Pak 5 vs Pak 8
I am controlling several servos on a RC airplane.
I am looking at using either the PAK-V or PAK-VIII from
www.al-williams.com/awce to control the servos.
Is there any advantage to using the PAK-VIII? It seems that the PAK-V is
simpler to use.
Thanks for any advice in selecting one of these over the other.
simpler to use.
dimming lights and controlling motor speeds, among other things. However, it
won't let you control a servo -- the cycle time is too fast.
The PAK-VIII, on the other hand, lets you set the on and off times easily to
whatever you want. That means you can do what a PAK-V does, but you can also
handle things like servos.
If you'd like an example have a look at
http://www.al-williams.com/awce/servobot.htm
Al Williams
AWC
* Floating point A/D
http://www.al-williams.com/awce/pak9.htm
> From: Alex Sulkowski [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=py9L0A7X5-owg4OK97zrmJzK8BgN4jJajvZiBgsFot3BjWX1KZU6-6MR786iYOSYWneFICOCs3dqCS2C0YzRKwav5iJDMA]asulkowski@a...[/url
> Sent: Friday, August 17, 2001 5:58 PM
> Subject: [noparse][[/noparse]basicstamps] Pak 5 vs Pak 8
> simpler to use.
> from the same email address that you subscribed. Text in the
From: Al Williams [noparse]/noparse]SMTP:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=RVJmWqJ5n_jQqcZl8vTOjHojZVro23KjWVbWb-vurSm67p-d4r-CTgIrtRlFTYtXlAJdAO1BOkOPmg]alw@a...[/url
Sent: Friday, August 17, 2001 7:08 PM
Subject: RE: [noparse][[/noparse]basicstamps] Pak 5 vs Pak 8
The PAK-V generates PWM like the Stamp generates PWM. That is
suitable for
However, it
easily to
can also
> From: Alex Sulkowski [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=OIhouizTM4c2bZvdt_Er7nMZjZugEO81KXD3z0JG9MruwHUrJvZkTOBXmp_ZxNjc_wsNoXKQU5-sHl_BDcD5rsmw6rUH]asulkowski@a...[/url
PAK-V is
> simpler to use.
