Help with Puppy-Bot
I would like to build a Puppy-Bot. It would be a fairly small bot
about 12 inches in diameter, low speed (~1mph), high ground clearance
and have obstacle avoidance ( via Sharp GP2Y0D02 & GP2D15 ).
I would like the puppy-bot to follow the `owner' around like a
happy puppy. It would need to be able to detect when the person is
too far away and move in the direction of the `owner'. It would also
need to be able to detect when it is close enough and quit chasing
the `owner'.
Now here is where I need some assistance.
How can I determine if the `owner' is out of a specified range?
(plus/minus several feet)
How can I determine if the bot is close enough?
How can I determine the direction?
If the owner carries a small transmitter the puppy-bot could use
a form of Radio Direction finding, but then Range (Max & Min) is
tough to do. If I rely on signal strength, then depending on what
side of the `owner' the transmitter is relative to the puppy-bot, the
signal strength would vary greatly.
Is this possible?
Any and all ideas gratefully accepted,
Phil
the `owner'.
Is this possible?
Phil
detector and detune it so anything less reflective does not trigger it.
> the `owner'.
