Data, Read, & Target variable
I am using a tilt sensor in an automatic leveling application.
My target variable that indicates a level position (90 degrees for the sake
of this argument) is 1780.
if the sensor is at 80 degrees it returns a value of 1710 (-70 from target)
and if the sensor is at 100 degrees it returns 1860 (+70 from target). I
would like to use the difference to control the level correction speed using
a "read / Data" table. Is there a simple way to ignore the sign and just
use the value of the result?
i.e.,
Correction_speed data 50,100,200,500,2000
speed var word
X var word
Get_sensor X (lets just say X =1760)
read correction_speed + (1780-x/10), speed
in this example speed will have the value of the "2" in eeprom (200). But if
my sensor is on the other side of level and returns a value of 1800, the
result will be a negative number.
i.e.,
speed var word
X var word
Get_sensor X (lets just say X =1800)
this time we get a -2
I know there has to be a simple solution for a simple problem. Any help
would be appreciated. Thanks
Jeff
i.e.,
speed var word
X var word
i.e.,
speed var word
X var word
Jeff
y = abs x
the absolute value of x
>i.e.,
>speed var word
>X var word
>i.e.,
>speed var word
>X var word
>Jeff
Thanks Tracy!.
