line low, and that is why you see the data
    coming onto your debug screen but not the terminal program. On the
    upper right hand edge of the Debug screen you will see a checkbox for
    DTR and it starts out unchecked. If you check it, the DTR line will
    be forced high and your stamp will go into reset.
    What you need to do to make it work with your terminal program is
    1) disconnect the DTR signal line
    2) insert a capacitor (~0.1uf) in series between the DTR line and
    pin 3 on the Stamp. That will make the Stamp reset when DTR first
    goes high, but then it can operate normally. I think that is the way
    most BASIC Stamp systems are configured.
    >program.
    DTR is usually the culprit.
    >Best regards,
    >Mojo
    > > Hi ...
    > > (www.vandyke.com).
    > > come rolling in.
    > > Any ideas?
    > > Best regards,
    > > Mojo
    >Morris Jones <*>
    >San Rafael, CA
    >mojo@w...
    edited 2001-09-22 19:40
    Hot darn! I missed his response. I'm quite certain that is the
    problem. Thank you!
    Best regards,
    Mojo
    > Hi Morris,
    > or
    > >program.
    > >Best regards,
    > >Mojo
    > > > Hi ...
    > > > (www.vandyke.com).
    > > > come rolling in.
    > > > Any ideas?
    > > > Best regards,
    > > > Mojo
    > >Morris Jones <*>
    > >San Rafael, CA
    > >mojo@w...
    Morris Jones <*>
    San Rafael, CA
    mojo@w...
    edited 2001-09-22 19:52
    Can your PC see the same data thats going to the Stamp Debug window? Are
    there any extra characters before the debug message? If so, I would suspect
    that the Stamp Debug window is receiving some sort of code to tell it the
    data being sent is a debug command. If your PC does not send the code, the
    Debug window would ignore it. This is pure speculation since I use a
    different method to talk to a PC.
    As far as the echoing, this is a normal feature when using a serial
    connection with PIN16 on a BS2
    > program.
    Actually, if the cable is connected and you close the debug window, the
    program does stop.
    > is running or not.
