Stranges BS2 results
I have a setup in testing with a BS2 , LED with built in resistor,
and a hacked Passive Infrared Sensor. The PIR shows 0.03 volts when
active and 5.06 when idle. I have written code that basically turns
on the led when motion is detected (Will use a Relay next), and
display via Debug "Motion detected". When there is no motion it
displays "All's still".
Now the problem. When I turn on the unit is Waits for and displays
the "All's still" message over and over as it should, then when I
cause the PIR to go active the "Motion detected" message displays and
the Led lights as is should. Now here is the actual problem. The
stamp from this point forward either the BS2 is reseting and my
results are when the PIR goes low it like causes a loop and makes the
PIR active again over and over.I know there is no movement being
detected. Now when I remove the LED and rest the Stamp, the PIR works
fine and displays the correct message. Now, as soon as I re-install
the led the next time motion is detected it begins the strange loop
of detecting movment, and when the PIR goes high, within a breif
second somthing causes the PIR to go low and the LED to light over
and over. This is so strange since the BS2 pin 9 is input and not
out, so why would it cause the PIR to go low?
Here is my BS2 prog.
Start:
If in8=0 then movement 'IF PIR goes low goto movment
in7=0 'turn off led
Debug "All's still",cr
goto start
movement:
in7=1 ' turn on led motion detected
Degug "Motion detected",cr
pause 5000 'Let PIR settle befor returning
goto Start:
Circuit is simple
BS2
Pin 8 to 330 ohm to signal line of PIR (PIR powered by 5 volts) PIR
is Active low. High voltage is 5.06 volts
Pin 7 to LED(built in resistance unknown came from a BS@ kit from a
professor at a university who sells alot of BS2 kits and how-to's
online) to GND
I hope someone out there knows what I'm trying to say. I'm very new
to Electronics and stamps, but having fun until it don't work. I plan
to add a relay into the LED circuit to turn on and off a flashing 12
VDC security light when motion is detected.
Thanks tremendously!
Shawn
Start:
in7=0 'turn off led
goto start
movement:
goto Start:
Circuit is simple
BS2
online) to GND
Shawn
1) To turn on/off the LED, don't use IN7, use OUT7. Or better yet, use HIGH
7 and LOW 7.
2) To see if the Stamp is resetting, but this as the first line:
Debug "RESET",cr
Start:
3) We'll assume Degug is a typo in the e-mail :-)
Good luck!
Al Williams
AWC
* Floating point A/D
http://www.al-williams.com/awce/pak9.htm
> From: shawnusa@e... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=B12yk1ktnNV-ZM2jdLSYNcxpQ09hdedgOdmzd3Lqg5b-nzVV6UGhGf-luCY9wgC7bHwGRUI17epF]shawnusa@e...[/url
> Sent: Friday, August 24, 2001 9:25 AM
> Subject: [noparse][[/noparse]basicstamps] Stranges BS2 results
> Start:
> in7=0 'turn off led
> goto start
> movement:
> goto Start:
> Circuit is simple
> BS2
> online) to GND
> Shawn
> from the same email address that you subscribed. Text in the
I did use High and low for the led. I will try the rest test
tonight. I still find it strange that the thing works when the led is
removed.
Here is a running example of the problem to try and better explain
the problem.
While the unit is running I'm measuring the voltage at PIR input pin
voltage on the PIR Debug Ouput LED status
5.06 all still off
5.06 all still off
I wave my hand in front of PIR
0.03 Motion detected on
pause to wait for PIR to settle
loops to start (PIR is now at 5.06 volts). Good so far
5.06 all still off
5.06 all still off
this repeats for what appears to be half a second or a little more
then this is where it "Loops" without me activating"waiving my hand"
the PIR.
pause
5.06 all still off
5.06 voltage shows for a second or less then
0.03 motion detected on
From here it just keep going over and over with same results each
time. Now when I remove the LED everything is fine.
Now let's say that the stamp is indeed restting. What and or why
would it do such a thing, and more importanly how would I fix it?
Again thanks for all help
Shawn
Since you are actually measuring a change in voltage on the PIR pin,
it looks like there is coupling from LED into the PIR module circuit.
PIR circuits are kind of slow, so the effect adds a delay in the
feedback loop that results in an oscillation on and off. The
coupling could be electrical from a ground loop, or electromagnetic
from coupling through the air. Or even optical, but I doubt that a
red led would have much if any effect on a PIR sensor.
Are you sure the red led has a built-in resistor? See if putting an
additional 330 ohms in series with the led helps the problem.
Also, try (1) put a bypass capacitor across the PIR sensor power
supply, say 1 to 100 uF. (2) Locate the PIR sensor further from the
Stamp circuit, and even shield it inside a tin can. (3) move the
ground for the PIR as close as possible to pin23 on the stamp.
I hope something in there helps!
-- regards,
Tracy Allen
mailto:tracy@e...
http://www.emesystems.com
>pause
>5.06 all still off
>time.
Do you feed the PIR and the Stamp with the same power supply ?
Then you should place decoupling capacitors, and also check the maximum
current of the power supply. The reset may be caused by the switching of the
PIR.
Hope this helps.
Best regards,
Phil.
Sent: Friday, August 24, 2001 5:02 PM
Subject: [noparse][[/noparse]basicstamps] Re: Stranges BS2 results
> My oops in the "in7" thing and the debug spelling was just a typo.
> removed.
> the problem.
> 5.06 all still off
> 5.06 all still off
> 5.06 all still off
> 5.06 all still off
> the PIR.
> pause
> 5.06 all still off
> Shawn
