tokenizing? comand line compilers?
Dear all,
I am currently writing a custom application to interface with the
stamp with Borland builder. My dilemma is that recompilation is
needed often as code segment changes. Does anyone know of a command
line version of stampw.exe to just "tokenize" into an object file so
I can upload into the stamp EEProm? Thanks a bunch.
Derek Woo
Derek Woo
control via the command line. It also allows you to compile to object files so
that you can send a program to a friend/client without revealing your source.
-- Jon Williams
-- Application Engineer, Parallax
this means updates in the field without the client seeing the source code?
(or stampw.exe) as in " Go to my website and download file x and run
it to upgrade to the new version"? ( or some variation of this? )
Dave
Sent: Tuesday, August 21, 2001 7:25 PM
Subject: Re: [noparse][[/noparse]basicstamps] tokenizing? comand line compilers?
> Version 1.2 is nearly ready and will meet your needs. It gives you
complete control via the command line. It also allows you to compile to
object files so that you can send a program to a friend/client without
> -- Jon Williams
samhell@s... writes:
> help me out here,
That's right. The new compiler will create an object file and a separate
loader. Even better, it will create a stand-alone EXE file that is the
loader with your object embedded. The creation of this loader/object lets
you customize it (title, messages, etc.).
You send it to you client, they connect a Stamp-based device to their PC and
run the program.
If you have a group of possibilities, you can send the loader and separate
object files (appropriately named, of course). They run the loader, select
the proper object file and click [noparse][[/noparse]Download].
It's really cool stuff and should be available for release in September.
-- Jon Williams
-- Dallas, TX
PS: The thing I like best about the command line interface is the ability to
use one's favorite programming editor. I'm currently using EditPlus. It
does syntax highlighting (I created a PBASIC syntax file) and allows me to
create toolbar buttons to launch the compiler and the compiler help file. It
will even to a keyword search in the help file if I've highlighted some text
before selecting help. And DEBUG still works when using and external editor.
Our compiler guy (Jeff) has done a great job on this -- it's really good
stuff and I'm confident that Stamp users are really going to like it.
to object files so that you can send a program to a friend/client
> -- Jon Williams
Jon,
It is a relief that you told me there will be a command line compiler
soon. How soon? I am very eager to use it. My application is
basically finished but waiting for the compiler.
had to rethink my algorithm a bit if I couldn't find a command line
compiler. I have searched all over the place! Can you tell me how
soon? or maybe a beta version??
Thanks, Jon and compiler guy !
delboy78@y... writes:
I'm sorry that I can't get it to you any sooner than our normal release date.
It's undergoing testing now and the completion of the help file (my
reponsibility...). Jeff (the compiler guy) has a lot on his shoulders now
and I don't want to burden him with anything else. Hang in there, it will be
worth the wait. September isn't very far away.
-- Jon Williams
release date. It's undergoing testing now and the completion of the
help file (my reponsibility...). Jeff (the compiler guy) has a lot on
his shoulders now and I don't want to burden him with anything else.
Hang in there, it will be worth the wait. September isn't very far away.
> -- Jon Williams
Thanks Jon for letting me know. Is there going to ben news bulletin
on the web site?
Derek.
> on the web site?
Absolutely!
