mA to V
For Chris
Run the current through a 1.2K resistor to ground and take the voltage
across the resistor to the ADC.
Sid
Sid
controller to a voltage that I can input to an ADC? I once thought I had
found a single chip solution, but, of course-now that I need it....
Chris
throughout the entire current range....Am I missing something here?
> From: Newzed@a... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=PQymPnxiOmJ4rf0llEggOzesQ22QufzvhSfsGbAsgH_xIAIuBuSNjzmn8rnS9hrGD33pzQ]Newzed@a...[/url
> Sent: Monday, August 20, 2001 3:02 PM
> Subject: Re: [noparse][[/noparse]basicstamps] mA to V
> For Chris
> the voltage
> Sid
> from the same email address that you subscribed. Text in the
Put the controller output through a resistor and read the developed voltage.
Decide
what voltage you'd like to see at 20 ma and divide it by 20 ma. This will
give you the
resistor value that you need.
Carl
> From: Chris Loiacono [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=NMJw2A3fd0bMRcW3daGSRiIl9l-Dc7KC9mwFASWnELdxZcG6C0MLsJzDlI9j7ekD57-lGfjGMik]chris@m...[/url
> Sent: Monday, August 20, 2001 10:05 PM
> To: 'basicstamps@yahoogroups.com'
> Subject: RE: [noparse][[/noparse]basicstamps] mA to V
> Thanks for the idea, however regardless of the resistance,
> these controllers maintain a steady voltage source from the
> minimum to the maximum current output.
> Chris
> > From: carl@g... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=O7lECzyxHkwSopYS-o8UXw4WBDCdtj057KpaTzCfa1c9oPaZtrkU7AU0c4v42r9iVq4Fdwdk]carl@g...[/url
> > Sent: Monday, August 20, 2001 6:38 PM
> > >Does anyone have a reasonable way to convert a 4-20 mA
> > output from a process
> > thought I had
> > developed voltage.
> > Decide
> > ma. This will
> > give you the
> > Carl
That's why you measure the voltage across the resistor.
