Interfacing the LCD with the RTC and DTS Chips (from the Stampworks experiments)
Hi all,
Now that I was successful putting time on the LCD, I went ahead and
tried to put a DS1620 and DS1302 together to add the output of
temperature to the LCD. I know this is close to the challenge problem
of Experiment #30. I notice that according to the diagram, it is OK
to share the lines coming out of P0 and P1 to both chips. However, I
tried to share P0 to both chips and noticed a different in output to
both the LCD and Debug screen from the code I used to output only the
time to the displays. I know I can hook up some unused open I/O ports
separately
to the Digital temperature sensor (DTS). Is there anyway I can
actually share the lines such as P0 and P1? If so what is the right
way? Ant input will be appreciated. Thank you very much.
Sincerely,
RP
separately
Sincerely,
RP
