Serial LCD Controller Module
Has anyone used the serial LCD Controller Module that is avalable
from www.wirz.com? If so, has it work with a Stamp?
Chris
Chris
you-know-what. Sometimes they come on and work just fine, other times they
interpret a Stamp pin transition at power-up as a command and they go wonky.
*IF* you turn on the whole display after you set your Stamp pin, they will
work fine -- in other words you either need two power switches or a second
Stamp pin and a relay or transistor to switch on the display.
of input from the Stamp can be confused on power up because the Stamp starts
with all inputs. The answer is to use a pull up or pull down resistor to set
the state of the pin to a known state at all times. Then the Stamp can
override that state when needed.
This is something we see all the time with our PAK-Vs. You can jumper them
to expect an RS-232 "space" to high or low. The input has a pull up
resistor, so setting it to high works best. However, if you set it to low,
the chip will "see" a spurious start bit when the Stamp starts (because of
the internal pull up). You just have to correctly pull the pin low or
adequately reset the PAK (which is always a good idea anyway).
Al Williams
AWC
* Control 8 servos at once
http://www.al-williams.com/awce/pak8.htm
> From: Rodent [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=d3kfMoZL7upP9aCPV7EzNdpsLMss7Kohmfo_sxH0FBt3427MDRmvHu8n-XkcleE6iTOWQL1XFdBqcakjNT0]daweasel@s...[/url
> Sent: Wednesday, August 22, 2001 6:13 PM
> Subject: Re: [noparse][[/noparse]basicstamps] Serial LCD Controller Module
> I think thats the same one Marlin P. Jones is selling, and its a piece of
> they go wonky.
> from the same email address that you subscribed. Text in the
the Stamp pin a certain way and use an END statement, then load and run your
normal code, it seems to be a bit more reliable.
> I like the SEETRON units. That being said, any device that expects some
sort
starts
set
of
they
> > they go wonky.
will
second
Stamp in a end mode, the watchdog timer times out every few seconds and this
causes the outputs to "float" for just a split second. The trick there is
not to stop your Stamp program. I think STOP does not do this, but I usually
just write:
halt: goto halt
This consumes power but doesn't wink out like an END. By standard computer
verb conjugation...
I code dynamic halts.
He/she codes endless loops.
Al Williams
AWC
* Floating point math for the Stamp, PIC, SX, or any microcontroller
http://www.al-williams.com/awce/pak1.htm
> From: Rodent [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=oYwv2xojfF0oyO9X0WG0wY0wGO_wswoaqv81oY7cnNatLOKo48DVM8h9RDq8lQXCLlfQ8_RG2q1GTQ]daweasel@s...[/url
> Sent: Wednesday, August 22, 2001 8:57 PM
> Tried it -- doen't seem to work all the time. *IF* you run some
> code to set
> and run your
> sort
> starts
> set
> jumper them
> it to low,
> (because of
> of
> they
> > > they go wonky.
> will
> second
work
> fine -- in other words you either need two power switches or a second Stamp
pin
If you're looking for an economical and reliable serial LCD controller, have a
look at our Econo-LCD kit:
http://www.hvwtech.com/econo-lcd.htm
Mark Hillier, VE6HVW
President, HVW Technologies Inc.
Canadian Distributors of Parallax Products and other Neat Stuff
Tel: (403)-730-8603 Fax: (403)-730-8903
See our NEW BASIC Stamp Prototyping tools !
http://www.hvwtech.com/stampstack.htm
