Palm Vx as a HMI for a basic stamp
I would like to know of applications built with a stamp and a palm
computer
My palm Vx is loaded with hotpaw basic and I have the pin outs
Any suggestions or sources would e helpful
Ideally would like to use the IR for diagnostics of automated mahines
using a stamp as a controller
Regards
Dan C.
computer
Regards
Dan C.
(http://www.wabasoft.com/) which runs on the Palm or CE (or TI calculator,
or MS-DOS, or several other things) and has serial port I/O to talk to a
Stamp.
Once you have serial I/O it is just like any other Stamp program that uses
RS-232.
Al Williams
AWC
* Floating point math for the Stamp, PIC, SX, or any microcontroller
http://www.al-williams.com/awce/pak1.htm
> From: DANCHAND@a... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=ZakHg5W6adv2qzgeep4w96uJW1Dm9_TfBLuSEcZBOtSEe8ISnSYaWGNcteqV2nQ5K72dWiNgfQnHew]DANCHAND@a...[/url
> Sent: Friday, August 17, 2001 5:53 AM
> Subject: [noparse][[/noparse]basicstamps] Palm Vx as a HMI for a basic stamp
> computer
> automated mahines
> Regards
> Dan C.
> from the same email address that you subscribed. Text in the
I've used "Online, VT100 terminal emulator for PalmPilot" from
http://www.markspace.com/online.html
to test and configure my data loggers. Very easy to use.
If you find that you need more power than Hotpaw BASIC interpreter
allows, check out
http://www.nsBASIC.com/palm/
I have a buffered IrDA interface for the stamp posted at
http://www.emesystems.com/IrDA.htm
-- regards,
Tracy Allen
mailto:tracy@e...
>I haven't done anything with your specific setup. However, I have used Waba
>Stamp. Once you have serial I/O it is just like any other Stamp
>program that uses RS-232.
>Regards,
>Al Williams
>AWC
>> From: DANCHAND@a... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=hnu7DXzoD-LJHbCmsOl6WvPQld6tufblzXsyyeAe5oBDELaCTCGTmPWJ6qegYQxT0Ly8C2yuEojCYT4]DANCHAND@a...[/url
>> computer My palm Vx is loaded with hotpaw basic and I have the
>>pin outs Any suggestions or sources would e helpful Ideally would
>>like to use the IR for diagnostics of automated mahines using a
>> Regards
> Dan C.
