Serial cable length — Parallax Forums
Serial cable length
edited 2001-10-18 18:46 in General Discussion
The stamp programming manual outlines the use of a 22K resistor when using the
serin command (and direct connection when using the serout command). I've used
this setup successfully, but was wondering how long of a cable I can use,
without using a line driver? About 2' of cable seems to work well now.
This isn't for a production product, and I don't have to worry about connecting
to unknown serial devices.
Kevin
    edited 2001-09-07 22:49
    If you are going to talk to a true serial device (PC, printer, etc...) with
    a regular Stamp pin, look into a MAX232 chip. One chip and 4 capacitors
    gives you two channels of true RS232.
    The resistor thing is a workaround to drop the voltage to Stamp levels.
    the
    used
    connecting
    edited 2001-09-07 22:59
    Yes, thanks, understood.
    But does anyone have any experience with the current limiting resistors approach
    and cable length? I'd guess this is highly dependent on the individual serial
    implementation on the other side of the line, just looking for others' data
    points.
    Kevin
    > the
    > used
    > connecting
    edited 2001-09-07 23:16
    RS232 is spec'd for + / - 12 volts -- the Stamp can put out 0 to +5 volts.
    This is what limits your distance. I suspect 3-5 feet with a good 20 gauge
    or larger shielded cable may be pushing it.
    Receiving the RS232 signal with the Stamp should not be a problem -- the
    resistors drop the voltage to Stamp levels. Its the maximum of 5 volts the
    Stamp can put out transmitting the RS232 signal that can be an issue.
    Depending on the baud rate and the type of cable you have, you can get over
    500 feet with the MAX232's
    approach
    serial
    data
    > points.
    with
    using
    > > the
    I've
    > > used
    use,
    now.
    > > connecting
    edited 2001-09-08 02:56
    Yep. From what I'm seeing there a number of interpretations of the 'spec'. I
    suspected the same thing, just thought I'd ask to see if anyone had actually
    fooled around with this.
    Yes yes, maxim is good, got it (I'd probably use an LTC part though), just
    thought I see what sort of experience folks had without using a line driver.
    Kevin
    edited 2001-09-08 19:03
    >I've used
    >connecting
    >Thanks,
    >Kevin
    Hi Kevin,
    There are 3 issues I think:
    1) capacitance of the cable degrades the signal.
    2) noise induced from outside sources fakes a signal.
    3) ESD from lightning or accidents, oops.
    #1 can be improved by operating at a lower baud rate. I have run 200
    feet at 300 baud at TTL levels for a kluged setup, through Belden
    8443 unshielded cable. Not a scientific test. Depends on the cable
    and on the resistance (RC time) driving the cable. If you are using
    a stamp, use no more than 220 ohms in series to drive the line.
    #2 Using shielded twisted pair cable can cut down the noise. However,
    shielded cables will have a higher capacitance. Noise can be awful
    on an unshielded cable. Of course, depends on where you are. The
    stamp input does not have any hysteresis, and the asymmetric
    threshold is not ideal if you are receiving TTL levels.
    Funny things can affect the results. Say your cable runs on the
    ground outdoors. It can work at first but stop working when it
    rains, because of changes in capacitance or noise. Or somebody can
    turn on a motor nearby. Okay for a kluge, but don't depend on it for
    the long term.
    #3 Well, ESD is separate issue.
    -- Tracy
    edited 2001-09-09 01:18
    Thanks for the reply.
    BTW, what's the 220ohm resistor for?
    I'll be driving this with a BS2 (maybe a PIC too, but I guess I can't
    admit to that on this list ;-)
    Kevin
    when using the
    command).
    > >I've used
    can use,
    now.
    about
    > >connecting
    > >Thanks,
    > >Kevin
    > Hi Kevin,
    200
    However,
    for
    > the long term.
    > -- Tracy
    edited 2001-09-09 04:10
    >Kevin
    Hi Kevin,
    The 220 ohm resistor the output of the stamp is there simply to
    protect it from accidents. Anytime an IC pin (Stamp, PIC, HC11,
    '555, CD4011, whatever) is connected to the "outside world", it is
    prudent to put at least resistor in series just in case... The
    resistor limits fault currents. There are some chips specifically
    designed as "line drivers" where this is not necessary. You should
    not go overboard with the protection, because more resistance will
    slow down the signal.
    -- Tracy
    edited 2001-09-09 04:32
    Thanks. So I'm guessing the 220ohm value is choosen to be a balance between
    protection and lost signal. 5/220 = about 23mA. Any smaller and I'll go over
    the 25mA current sink limit, any larger and I needlessly loose signal strength
    if I'm just trying to protect against 5V, yes?
    Thanks again,
    Kevin
    edited 2001-09-10 06:00
    Exactly!
    edited 2001-10-18 18:35
    All,
    I have an application that requires me to periodically access the
    Stamp via the Serial port. It is located in an awkward position and I
    would like to bring a serial cable from the Stamp to a more
    convenient location. The board has decoupling capacitors to the DB9
    and to ground on the ATN line (as done on the BOE). I have a
    shorting plug that would hold ATN to ground at the remote serial
    port, when not in use.
    Thus my questions for the collective wisdom:
    1) How long a serial cable can I have between the computer and the
    DB9 on the Stamp board?
    2) Is the shorting plug sufficient to prevent false ATN interrupts to
    the Stamp? (Or is it really necessary?)
    Thanks for you input,
    Phil
    At 05:35 PM 10/18/01 +0000, you wrote:
    >All,
    >Phil
    I have made 200ft runs with plain-jane 4-conductor telephone wire up
    through ceiling tile and over an area with heavy machinery without any
    problems. I did have a 1K resistor tied between the ATN and GND at
    the stamp location however.
    Beau Schwabe IC Mask Designer
    National Semiconductor Wired Communications Division
    500 Pinnacle Court, Suite 525 Mail Stop GA1 Norcross, GA 30071
