Devantech compass — Parallax Forums
Devantech compass
edited 2001-09-02 16:45 in General Discussion
I have uploaded Devan.bs2 to the files section. This demo program for
the BS2 reads via I2C either in single byte or two byte mode and
displays with debug.
It uses the I2C routines from wwww.high-techgarage.com.
The module was purchased from www.acrnoname.com and is made by
www.robot-electronics.co.uk
    edited 2001-09-01 11:10
    Thanks for posting this code Mike - I now understand the mechanics of
    talking I2C from a BS2 but I'm not getting good clean results with the
    program. The values coming out are ranging from 255 (the most common output,
    regardless of orientation !) and across to 037 and back to 127. All without
    moving the compass !?
    The docs (http://www.robot-electronics.co.uk/htm/cmpsdoc.htm) talk of
    pull-up resistors needed on the I2C bus. It says they are required on the
    SCL and SDA lines and their values are dependent on clock speed. It also
    says that the compass is designed to work up the the standard clock speed
    (SCL) of 100KHz but can be driven at up to 1MHz. Do you have these resistors
    in place in your circuit ? Do you have a circuit diagram I could look at ?
    Thanks in advance (again !).
    Justin.
    From: miked@t... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=voTsP2MZKcP17KAJIPwdd11L7pERqN2kFbWqlNpZop0CWxodoTbj0hM07ymntpQob9KB0OnzwOQl3TvfNo33x9c]miked@t...[/url
    Sent: 27 August 2001 20:59
    Subject: [noparse][[/noparse]basicstamps] Devantech compass
    Did you see the notice about a cap may be needed depending on the
    power supply you use?
    Also make sure module is not close to magnets, motors, electric
    equipment.
    in
    Pull ups are always needed for I2C. I used the 'standard' value of 4.7K
    I just hooked 2 pins from the BS2 to the compass module with the pull ups.
    > Justin.
