Visual Basic AHHH!!!! — Parallax Forums
edited 2001-08-21 13:55 in General Discussion
Well I have been expermenting with the Stamp and interfacing it into
a Basic stamp program and I got it working and then expanded the idea
however when I transmit the data the stamp is transmitting the right
number of bytes to my prgram and my program is capturing them all in
my program with no errors. However I'm transmitting three seperate
arrays and the last element of the first two arrays is being
transmitted the same as the first ellement of the next array so A(3)
is showing up as B(0) and B(0) is also B(0). however if I change the
variable I'm transmitting to a constant my program captures it with
no problem. I hope that makes sense I was just wondering If this has
happened to anybody before or if anybody has any suggestions that
might solve this problem
Thank You
Aaron Nielsen
    I'm just guessing, but here's my guess:
    Do you realize that arrays dimensioned to N (in PBasic) range from 0 to N-1.
    However, PBasic doesn't bound check. So... if you have:
    abc var byte(3)
    xyz var byte(3)
    You just created abc(0), abc(1), abc(2) (and the same for xyz). However,
    PBasic will let you say abc(4) but it will probably (depending on how the
    Stamp software lays out your variables) be the same as xyz(0).
    So my guess is, you have statements like the above when you should use "abc
    var byte(4)" which would give you legal subscripts from 0 to 3.
    Good Luck!
    Al Williams
    AWC
    * Connect a PS/2 keyboard to your next Stamp project
    http://www.al-williams.com/awce/pak6.htm
    > From: Aaron [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=1BYEgC3icCVJpvkVShrpELVJu2aAherR9EM0aJ1mhRM2W-YnzM01f5ek25H7bwTqfuIF43xuvJwp8n2T3qFL]snazzyguy2@y...[/url
    > Sent: Tuesday, August 21, 2001 3:09 AM
    > Subject: [noparse][[/noparse]basicstamps] Visual Basic AHHH!!!!
    > Thank You
    > Aaron Nielsen
    > from the same email address that you subscribed. Text in the
