Parallel port on a basic stamp ?
Has anyone used (basically all the pins on a BS2) to recreate a pc type
parallel port? The reason is I have got (frankly I bought the wrong thing
at the time but it's done now) a dual stepper motor controller which would
run off a parallel port. Is it possible to simply set 12Bits of data and
then fire the strobe ?
Justin
Justin
Allegro 5804 stepper motor drivers. Take a look at:
http://www.allegromicro.com/sf/5804/
They will even send you free samples. I'm sure you can use the
stepper controller you already have but this Allegro driver will
certainly save you some development time.
type
thing
would
data and
> Justin
