Off the subj.
On Thu, 6 Sep 2001, Production Technology, L.L.C. wrote:
> HELP,
> Does anyone know how to print a text file to a networked laser printer.
> If the printer is not networked you can do either of the following.
> type filename>lpt1
> print filename /d:lpt1
> Is there anything similar either in windows or dos for a networked printer
> Thanks,
> David Fixemer
> fixemerd@a...
Open the file in notepad, click file, print, and select the printer that
you wish to print to, assuming you already have the drivers loaded on
this machine.
OR
net use lpt3 \\machine_name\printer_name
which will map lpt3 ( or use lpt2 ) to the printer named printer_name on
the machine called machine_name.
NOTE: my win-box would not allow me to use an ip address in place of
machine_name.
After this is done, you can
type filename.ext > lpt3 and the file will print on the remote printer.
This at least works from my windows box printing to my linux server where
the printer is attached.
Dale Harwood [noparse][[/noparse] N4VFF ]
internet> dale@h...
ax.25> n4vff@n4vff.#cha.tn.usa.noam
#include <std_disclaimer.h>
> HELP,
> type filename>lpt1
> Thanks,
> David Fixemer
> fixemerd@a...
this machine.
OR
machine_name.
internet> dale@h...
type filename>lpt1
David Fixemer
fixemerd@a...
In a Microsoft network, the dos command NET PRINT is useful.
If this is not enough help, contact me off-line. I'm in PA.
Daniel
> From: Production Technology, L.L.C. [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=0YVufiWgmPa1D-82KFVukWOFj1Uo39__I3d0p1Mhb0PfxYvgiw_zE-uiQFG0pHdAWzMv36SU_ASH]fixemerd@a...[/url
> Sent: Thursday, 06 September 2001 13:44
> Subject: [noparse][[/noparse]basicstamps] Off the subj.
> HELP,
> type filename>lpt1
> Thanks,
> David Fixemer
> fixemerd@a...
> from the same email address that you subscribed. Text in the
_________________________________________________________
Do You Yahoo!?
Get your free @yahoo.com address at http://mail.yahoo.com
Sorry, I hit send too quick.
In a Microsoft network, the dos commands NET USE and NET PRINT are useful.
Help is available by NET USE /? and NET PRINT /?
Daniel
> From: Production Technology, L.L.C. [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=GVtakJ_BmlhpMvIwiFxm13DvUs9m5bv0Imgu3M4DrqGjKGjb8K5dZLcFmvNLRCAcqjFtedBJY3gXDrN-xw]fixemerd@a...[/url
> HELP,
> type filename>lpt1
> Thanks,
> David Fixemer
> fixemerd@a...
Do You Yahoo!?
copy filename \\network\printer_name
From: D. Daniel McGlothin [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=68ONX4ZLIQNitvKSR1Z8ua8lLiwEuETYT5XEphR9OAPqsWlv4XsbqhUK18971MmQcpdEqYCF37-PQ3hS]ddm_stamps@y...[/url
Sent: Thursday, September 06, 2001 11:29 AM
Subject: RE: [noparse][[/noparse]basicstamps] Off the subj.
Hi David,
Daniel
> From: Production Technology, L.L.C. [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=MZc4YuKGk8KNQtXnt2m_5ByekawFaBubg-dYMdm90uv1FS_XfO2dJV0uMSKiSncmGpnL1_V8C5zV4gZLQQ]fixemerd@a...[/url
> HELP,
> type filename>lpt1
> Thanks,
> David Fixemer
> fixemerd@a...
Do You Yahoo!?
Go into the printer driver properties for the network printer in Windows and
set up the 'capture printer port'
under details. Then you can use your normal dos type and print functions in a
dos box and they will route to the
network printer that is capturing.
Bill Mrozinski
"Production Technology, L.L.C." wrote:
> HELP,
> type filename>lpt1
> Thanks,
> David Fixemer
> fixemerd@a...
