Serout
I'm trying to send text strings out the serial port of the BSII.
I am able to send single characters to DCE equipment, but I am unable
to send text strings to DTE equipment. I've disconected the ATN line
on the carrier board, but still no data.
Any suggestions?
Todd
Any suggestions?
Todd
Normally DTE and DCE equipment have their TX/RX pins (2 and 3) swapped.
Check your cabling documentation..
Greetings peter
Oorspronkelijk bericht
Van: Todd Goetze [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=NpeI1X0UQlYKaBqSSTG2IS3Am2c35yMx-8dTl_O1XKiqcglFirh4ohL9ZDwgeWpznQ_S3ViSkEIyOkI]todd_goetze@y...[/url
Verzonden: vrijdag 10 augustus 2001 01:10
Aan: basicstamps@yahoogroups.com
Onderwerp: [noparse][[/noparse]basicstamps] Serout
Any suggestions?
Todd
to mind that may be of use.
The transmit and receive lines on a cable to connect a 25-pin serial port to
a 25-pin modem do not cross.
The transmit and receive lines on a 25-pin to 25-pin null cable do cross.
The transmit and receive lines on a cable to connect a 9-pin serial port to
a 25-pin modem do cross.
The transmit and receive lines on a 9-pin to 25-pin null cable do not cross.
If I remember right, the rules for the 25-pin to 25-pin cables stated above
also apply to a 9-pin to 9-pin cable.
Adapters used to connect a 9-pin mouse to a 25-pin serial cable rarely have
all the connections necessary to use them for anything other than the mouse.
I am getting communications. The problem is when I send a text
string all I receive is a NULL character from the stamp. I've tried
sending one character at a time and several other methods. Still all
I get are NULLs.
Please Help.
Todd
--- In basicstamps@y..., "Peter Verkaik" <peterverkaik@b...> wrote:
> Hi,
swapped.
> Greetings peter
> Van: Todd Goetze [noparse][[/noparse]mailto:todd_goetze@y...]
> Aan: basicstamps@y...
unable
line
> Any suggestions?
> Todd
> basicstamps-unsubscribe@y...
Subject and
Have you tried/checked lower baudrates yet. At some equipment
that use software decoding a too high baudrate causes them
to miss transients. A 1200 baud setting always should work.
Greetings peter
Van: Todd Goetze [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=7dTprP4wdunCYy4VZvVNIYva9GVYTj8bRjjKjDC_zsdtQqR4L9C9a1BrwtHm4gTejJcLa49e19grpn15nRM]todd_goetze@y...[/url
Verzonden: vrijdag 10 augustus 2001 16:53
Onderwerp: [noparse][[/noparse]basicstamps] Re: Serout
My first message was a bit vague. The problem is not cabling because
I get are NULLs.
Please Help.
Todd
> Hi,
swapped.
> Greetings peter
unable
line
> Any suggestions?
> Todd
Subject and
This specifies I/O 1 and a baud rate of 2400--won't work.
To send data back to your PC, use the DEBUG command or send via I/O
16 at 9600 baud:
DEBUG 65 ' dec 65 = hex 41 = ASC 'A'
SEROUT 16,16624,[noparse][[/noparse]65]
See BASIC Stamp Programming Manual 2.0 pages 97 and 297.
Steve
download the simple program:
SEROUT 1,17405,[noparse][[/noparse]65]
to my BS2SX, should it give an output to the debug terminal? If so,
something is wrong b/c I don't see anything.
terminal by using Pin
#16.
Jared
--- pstrittmatter@y... wrote:
> I have just started trying to learn the SEROUT command. When I
of the message
> will be ignored.
electrolinx - http://www.geocities.com/SiliconValley/File/2400/
__________________________________________________
Do You Yahoo!?
Get email alerts & NEW webcam video instant messaging with Yahoo! Messenger
http://im.yahoo.com
the right baud rate and everything so I'm not sure what the problem
is.
--- In basicstamps@y..., Jared Hoylman <electrolinx@y...> wrote:
> This would send the data out Pin #1. You can send this data to the
debug terminal by using Pin
> #16.
> Jared
so,
Subject and Body of the message
> > will be ignored.
> Do You Yahoo!?
Messenger
> http://im.yahoo.com
> 16 at 9600 baud:
> or
> Regards,
> Steve
