loop interrupt?
Lou-
In addition to Chuck's excellent suggestions, you might also want to
get in the habit of doing some of the following:
When your Stamp program starts, all of the I/O pins are inputs, so
you don't need to initialize pins to the input state.
It's good practice to set the state of an I/O pin's output latch
prior to making that pin an output. In your code, you'd probably be
setting I/O pins 10, 11 and 12 low by making them outputs at the
beginning. Probably not what you mean to do. A couple of
initialization options:
HIGH 10 'Make pin 10 an output, high -DVD track 1
HIGH 11 'Make pin 10 an output, high -DVD track 2
HIGH 12 'Make pin 10 an output, high -DVD track 3
-or-
OUTS = %0001110000000000 ' initialize output latches
DIRS = %0001110000000000 ' initialize direction bits
PBASIC2 also allows you to use aliases for pin names and predefined
variables. This can greatly simplify your life:
coin_pin VAR IN1
button_pin VAR IN2
DVD_1 CON 10
DVD_2 CON 11
DVD_3 CON 12
i VAR WORD
Loop:
LOW DVD_1 'turn on dvd attract track
FOR i = 1 TO 2000
IF coin_pin = 0 THEN coinInserted ' assumes active low
PAUSE 10 'pause for 1/100 second
NEXT
HIGH DVD_1 'release button
GOTO Loop
coinInserted:
(do the right thing...)
GOTO Loop
In this example you can use "coin_pin" in place of IN1, and DVD_1 in
place of 10, and so on. It's a lot easier to remember, less prone to
typo errors, and you only have to change the pin number once should
you need to change your Stamp's wiring scheme.
Little things, but as your programs grow in size and complexity they
can make a big difference.
Steve
-or-
coin_pin VAR IN1
button_pin VAR IN2
DVD_1 CON 10
DVD_2 CON 11
DVD_3 CON 12
i VAR WORD
Loop:
FOR i = 1 TO 2000
NEXT
GOTO Loop
coinInserted:
GOTO Loop
Steve
See the manual regarding OUTS and DIRS--it explains it better than I
can. In short, they provide a quick way to set the output latches
and input/output directions to desired values.
> okay, if I want to create aliases for the pin inputs, should I be
> using 'Coin_Mech VAR IN0' or 'Coin_Mech CON IN0'?
IN0 is the name for the predefined bit variable whose value (0 or 1)
is determined by the logic level (low or high) present at I/O pin 0.
PBASIC won't allow you to treat a variable (predefined or otherwise)
as a constant (CON). However, you can refer to any variable by a
more meaningful name by defining an alias for the variable. Think
of it as a nickname.
You can only assign a CON alias to a number such as 10 or some other
constant value.
I like to simulate a button/switch by connecting a ~4.7K resistor
from the I/O pin to +5 volts. Attach a jumper wire to the same I/O
pin. After assuring yourself that the pin is indeed in input mode
(check your program carefully--if in doubt send DIRS to the DEBUG
screen), briefly touch the jumper to ground to simulate switch
closure. In this configuration you are testing for an active low
closure (IF switch = 0 THEN switchClosed). If the pin is in input
mode, you won't hurt your Stamp using this technique.
My guess is you're getting "free plays" because you have nothing
attached to I/O 0, so it's reading high (i.e. "1") most of the time,
which is very common for a floating (nothing attached) input. Pull
the input to ground or +5 volts with the resistor described above to
establish an unambiguous default state, then test for the opposite
condition to detect switch closure.
Steve
First off, I'd like to thank everyone who helped me
through my stamp->pc setup. I've got it working now
and I'm eager to get starting coding. I'm building a
little prototype of a coin operated video game- it's
pretty simple, but i'm new to pbasic, so i've got a
quick question.
so far i've got:
'========== Initialize ============
input 1 'Make pin 1 the coin mech input
input 2 'Make pin 2 the button input
output 10 'Make pin 10 an output -DVD track 1
output 11 'Make pin 11 an output -DVD track 2
output 12 'Make pin 12 an output -DVD track 3
'======== Attract Startup =========
Loop:
LOW 10 'turn on dvd attract track
PAUSE 1000 'pause for 1 second
HIGH 10 'release button
PAUSE 20000 'wait for 20 seconds, repeat
GOTO Loop:
How can I set this up to be interrupted by a pulse
from the coin mech?
Thanks for the help!
-Lou
__________________________________________________
Do You Yahoo!?
Make international calls for as low as $.04/minute with Yahoo! Messenger
http://phonecard.yahoo.com/
Thanks for the help, I've incorporated the pin aliases and got the loop
working. It took a couple re-reads of your email to really grasp everything
you explained, but I think I've got it now.
All but:
of course, if I can achieve the same thing with:
okay, if I want to create aliases for the pin inputs, should I be using
I have yet to attach anything to the stamp- I'm a little bit shaky on how to
wire a button up, or deal with the 5volt pulse from the coin mechanism. I'm
somewhat afraid (probably with good reason) that I'm going to blow the stamp
up... My electrical knowledge is pretty weak, and I'm concerned that I will
overload the board. I understand that I need to add resistors into the
button, and that the overall sink (amount of current flowing in?) cannot
exceed 50mA- on the output side I need to wire in a few relays- Oh no, it's
electrical theory time... Time to do more reading with the radio shack
catalog in hand-
Is there some way to 'simulate' an input on a button? Is this what the
macros are for? I tried setting one up as 'credit = 1', where credit had
been defined at the beginning of the program- it didn't seem to do anything.
Thanks again for the help!
-Lou
(I'm having an issue with the coin_mech input, which seems to be giving
'free games'...)
DEBUG CLS, "System Startup", CR
'======== Initialize I/O =========
input 0
input 1
HIGH 10
HIGH 11
HIGH 12
HIGH 13
HIGH 14
HIGH 15
'============ Map I/O ============
Coin_Mech VAR IN0 'Make pin 0 the coin mech input
Button_Input1 VAR IN1 'Make pin 1 the button input
DVD_Track_1 CON 10 'Make pin 10 an output triggering DVD track 1
DVD_Track_1_Length CON 5000 'Length of DVD track 1
DVD_Track_2 CON 11 'Make pin 11 an output triggering DVD track 2
DVD_Track_2_Length CON 5000 'Length of DVD track 2
DVD_Track_3 CON 12 'Make pin 12 an output triggering DVD track 3
DVD_Track_3_Length CON 5000 'Length of DVD track 3
Audio_Switch CON 13 'Make pin 13 an output -audio switcher
Video_Switch CON 14 'Make pin 14 an output -video switcher
Effect_Switch CON 15 'Make pin 15 an output -effect relay
'===== Initialize Variables =======
pulseCount VAR WORD 'establist pulsecount variable
pulseCount = 0
credit VAR NIB 'establish credit variable as 0-15
credit = 0
gameInPlay VAR BYTE 'establish if game is currenly in play
gameInPlay = 0
gameCount VAR WORD 'establish gamecount variable
gameCount = 0
reps VAR WORD 'establish counter loop
'===== Output Debugging Info ======
GOSUB System_Status_Sub
'======== Game_Logic Loop =========
Game_Logic:
IF credit=0 THEN Attract_Loop 'if credits are not present
IF credit>0 THEN Game_Play 'if credits are present
GOTO Game_Logic
'========= Attract_Loop ==========
Attract_Loop:
LOW DVD_Track_1 'turn on DVD_Track_1
FOR reps = 1 TO DVD_Track_1_Length/2
IF Coin_Mech = 1 THEN Game_Play 'assumes active high
PAUSE 2 'pause for 2 ms
NEXT
HIGH DVD_Track_1 'release DVD_Track_1
GOTO Game_Logic
'========== Game_Play ============
Game_Play:
credit=credit-1 'subtract credit for game
gameInPlay=1 'set gameInPlay variable
gameCount = gameCount + 1 'increment gameCount
gameInPlay=0 'set gameInPlay variable
GOTO Game_Logic
'====== System_Status_Sub ========
System_Status_Sub:
DEBUG CLS, "SYSTEM READY:", CR
DEBUG ? gameInPlay
DEBUG ? credit
DEBUG ? gameCount
RETURN
