Digest Number 796
I have debugged code fragments to set and read the Vector Electronic Compass
if anyone needs it.
Also code fragments to set and read the JVC clock chip.
Jim
Sent: August 15, 2001 4:41 AM
Subject: [noparse][[/noparse]basicstamps] Digest Number 796
> There are 24 messages in this issue.
> Topics in this digest:
> 1. quadravox speech question
> From: "ulibasic" <ulibasic@r...>
> 2. Controlling the LED blinker help!
> From: "Michael Robinson" <mhr_54@h...>
> 3. Re: Re: LDVDT???
> From: "Beau Schwabe" <bschwabe@a...>
> 4. New stamper question
> From: shawnusa@e...
> 5. Re: LDVDT???
> From: iceninevt@y...
> 6. Re: New stamper question
> From: Rodent <daweasel@s...>
> 7. RE: New stamper question
> From: "Al Williams" <alw@a...>
> 8. Re: New stamper question
> 9. RE: New stamper question
> 10. Re: New stamper question
> From: shawnusa@e...
> 11. stamp/pic
> From: "Sean T. Lamont .lost." <lamont@a...>
> 12. Re: stamp/pic
> From: "Philippe Derenne" <derennep@s...>
> 13. RE: stamp/pic
> 14. OT) Net World Interop
> 15. FW: OT) Net World Interop
> From: "Chris Loiacono (E-mail)" <chris01@t...>
> 16. Re: LVDT???
> From: agarb@j...
> 17. Re: Re: LDVDT???
> From: agarb@j...
> 18. Re: LVDT???
> From: agarb@j...
> 19. Re: stamp/pic
> From: "S Parkis" <parkiss@e...>
> 20. Re: Digital Compass
> From: DAVECUSTOM@A...
> 21. Serial LCD
> From: chrisd@w...
> 22. LCD Selection
> From: tbanez@h...
> 23. Re: LCD Selection
> From: Bruce Bates <bvbates@u...>
> 24. RE: LCD Selection
> From: "Daliti" <peter.christiaen@s...>
> ________________________________________________________________________
> Message: 1
> Date: Tue, 14 Aug 2001 12:23:43 +0200
> Subject: quadravox speech question
> Hi Stanpers,
> I got myself a quadravox speech module and a cradle to put wav. files into
> it. Everything works great except:
> How can I manage to play one sound after the other without delay? I picked
> the highest baudrate and tried to create soundfiles with no silence in the
> beginning but there is still almost a second between two sounds...
> What is my mistake or is it just that way?
> Thanx for your help,
> Uli
> [noparse][[/noparse]Non-text portions of this message have been removed]
> Message: 2
> Date: Tue, 14 Aug 2001 10:21:19 -0400
> Subject: Controlling the LED blinker help!
> Dear list,
> Does anyone have the book Programming and Customizing the Basic Stamp
Computer. I need help with page 83, Controlling the LED Blinker. When I turn
the switch on the led blinks, but when I turn it off the LED stays lit 75%
of the time and not lit 25% of the time. I check my circuit wiring and
program and they were both exactly the same as the book. I have a BS2SX on
an activity board with an app module plugged into it containing my circuit.
Please help.
> Sincerely,
> MichaelGet more from the Web. FREE MSN Explorer download :
http://explorer.msn.com
> Message: 3
> Date: Tue, 14 Aug 2001 10:16:49 -0400
> Subject: Re: Re: LDVDT???
> At 07:59 PM 8/13/01 +0000, you wrote:
> >Maybe you are correct, it's just that my "gut" doesn't subscribe to
> >what you suggest. It is difficult for me to accept that the circuit
> >can be made thermally stable in this fashion. Still, I don't discount
> >what you say...
> Refer to the attached URL:
> Since the same oscillator (U1,U2,and C1, plus the LVDT Coils) is used
> for up to 8 LVDT coils then you can bet that all coils will be affected
> equally with temperature, and that any differences could be traced to
> internal propagation delays within U1.
> What the 'LVDT,gif' does require in order to provide compensation
> is a LVDT coil dedicated to do nothing as far as movement, but only
> for a reference. Typically the "reference coil" or "dummy coil"
> would be configured so that the metallic slug would be resting at a
> center position. Your software (within a STAMP or PIC) would simply
> select the appropriate coil and make a percentage comparison. i.e.
> (Pseudo Stamp Code)
> Start:
> read reference LVDT
> read position LVDT
> if reference < position then Loop1
> if reference > position then Loop2
> percent = 0
> goto Done
> Loop1:
> percent = ( reference * 100 ) / position
> goto Done
> Loop2:
> percent = ( position * 100 ) / reference
> percent = percent * -1
> Done:
> debug percent
> goto Start
> >What you suggest is much less parts intensive than the only way I
> >know how to do it. Could you point me somewhere where I may look at
> >the schematic to which you refer? My curiosity certainly has the best
> >of me.
> 3 IC's + a Stamp to read 7 LVDT's
> http://home.earthlink.net/~y2kbc/Electronics/BasicStamp/LVDT.gif
> See also...
> http://home.earthlink.net/~y2kbc/Electronics/BasicStamp/Coilread.gif
> >Thank You,
> >Regards
> >Rich
> >--- In basicstamps@y..., "Beau Schwabe" <bschwabe@a...> wrote:
> > > At 05:34 PM 8/13/01 +0000, you wrote:
> > > >Using a LVDT with only a single secondary winding only simplifies
> > > >things slightly. Placing a second coil in a feedback wont do much
> >to
> > > >keep things stable. The coil is not nearly as cranky about ambient
> > > >temp as a semiconductor junction. Is is for that reason that I
> > > >suggested placing all rectifiers over a common thermal pad.
> > > >Instability comes from these diodes being at different temps.
> > > Agreed, but the circuit that I provided does have temperature issues
> > > not so much with the coils, but within the 74xx14. To compensate
> > > for this you must have a "dummy coil" that is used to compare
> >against
> > > the LVDT coil. i.e.
> > > ( "LVDT coil" * "DeltaTemp" )
> > > Output =
> > > ( "dummy coil" * "DeltaTemp")
> > > can be simplified, eliminating any temperature effects to...
> > > "LVDT coil"
> > > Output =
> > > "dummy coil"
> Beau Schwabe IC Mask Designer
> National Semiconductor Wired Communications Division
> 500 Pinnacle Court, Suite 525 Mail Stop GA1 Norcross, GA 30071
> Message: 4
> Date: Tue, 14 Aug 2001 15:07:00 -0000
> From: shawnusa@e...
> Subject: New stamper question
> I'm fairly new to Basic stamps and electronics in general. I was
> hopping one of you out there might be able to help me out here. I
> have a Passive Infrared motion detector that shows a 5.06 voltage
> constant until movment is detected. When it senses movment the
> voltage drops to below 1 volt. Now from reading, this seems to be
> what is termed active-low. Now my real question . How would I code/
> add components to the stamp to allow me to sense when the PIR sensor
> detects movment? Do I need any resitors or other components? It seems
> to me I should be able to do an If in8=0 then display movment
> detected. Any code examples and or componets required would be
> appricated.
> Thanks for your help
> Shawn
> Message: 5
> Date: Tue, 14 Aug 2001 15:25:07 -0000
> Subject: Re: LDVDT???
> Thank you for sharing this information with me. Informative and
> interesting...
> I can be SOO00oo stubborn sometimes.
> Regards
> Rich AA2DN
> discount
> > >what you say...
> used
> affected
> to
> > (Pseudo Stamp Code)
> > Start:
> > read reference LVDT
> > read position LVDT
> > percent = 0
> > goto Done
> > Loop1:
> > goto Done
> > Loop2:
> > Done:
> > debug percent
> > goto Start
> at
> best
> > >of me.
> > See also...
> > >Thank You,
> > >Regards
> > >Rich
> simplifies
> much
> > >to
> ambient
> issues
> compensate
> > >against
> > > > the LVDT coil. i.e.
> > > > Output =
> > > > "LVDT coil"
> > > > Output =
> > > > "dummy coil"
> Message: 6
> Date: Tue, 14 Aug 2001 10:30:48 -0500
> Subject: Re: New stamper question
> Connect the output of the PIR detector to one of the Stamp ports though
> about a 330 ohm resistor. You don't absolutely need the resistor, but if
you
> screw up and have the port set up as an output it can save the Stamp. Set
> the port up as an input with the DIR = statement, then do the IF statement
> you posted.
> > appricated.
> Message: 7
> Date: Tue, 14 Aug 2001 10:33:02 -0500
> Subject: RE: New stamper question
> That sounds like it should work. All digital devices have some threshold
and
> anything below that threshold is a "0" (except for devices that exhibit
> hysterisis, but that's another story and one that doesn't apply). The
5.06V
> should not bother the Stamp, although a small series resistor would allow
> you to safely handle voltages high enough to trip the Stamp's internal
> protection diodes (5.6V or so).
> Figure a Stamp input can sink 20mA safely. The protection diodes will
clamp
> the input to 5.6V (and -.6V on the other side) more or less. So ohm's law
> can tell us that:
> (Vin-5.6)/.02 = R
> So if the PIR could deliver, for example, 9V would give you an R of 170
> ohms. Under normal operation, this wouldn't be a problem since the Stamp
> inputs draw so little current. Just for a seat of the pants guess, say a
> Stamp input draws 100uA (.0001A) -- it may not even draw that much, but
just
> say that it does. That would result in a 17mV drop in your input voltage.
So
> if the PIR outputs 5.06V, the Stamp would see 5.043V -- no big deal.
> So while you probably don't need a small resistor, it wouldn't hurt to put
> one in and could save you trouble later. Cheap insurance. 170 ohms
probably
> isn't a standard value, but 220 is. That's OK on current because it will
> cause the current to be even lower if the voltage goes too high. And the
> drop at 100uA is only 22mV -- still a drop in the bucket (no pun
intended).
> You might also want to consider software averaging, filtering, and
> hysterisis to ignore fast noise.
> For example:
> No filter:
> if in8=0 then motion_on
> Example raw filter:
> waitmo:
> filter=0
> waitmo1:
> if in8=1 then waitmo
> filter=filter+1
> if filter<5 then waitmo1 ' wait for 5 hits in a row
> Good luck!
> Al Williams
> AWC
> * Floating point math for the Stamp, PIC, SX, or any microcontroller
> http://www.al-williams.com/awce/pak1.htm
> > From: shawnusa@e... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=KFaVer5h_83XvSetYqtbL0NOU8NA8stIFgPqImEfx7vdgFgZm9__MctLUzfbmcZxCzJciYEgEAZe]shawnusa@e...[/url
> > Sent: Tuesday, August 14, 2001 10:07 AM
> > To: basicstamps@yahoogroups.com
> > Subject: [noparse][[/noparse]basicstamps] New stamper question
> > appricated.
> > Shawn
> > Subject and Body of the message will be ignored.
> > Your use of Yahoo! Groups is subject to
> Message: 8
> Date: Tue, 14 Aug 2001 13:20:37 -0400
> I would probably use a much higher value resistor, say 4.7K
> With a 330 Ohm resistor you 'might' if the stamp pin
> is at anytime an output and at a logic state opposite the
> PIR, see 15.3mA of surge current. This in my opinion is much
> to close to the nominal 20mA/25mA capabilities of the Stamp.
> With a 4.7K resistor the current is adequate to drive
> the stamp in input mode, and also remains safe if the stamp
> pin was to be placed in output mode.
you
statement
> >you posted.
> > > appricated.
> Message: 9
> Date: Tue, 14 Aug 2001 13:02:45 -0500
> Yes, that's true if you might ever put the input mode into an output
state.
> Although you'd hope something like that would be transient and 15.3mA is
> still within the letter of the law.
> I had said 220 which will allow even higher current to flow (5/220) but I
> was really thinking about high voltage from the PIR not reversed Stamp
pins.
> From all the discussion, you might think a bigger resistor is better, so
> just use a bigger resistor (and I know you know this Beau, but for the
> lurkers). To a point this is OK, with two limiting cases. As we've
> discussed, the higher resistance drops more input voltage. At some point
you
> drop below threshold. The second problem occurs with short pulses and/or
> long lines. Interconnections have capacitance and adding resistance makes
an
> RC circuit. This can do bad things to your inputs if they are short
pulses.
> Just something to think about.
> Anyway, that's a good point since the Stamp's pins can go either way.
> Al Williams
> AWC
> * Measure 8 pulses at once
> http://www.al-williams.com/awce/pak7.htm
> > From: Beau Schwabe [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=2eS7NjWpzddE5OmmQtwd09tpB8C2ZXhbqUpxHhc7piGE_3eLIqj1VvJ8uf0FaeBdKj3RZwuLpjuZoBZG-OpiZ4wjOw]bschwabe@a...[/url
> > Sent: Tuesday, August 14, 2001 12:21 PM
> > Subject: Re: [noparse][[/noparse]basicstamps] New stamper question
> > resistor, but if you
Set
> > statement
> > >you posted.
seems
> > > > appricated.
> Message: 10
> Date: Tue, 14 Aug 2001 19:19:41 -0000
> From: shawnusa@e...
> Thanks Guys for the help. It works like a charm. Now all I have to do
> is figure a way to pan a r/c servo to look in the right direction of
> the detected PIR unit. I plan to have 6 pir units and one r/c servo
> with a CCD cammera attached on it. When a PIR is activated the servo
> will turn to that general direction and with a Heat sensor try and
> track the movment with the servo. It's going to take me awhile to
> figure out how to code the PIR with the Servo movment. Anyway thanks
> for your help and any recommendations are welcome on my project.
> Shawn
> output state.
> 15.3mA is
> but I
> Stamp pins.
> better, so
> the
> point you
> and/or
> makes an
> pulses.
> way.
> > Al Williams
> > AWC
> > > From: Beau Schwabe [noparse][[/noparse]mailto:bschwabe@a...]
> > > To: basicstamps@y...
> though
> Stamp. Set
> > > statement
> > > >you posted.
> was
> here. I
> voltage
> to be
> code/
> sensor
> It seems
> > > > > appricated.
> > > basicstamps-unsubscribe@y...
> Message: 11
> Date: Tue, 14 Aug 2001 12:48:07 -0700 (PDT)
> Subject: stamp/pic
> This might be an odd question, but has anyone built a pic programmer out
> of a stamp?
> Sean T. Lamont, CTO / Chief NetNerd, Abstract Software, Inc. (ServNet)
> Seattle - Bellingham - Vancouver - Portland - Everett - Tacoma - Bremerton
> email: lamont@a... WWW: http://www.serv.net
> "...There's no moral, it's just a lot of stuff that happens". - H. Simpson
> Message: 12
> Date: Tue, 14 Aug 2001 22:16:09 +0200
> Subject: Re: stamp/pic
> Hi Sean,
> Depends on which model you want to use, and if you have a PC. I use a
(very
> !) simple programmer hooked to a serial port (no need to supply external
> voltage !) to program the 16F84. I think this model is useful for simple
> applications. It works perfectly.
> Let me know if you need more info.
> Best regards,
> Phil.
> > of a stamp?
Bremerton
Simpson
> Message: 13
> Date: Tue, 14 Aug 2001 15:42:10 -0500
> Subject: RE: stamp/pic
> Have a look at our APP-I which is exactly that. You can get the kit, or
you
> can find the schematics and software in my Stamp Book (the parts are easy
> enough to find). You either need a Vpp supply or a good enough serial port
> to supply 12V.
> http://www.al-williams.com/awce/app1.htm
> and
> http://www.al-williams.com/awce/sbook.htm
> Al Williams
> AWC
> * Floating point A/D
> http://www.al-williams.com/awce/pak9.htm
> > From: Sean T. Lamont .lost. [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=uMWNB6oycavYdQJ7ILb8_7kMJ7-1ohrH5NhfEGE9srml_lB7b0nl24hjBHdShmXxhiMM09BcVpdB4Ez-rmXG3jA]lamont@a...[/url
> > Sent: Tuesday, August 14, 2001 2:48 PM
> > Subject: [noparse][[/noparse]basicstamps] stamp/pic
> > of a stamp?
Bremerton
Simpson
> Message: 14
> Date: Tue, 14 Aug 2001 17:30:23 -0400
> Subject: OT) Net World Interop
> Anyone on the list attending the Net World Interop 2001 in Atlanta, GA
> September 9-14 ??
> http://www.key3media.com/interop/
> Message: 15
> Date: Tue, 14 Aug 2001 18:12:28 -0400
> Subject: FW: OT) Net World Interop
> > From: Chris Loiacono [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=57zEXefK32YngcYWQbeck96_GO6O1uHLKCr5ObjmTiZoyYdbq8GKFHPh6tEBF6Ci4EFu0HrvOmAJhqg]cl1a@e...[/urlOn Behalf Of Chris
> > Loiacono (E-mail)
> > Sent: Tuesday, August 14, 2001 6:04 PM
> > To: 'basicstamps@yahoogroups.com'
> > Subject: RE: [noparse][[/noparse]basicstamps] OT) Net World Interop
> > I'm thinking that I will if my schedule permits....
> > Chris
> > > Sent: Tuesday, August 14, 2001 5:30 PM
> > > Subject: [noparse][[/noparse]basicstamps] OT) Net World Interop
> > Atlanta, GA
> > > September 9-14 ??
> Message: 16
> Date: Mon, 13 Aug 2001 20:52:32 -0400
> From: agarb@j...
> Subject: Re: LVDT???
> > The Red Lion meters also have RS-422 output, so I could
> > link all 3 meters up (Burial, Pitch & Roll) & send the data through an
> RS-232
> > converter into a notebook. The notebook logged all the parameters
> > and was also interfaced into a GPS to cross-reference the above data
> > with position.
> Sounds like a cool project!
> Message: 17
> Date: Mon, 13 Aug 2001 20:57:40 -0400
> From: agarb@j...
> Beau,
> Thanks for the info, I'll see if I can give it a try.
> Regards,
> Aaron
OLD article begins below this line
> > You can make a very simple "sensitive" LVDT with a resolution
> > greater than
> > 1/2000th of an inch using a BS1 or BS2, 74HC14 or 74HCT14, and
> > 4040B. For
> > more than one, in addition you can use a 4051B for up to eight
> > LVDT's
> > LVDT- #40 AGW enamled copper wire wound around a
> > "Coffie-Straw(single tube)",
> > closely wound with at least 1 inch coil width. (width =
> > travel length)
> > Vcc(+5V reg)
> > o
o->Vcc(+5V reg)
> > o---> LVDT <---o | | |
> > | | 14| |16 ---
> > | | | o
o
o --- .1uF
> > | 1|\ 2 | 3|\| 4 10| | |
> > o
| \o----o----| \o
| 4040 B |--o-> GND
> > | |/| |/ | |8,11
> > --- 7| o
o
o
> > --- .01uF | |Output *
> > | ZTR* | |
> > | | o--->Stamp Pin#
> > o
o---->GND
> > ZTR* - Zero Temperature Response
> > 4040B - "Pin Outs"
> > Output* : pin 9 - divide by 2
> > pin 7 - divide by 4
> > pin 6 - divide by 8
> > pin 5 - divide by 16
> > pin 3 - divide by 32
> > pin 2 - divide by 64
> > pin 4 - divide by 128
> > pin 13 - divide by 256
> > pin 12 - divide by 512
> > pin 14 - divide by 1024
> > pin 15 - divide by 2048
> > pin 1 - divide by 4096
> > This position can "Vary" depending on the sensitivity
> > that
> > you desire. The greater the division, the greater the
> > sensitivity, however the "sample time" increases also
> > with
> > greater division factors when using the PULSIN function.
> > You can use the COUNT function with the BS2 instead for
> > an even better resolution, but you loose the
> > compatability
> > between the BS1 and BS2.
> > EXAMPLE CODE:
> > LVDT var word
> > Start:
> > PULSIN Pin#,0,LVDT 'or COUNT Pin#,Duration,LVDT
> > debug home,? LVDT
> > goto Start
> > DIRECTIONS:
> > Use a piece of "Coat-Hanger-Wire" to slide in and out of the STRAW.
> > Beau Schwabe
> > bschwabe@i...
OLD article stops above this line
> > After reading this, I would ignore the references to the COUNT
> > command, and just stick with the PULSIN command.
> Message: 18
> Date: Mon, 13 Aug 2001 21:00:20 -0400
> From: agarb@j...
> Thanks to all who provided insight into LVDTs. I am currently
> investigating/digesting all the info as well as pursuing some other
> options as suggested...
> Regards,
> Aaron
> On Sat, 11 Aug 2001 20:16:12 -0400 "Leroy Hall, Senior" <leroy@f...>
> writes:
> > I did a search on LVDT at www.goolge.com and found this. Hope it
> > helps..
> > http://www.rdpelectrosense.com/displacement/lvdt/lvdt-principles.htm
> > Understand about the customer being right <GRIN> yep it's a fact!
> > I am
> > sure that range is available see above link. They make interface
> > units
> > for their LVDT's as well. I would need to see the application to
> > determine what would be a good solution to the 'clamp at different
> > heights problem'. Is the air cylinder doing positioning or the
> > heights
> > determined by the part and the cylinder is just clamping it at it's
> > height?
> > Yes, Loveland is near Dayton!!
> > Hope this helps,
> > Leroy
> > agarb@j... wrote:
> > > Leroy,
> > > Thanks for the input. We would prefer to use multiple proximity
> > > switches... but the customer is always right (unless we can
> > convince them
> > > of a better solution)!
> > > Let me explain the application a bit more. The cylinder is to be
> > used to
> > > clamp three types of parts -- all of different heights. The
> > customer
> > > doesn't want to have to set the machine up for each individual
> > part and
> > > suggested an LVDT for automatic part recognition. I guess I need
> > to talk
> > > to our mechanical guy to find out the range in part heights. I am
> > > guessing about 2 inches of the overall stroke is all we would
> > really be
> > > concerned about. Is this doable? How much range does a typical
> > LVDT
> > > have? 1/2, 1, 3, 10 inches?
> > > When you say 'sophisticated electronics' are needed to interface
> > to a
> > > stamp, I assume its is not as easy as feeding an analog signal
> > into an
> > > A/D converter?
> > > Regards,
> > > Aaron
> > > PS: Isn't Loveland around Cincinnati? I am in Dayton.
> > > On Sat, 11 Aug 2001 15:24:06 -0400 "Leroy Hall, Senior"
> > <leroy@f...>
> > > writes:
> > > > An LVDT is used to measure very small distances on machine
> > tools.
> > > > They can sense distances in the tenths of one thousand of an
> > inch.
> > > Some
> > > > perspective here. A human hair is usually somewhere around 3
> > > > thousands (.003) This device could measure them like you would
> > use a
> > > tape
> > > > measure on a room. They would be very difficult, with out some
> > pretty
> > > > sophisticated electronics, to interface with the stamp. What I
> > > > would suggest is Proximity switch for your stated application.
> > They
> > > are
> > > > often used they and are much cheaper. Easier to interface too,
> > as they
> > > > usually provide a logic 24 VDC or 120 VAC output signal that
> > would
> > > > be easy to interface to the stamp.
> > > > BTW air cylinders are not usually sensed as to position. Air is
> > > > compressible and sensing position on this type of device would
> > be
> > > > very difficult. Depending on resolution required, several prox
> > > switches
> > > > might be used. Air cylinders typically are sensed at either end
> > of
> > > > their stroke.
> > * Leroy Hall *
> > * 317 Cherokee Drive *
> > * Loveland, Ohio - USA 45140-2404 *
> > * Phone: (513) 697-7539 *
> > * Cell : (513) 300-8632 *
> > * Email: leroy@f... *
> > * Home page URL: http://home.fuse.net/leroy/ *
> > * Resume URL: http://home.fuse.net/leroy/resume.htm *
> > * Leroy Hall *
> Message: 19
> Date: Tue, 14 Aug 2001 16:49:48 +0800
> I've no doubt Al's and Phillipe's solutions work well. But you can
> in fact "build" a PIC programmer with your Stamp alone if you use a
> PIC in the low-voltage programming series such as the PIC16F877. A
> simple Stamp program is all that's needed to impement the programming
> protocol and twiddle the PIC pins to load the program. With a little
> more hardware you could switch the higher programming voltages needed
> by conventional PICs.
> Loading a useful PIC program with this approach is a little more
> complicated. Nearly every PIC programmer ever made uses a
> disk-resident .hex file (the output from your assembler/compiler) as
> input for the PIC programming per se. Until somebody figures out
> how to get a Stamp to read a disk file directly, you have to
> download the .hex file from the PC to the PIC via the Stamp.
> This isn't the most user-friendly or elegant approach, but lets you
> try your hand at PIC programming using stuff you probably already
> have if you're a member of this group: a Stamp and a PC.
> Regards,
> Steve
> Message: 20
> Date: Tue, 14 Aug 2001 20:22:35 EDT
> Subject: Re: Digital Compass
> I have been working with KVH Electronic compasses. Feel free to contact
me
> for more info.
> Dave
> Message: 21
> Date: Wed, 15 Aug 2001 00:53:31 -0000
> From: chrisd@w...
> Subject: Serial LCD
> I'm looking to use a stamp to read data from a serial interface then
> print parts of that data on a 4x16 serial LCD screen. Which stamp
> would be best for this project? I was looking at the II and the IIp.
> Chris
> Message: 22
> Date: Wed, 15 Aug 2001 06:36:06 -0000
> From: tbanez@h...
> Subject: LCD Selection
> Hey everyone,
> I'm working on a project right now which monitors bearing
> temperatures, oil pressure, and air pressure on a piece of equipment,
> and if all conditions are satisfied will pick up a permissive relay
> which will allow the machine to run.
> I'd like to display all of this information to the user on a screen so
> if there is a problem he/she can see immediately what is going on with
> the system.
> Problem is, I have about 12 different variables I'd like displayed to
> the user and the LCD's I've come across such as those by Scott Edwards
> (http://www.seetron.com) don't seem like they will be big enough to
> fit all I want to on one screen.
> I was wondering if anyone out there had interfaced a stamp to a larger
> LCD or knows of a supplier for larger LCD's. LCD's that are as easy
> to interface as Scott Edwards' are would be ideal. Probably don't
> need anything as big as a 15" computer monitor LCD but maybe 6" or so
> diagonal would be nice.
> By the way, I have thought about using a button or something to switch
> between screens but I would prefer to have it all on one screen.
> Thanks in advance!
> Message: 23
> Date: Wed, 15 Aug 2001 02:57:14 -0400
> Subject: Re: LCD Selection
> At 8/15/2001 Wednesday 02:36 AM, tbanez@h... promulgated:
> >Hey everyone,
> >the system.
> >Thanks in advance!
> If a 2 x 40 (2 lines x 40 characters per line) will fit your needs, you
can
> find
> them surplus at the Marlin P. Jones Web Site http://www.mpja.com using
stock
> number 11287 OP or hit the LCD Display Button on the Home Page. It's a
nice
> Densitron unit for $ 12.95 US and it should be Stamp compatible, although
> perhaps not as neatly as the SEETRON Unit. New 4 x 40 units should also be
> readily available from many sources including Densitron.
> Regards,
> Bruce Bates
> Message: 24
> Date: Wed, 15 Aug 2001 10:06:17 +0200
> Subject: RE: LCD Selection
> Look at http://www.controlanything.com/html/newdisplay.htm
> BTW, isn't it possible to use a Stamp only to control serial a less
> expensive parallel LCD display and if possible with sort of an EPROM
> connected to store some predefined words or graphics and another Stamp to
> control the process?
> Something like this http://www.controlanything.com/html/lcda128.htm but
they
> don't produce it anymore. I found it anyway a good product. I think it
must
> be possible to do the same thing with a additional Stamp.
> Peter
> Belgium
Oorspronkelijk bericht
> Van: tbanez@h... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=HrbPv5ON5OYbctgzJJeH2-gnY68W1baIqfdWuQYced0EoP7ZvvETAAmYqWxAL0vku094PgSqlsyViHAb]tbanez@h...[/url
> Verzonden: woensdag 15 augustus 2001 8:36
> Aan: basicstamps@yahoogroups.com
> Onderwerp: [noparse][[/noparse]basicstamps] LCD Selection
> the system.
if anyone needs it.
Jim
> 3. Re: Re: LDVDT???
> From: shawnusa@e...
> 5. Re: LDVDT???
> From: shawnusa@e...
> 11. stamp/pic
> 12. Re: stamp/pic
> 13. RE: stamp/pic
> 16. Re: LVDT???
> From: agarb@j...
> From: agarb@j...
> 18. Re: LVDT???
> From: agarb@j...
> 19. Re: stamp/pic
> 21. Serial LCD
> From: chrisd@w...
> 22. LCD Selection
> From: tbanez@h...
> Message: 1
> Hi Stanpers,
> Uli
> Message: 2
> Dear list,
Please help.
> Sincerely,
> Message: 3
> >what you say...
> (Pseudo Stamp Code)
> Start:
> read reference LVDT
> read position LVDT
> percent = 0
> goto Done
> Loop1:
> goto Done
> Loop2:
> Done:
> debug percent
> goto Start
> >of me.
> See also...
> >Thank You,
> >Regards
> >Rich
> >to
> >against
> > > the LVDT coil. i.e.
> > > Output =
> > > "LVDT coil"
> > > Output =
> > > "dummy coil"
> Message: 4
> From: shawnusa@e...
> appricated.
> Shawn
> Message: 5
> interesting...
> Regards
> Rich AA2DN
> discount
> > >what you say...
> used
> affected
> to
> > (Pseudo Stamp Code)
> > Start:
> > read reference LVDT
> > read position LVDT
> > percent = 0
> > goto Done
> > Loop1:
> > goto Done
> > Loop2:
> > Done:
> > debug percent
> > goto Start
> at
> best
> > >of me.
> > See also...
> > >Thank You,
> > >Regards
> > >Rich
> simplifies
> much
> > >to
> ambient
> issues
> compensate
> > >against
> > > > the LVDT coil. i.e.
> > > > Output =
> > > > "LVDT coil"
> > > > Output =
> > > > "dummy coil"
> Message: 6
you
> you posted.
> > appricated.
> Message: 7
and
5.06V
clamp
> can tell us that:
> (Vin-5.6)/.02 = R
just
So
probably
intended).
> For example:
> No filter:
> Example raw filter:
> waitmo:
> filter=0
> waitmo1:
> filter=filter+1
> Good luck!
> Al Williams
> AWC
> > appricated.
> > Shawn
> Message: 8
you
statement
> >you posted.
> > > appricated.
> Message: 9
state.
pins.
you
an
pulses.
> Al Williams
> AWC
Set
> > statement
> > >you posted.
seems
> > > > appricated.
> Message: 10
> From: shawnusa@e...
> Shawn
> output state.
> 15.3mA is
> but I
> Stamp pins.
> better, so
> the
> point you
> and/or
> makes an
> pulses.
> way.
> > Al Williams
> > AWC
> though
> Stamp. Set
> > > statement
> > > >you posted.
> was
> here. I
> voltage
> to be
> code/
> sensor
> It seems
> > > > > appricated.
> Message: 11
> Subject: stamp/pic
> of a stamp?
> Message: 12
> Hi Sean,
(very
> Best regards,
> Phil.
> > of a stamp?
Bremerton
Simpson
> Message: 13
you
> to supply 12V.
> and
> Al Williams
> AWC
> > of a stamp?
Bremerton
Simpson
> Message: 14
> September 9-14 ??
> Message: 15
> > Loiacono (E-mail)
> > Chris
> > Atlanta, GA
> > > September 9-14 ??
> Message: 16
> From: agarb@j...
> RS-232
> > with position.
> Message: 17
> From: agarb@j...
> Beau,
> Regards,
> Aaron
> > greater than
> > 4040B. For
> > LVDT's
> > travel length)
> > Vcc(+5V reg)
> > o
o->Vcc(+5V reg)
> > | | 14| |16 ---
> > | | | o
o
o --- .1uF
> > o
| \o----o----| \o
| 4040 B |--o-> GND
> > | |/| |/ | |8,11
> > --- 7| o
o
o
> > | ZTR* | |
> > | | o--->Stamp Pin#
> > o
o---->GND
> > 4040B - "Pin Outs"
> > pin 7 - divide by 4
> > pin 6 - divide by 8
> > that
> > with
> > compatability
> > EXAMPLE CODE:
> > LVDT var word
> > Start:
> > debug home,? LVDT
> > goto Start
> > DIRECTIONS:
> > Beau Schwabe
> > bschwabe@i...
> Message: 18
> From: agarb@j...
> Regards,
> Aaron
> writes:
> > helps..
> > I am
> > units
> > heights
> > height?
> > Hope this helps,
> > Leroy
> > agarb@j... wrote:
> > > Leroy,
> > convince them
> > used to
> > customer
> > part and
> > to talk
> > really be
> > LVDT
> > to a
> > into an
> > > A/D converter?
> > > Regards,
> > > Aaron
> > <leroy@f...>
> > > writes:
> > tools.
> > inch.
> > > Some
> > use a
> > > tape
> > pretty
> > They
> > > are
> > as they
> > would
> > be
> > > switches
> > of
> > > > their stroke.
> > * Leroy Hall *
> > * Leroy Hall *
> Message: 19
> Regards,
> Steve
> Message: 20
me
> for more info.
> Dave
> Message: 21
> From: chrisd@w...
> Subject: Serial LCD
> Chris
> Message: 22
> From: tbanez@h...
> Hey everyone,
> the system.
> Thanks in advance!
> Message: 23
> >Hey everyone,
> >the system.
> >Thanks in advance!
can
> find
stock
nice
> Regards,
> Bruce Bates
> Message: 24
they
must
> Peter
> Belgium
> the system.
