New stamper question
I'm fairly new to Basic stamps and electronics in general. I was
hopping one of you out there might be able to help me out here. I
have a Passive Infrared motion detector that shows a 5.06 voltage
constant until movment is detected. When it senses movment the
voltage drops to below 1 volt. Now from reading, this seems to be
what is termed active-low. Now my real question . How would I code/
add components to the stamp to allow me to sense when the PIR sensor
detects movment? Do I need any resitors or other components? It seems
to me I should be able to do an If in8=0 then display movment
detected. Any code examples and or componets required would be
appricated.
Thanks for your help
Shawn
appricated.
Shawn
about a 330 ohm resistor. You don't absolutely need the resistor, but if you
screw up and have the port set up as an output it can save the Stamp. Set
the port up as an input with the DIR = statement, then do the IF statement
you posted.
> appricated.
anything below that threshold is a "0" (except for devices that exhibit
hysterisis, but that's another story and one that doesn't apply). The 5.06V
should not bother the Stamp, although a small series resistor would allow
you to safely handle voltages high enough to trip the Stamp's internal
protection diodes (5.6V or so).
Figure a Stamp input can sink 20mA safely. The protection diodes will clamp
the input to 5.6V (and -.6V on the other side) more or less. So ohm's law
can tell us that:
(Vin-5.6)/.02 = R
So if the PIR could deliver, for example, 9V would give you an R of 170
ohms. Under normal operation, this wouldn't be a problem since the Stamp
inputs draw so little current. Just for a seat of the pants guess, say a
Stamp input draws 100uA (.0001A) -- it may not even draw that much, but just
say that it does. That would result in a 17mV drop in your input voltage. So
if the PIR outputs 5.06V, the Stamp would see 5.043V -- no big deal.
So while you probably don't need a small resistor, it wouldn't hurt to put
one in and could save you trouble later. Cheap insurance. 170 ohms probably
isn't a standard value, but 220 is. That's OK on current because it will
cause the current to be even lower if the voltage goes too high. And the
drop at 100uA is only 22mV -- still a drop in the bucket (no pun intended).
You might also want to consider software averaging, filtering, and
hysterisis to ignore fast noise.
For example:
No filter:
if in8=0 then motion_on
Example raw filter:
waitmo:
filter=0
waitmo1:
if in8=1 then waitmo
filter=filter+1
if filter<5 then waitmo1 ' wait for 5 hits in a row
Good luck!
Al Williams
AWC
* Floating point math for the Stamp, PIC, SX, or any microcontroller
http://www.al-williams.com/awce/pak1.htm
> From: shawnusa@e... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=LaNvFWEYnglxOkQLeU6FWyFaMXs5X6w4rwR_paQwWJznDsBhf9BtLkpHQpGFURMGYfHHa3W_E4bmGQ]shawnusa@e...[/url
> Sent: Tuesday, August 14, 2001 10:07 AM
> Subject: [noparse][[/noparse]basicstamps] New stamper question
> appricated.
> Shawn
> from the same email address that you subscribed. Text in the
With a 330 Ohm resistor you 'might' if the stamp pin
is at anytime an output and at a logic state opposite the
PIR, see 15.3mA of surge current. This in my opinion is much
to close to the nominal 20mA/25mA capabilities of the Stamp.
With a 4.7K resistor the current is adequate to drive
the stamp in input mode, and also remains safe if the stamp
pin was to be placed in output mode.
>Connect the output of the PIR detector to one of the Stamp ports though
>you posted.
> > appricated.
Beau Schwabe IC Mask Designer
National Semiconductor Wired Communications Division
500 Pinnacle Court, Suite 525 Mail Stop GA1 Norcross, GA 30071
Although you'd hope something like that would be transient and 15.3mA is
still within the letter of the law.
I had said 220 which will allow even higher current to flow (5/220) but I
was really thinking about high voltage from the PIR not reversed Stamp pins.
From all the discussion, you might think a bigger resistor is better, so
just use a bigger resistor (and I know you know this Beau, but for the
lurkers). To a point this is OK, with two limiting cases. As we've
discussed, the higher resistance drops more input voltage. At some point you
drop below threshold. The second problem occurs with short pulses and/or
long lines. Interconnections have capacitance and adding resistance makes an
RC circuit. This can do bad things to your inputs if they are short pulses.
Just something to think about.
Anyway, that's a good point since the Stamp's pins can go either way.
Al Williams
AWC
* Measure 8 pulses at once
http://www.al-williams.com/awce/pak7.htm
> From: Beau Schwabe [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=t-AVdpkX6wlwrGmarDKmsPRKaHxQNwsumnbQh_uH_Kx5vkts-7FRCgKMI7q_j_Q-uMJkgpdrqICe5DBlga9xag]bschwabe@a...[/url
> Sent: Tuesday, August 14, 2001 12:21 PM
> Subject: Re: [noparse][[/noparse]basicstamps] New stamper question
> I would probably use a much higher value resistor, say 4.7K
> statement
> >you posted.
> > > appricated.
is figure a way to pan a r/c servo to look in the right direction of
the detected PIR unit. I plan to have 6 pir units and one r/c servo
with a CCD cammera attached on it. When a PIR is activated the servo
will turn to that general direction and with a Heat sensor try and
track the movment with the servo. It's going to take me awhile to
figure out how to code the PIR with the Servo movment. Anyway thanks
for your help and any recommendations are welcome on my project.
Shawn
--- In basicstamps@y..., "Al Williams" <alw@a...> wrote:
> Yes, that's true if you might ever put the input mode into an
output state.
15.3mA is
but I
Stamp pins.
better, so
the
point you
and/or
makes an
pulses.
way.
> Al Williams
> AWC
> > From: Beau Schwabe [noparse][[/noparse]mailto:bschwabe@a...]
> > To: basicstamps@y...
though
Stamp. Set
> > statement
> > >you posted.
was
here. I
voltage
to be
code/
sensor
It seems
> > > > appricated.
> > basicstamps-unsubscribe@y...
