Is 500 Lines of PBASIC too little? — Parallax Forums
edited 2001-08-29 18:45 in General Discussion
I was browsing Parallax's BASIC Stamp offerings, and found every
qualification to meet my needs except one: The statement that it has
500 Lines of PBASIC doesn't seems like quite a lot; does anyone have
experience with this? Is 500 lines of PBASIC enough for most uses or
is it too little?
Ben
    edited 2001-08-29 16:07
    In a message dated 8/29/01 9:02:34 AM Central Daylight Time,
    bwoodacre@y... writes:
    Keep in mind that PBASIC was designed for embedded applications, so one line
    of code can do quite a bit of work. I've written some fairly serious
    applications for the Stamp and never run out of space. Efficient coding is
    the key.
    If you do, in fact, need more code space, the BS2e, BS2sx and BS2p all have
    multiple (8) program banks and a shared RAM space (not part of the normal
    variables) that can be used to pass data back and forth between them.
    -- Jon Williams
    You can fit a butt-load of code into the BS2's, and the multiple program
    banks make it easy to write a large program.
    Best thing to do is write the code you want, then study examples in the
    various Parallax documents to help you improve the speed and decrease the
    memory used. Lots of good tips in the educational documents, and they are
    free. The Nuts & Volts books are good also, and cover a broader spectrum of
    applications. I'm about 1/2 way through book one and already it has helped
    me code more better <grin>/
    line
    is
    > the key.
    have
