Basic Stamp BS2sx replace by a normal SX28 in circuit ?
I would like to have information.
I made a circuit with a BASIC STAMP BS2SX in version DIP (not in CMS).
I program my circuit via a SB9-rs232 catch, and all the transistors and
resistances described on the diagram of the BS2SX version CMS are integrated
in the circuit.
The circuit run very well.
My question is:
Can I replace the BS2SX by a simple SX28, not preprogramme in BASIC, and use
a normal compileur ASM for loading this circuit ?
In did other term, I build a universal programmer of SX28 by building the
diagram of the BS2SX ?
John john
France
in the circuit.
My question is:
John john
France
If I understand you correctly, the answer is no. The BS2SX has firmware on
it that contains the Parallax Basic. You can buy these chips from Parallax,
but they contain the Parallax software.
Your software, however, goes into the EEPROM that is separate from the SX
processor. This is what you are programming when you burn your Stamp
program.
It is possible to program an SX directly, and Parallax makes a SX-Key which
is very nice since you can single step your code, watch registers, but it is
all assembly language programming. However, it isn't terribly difficult to
write in assembly and the benefits are great. However, it is more complex
than coding in PBasic.
Hope that helps.
Al Williams
AWC
* Connect a PS/2 keyboard to your next Stamp project
http://www.al-williams.com/awce/pak6.htm
> From: Jean.Marchaudon [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=yRVQaeBO5-D6bsGflvtV9J4dUy6sV_d7a92HmfriV343HAspFfPXi_UieIAuVTPN1tqQBCmnKK0MS8V4x60itWdq5sE]jean.Marchaudon@w...[/url
> Sent: Friday, August 10, 2001 2:08 PM
> Subject: [noparse][[/noparse]basicstamps] Basic Stamp BS2sx replace by a normal SX28 in
> circuit ?
> Hi,
> integrated
> in the circuit.
> My question is:
> BASIC, and use
> John john
> France
> from the same email address that you subscribed. Text in the
I discovered a compiler named JAL which makes it possible to simplify the
writing out of assembler.
From a kind of Visual BASIC, JAL makes a file ASM, and WISP charges it in
the SX28.
As I have already the circuit to program the BS2SX (which uses PORT RA3 and
RA4 of the BS2SX), couldn't it charge a source ASM via this diagram with a
compiler with this type ?
jj
Sent: Friday, August 10, 2001 9:22 PM
Subject: RE: [noparse][[/noparse]basicstamps] Basic Stamp BS2sx replace by a normal SX28 in
circuit ?
> Hi John,
Parallax,
> program.
which
is
> Hope that helps.
> Al Williams
> AWC
> > From: Jean.Marchaudon [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=wrQOnoJNse2AWKNSlCG295rhFM6D0VhkjOTp0JGmMmTxKTzPf3KmiNEHgC2Z7tRSMSfnR4aan6NHGzoBLymEquZFxPgE]jean.Marchaudon@w...[/url
> > circuit ?
> > Hi,
> > integrated
> > in the circuit.
> > My question is:
> > BASIC, and use
the
> > John john
> > France
an SX requires a special programmer that connects to OSC1 and OSC2 of the
SX, not RA3/RA4. The Stamp "programming" is really causing the program in
the SX to put your program in the external EEPROM chip. So you don't really
have an SX programmer.
I mentioned the SXKey. If you don't care about debugging, the SXBlitz from
Parallax is very inexpensive.
Al Williams
AWC
* Floating point A/D
http://www.al-williams.com/awce/pak9.htm
> From: Jean.Marchaudon [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=3q9T_byl38tS1QkZx8eTlDYyHqlOZmqK2v9bJASO3676zO_RGhF8v26H2VDi2LHODnGUmdpqjeB9NmnsHgGAD5IO2QTB]jean.Marchaudon@w...[/url
> Sent: Friday, August 10, 2001 2:43 PM
> Subject: Re: [noparse][[/noparse]basicstamps] Basic Stamp BS2sx replace by a normal SX28 in
> circuit ?
> Thank you for your answer Al,
> the SX28.
> PORT RA3 and
> jj
> From: "Al Williams" <alw@a...>
> circuit ?
> > Hi John,
> firmware on
> Parallax,
> from the SX
> > program.
> which
> registers, but it
> is
> difficult to
> more complex
> > Hope that helps.
> > Al Williams
> > AWC
> > > circuit ?
> > > Hi,
> transistors and
> > > integrated
> > > in the circuit.
> > > My question is:
> > > BASIC, and use
> the
> > > John john
> > > France
> Subject and
jj
Sent: Friday, August 10, 2001 11:14 PM
circuit ?
> Yes Jal is one of many options for programming the SX. However,
programming
really
> Regards,
> Al Williams
> AWC
> > From: Jean.Marchaudon [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=NWEf1lj5f7b3pO7HcWdMz5AbLyg8I3z6ESO6_YsbrXlahmF_VEeLT4Rg1xEv8dAzELsrc-tPZZ_TZeVuFRKGh-J4WA]jean.Marchaudon@w...[/url
> > circuit ?
the
in
> > the SX28.
> > PORT RA3 and
a
> > jj
> > circuit ?
> > > Hi John,
> > firmware on
> > Parallax,
> > from the SX
> > > program.
> > which
> > registers, but it
> > is
> > difficult to
> > more complex
> > > Hope that helps.
> > > Al Williams
> > > AWC
> > > > circuit ?
> > > > Hi,
CMS).
> > transistors and
> > > > integrated
> > > > in the circuit.
> > > > My question is:
> > > > BASIC, and use
building
> > the
> > > > John john
> > > > France
> > Subject and
