Need some advice.
I am building a unit that is going to be measuring pressure, temperature, ph,
conductivity and possibly one or two more things. I am using a BS2P and would
like to find a 12 bit A/D converter with several channels, and probes that I can
use the I2c or the one wire protocol, neither of which I have used. Basically
I want to consolidate all these things together, use similar communication, use
minimal stamp lines and still have room for expansion. Any suggestions?
Ricky Konvicka
Electronic Engineer
BioTech International Inc.
www.biotechintl.com
Ricky Konvicka
Electronic Engineer
www.biotechintl.com
Take a look at Texas TLC 2543. It has several channels, all addressable.
Uing one here and it works great. For coding examples search the Internet
for TLC2543 and go to Al Williams Owl2 Interface site. Owl2 has all the
codes for the 2543.
Sid
there a nice IC out there that takes care of several channels?
Sent: Monday, August 27, 2001 11:43 AM
Subject: Re: [noparse][[/noparse]basicstamps] Need some advice.
> For Ricky
> codes for the 2543.
> Sid
>From: "Ricky Konvicka" <ricky@m...>
>Reply-To: basicstamps@yahoogroups.com
>Subject: [noparse][[/noparse]basicstamps] Need some advice.
>Date: Mon, 27 Aug 2001 10:57:21 -0500
>ph, conductivity and possibly one or two more things. I am using a BS2P
>and would like to find a 12 bit A/D converter with several channels, and
>probes that I can use the I2c or the one wire protocol, neither of which I
>have used. Basically I want to consolidate all these things together, use
>similar communication, use minimal stamp lines and still have room for
>Ricky Konvicka
>Electronic Engineer
>www.biotechintl.com
_________________________________________________________________
Get your FREE download of MSN Explorer at http://explorer.msn.com/intl.asp
directly.
Sid
Al Williams
AWC
* 8 channels of PWM
http://www.al-williams.com/awce/pak5.htm
> From: Newzed@a... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=3R6HW7bgQDbgq_cLb7EE46cJaRmuadmujlGNZcsdnFTMh6V1eSESgBmbk0HzJV61wWo4bSE]Newzed@a...[/url
> Sent: Monday, August 27, 2001 11:44 AM
> For Ricky
> addressable.
> Internet
> codes for the 2543.
> Sid
As usual you are correct. Hope Tracy doesn't see that.
Sid
ACJacques
> Ricky Konvicka
> Electronic Engineer
> www.biotechintl.com
lines. It's 12 bits of resolution and has 8 channels.
Paul
interface?
Sent: Monday, August 27, 2001 4:28 PM
> Try the MAX186 for an ADC. It's an SPI device, so it takes two
> Paul
>>>codes for the 2543.
>>I don't make the OWL2. Isn't that Tracy?
>Ricky, the TLC2543 is a 12-bit 6 channel ADC. Stamp will read the output
>directly.
Aha! Right, the information is at
http://www.emesystems.com/OWL2face.htm#TLC2543
The TLC2543 has 11 external channels, and those extra channels are
one reason I favor it.
>temperature, ph, conductivity and possibly one or two more things.
>I am using a BS2P and would like to find a 12 bit A/D converter with
>several channels, and probes that I can use the I2c or the one wire
>protocol, neither of which I have used. Basically I want to
>use minimal stamp lines and still have room for expansion. Any
>suggestions?
The SPI interface takes 4 (or 3) lines with one additional line per
device you add to the system. The I2C and one-wire protocols that
are available built into the BS2p take only two lines to daisy chain
many devices.
The pressure, pH and conductivity sensors are probably going to be
analog sensors, so you will need analog signal conditioning circuitry
to interface them to input channels of the ADC. I have a few
interface circuits on my web site. The temperature sensor you could
get in analog or directly in any of the different digital protocols.
-- good luck
Tracy
