why would a wire extension affect operation???
Does anyone know why extending an automobile DC power wire (cigarette
lighter adapter specifically) would cause an AC/DC inverter to not work?
Can the length of a wire affect how much current flows through it? (I use a
basic stamp 2 in my application, and I figured this group hosts the wisest
of the wise...)
Here's a link to my application (Dashboard PC):
http://christopher.bergeron.com/
for those interested...
Thanks in advance for any info about this!
-CB
_________________________________________________________
Do You Yahoo!?
Get your free @yahoo.com address at http://mail.yahoo.com
of the wise...)
-CB
Do You Yahoo!?
your inverter and that 12V is in fact present, if you extended the
cigarette lighter adapter wiring yourself by splicing into it. The
length of a piece of wire does have an impact on how much current can
flow through it. The longer the piece of wire is, the more resistance
it has, hence less current can flow. However you have to have ALOT of
wire for this to really come into play.
I'd look for more obvious causes...Polarity reversal, bad connection,
shorted wiring, blown fuse inside the cigarette lighter part, blown
fuse in the vehicles fuse panel, etc., epsecially if you made the
modifications yourself. Length of wire would be the last thing I look
at unless you just extended it from 8 feet to 800.
--- In basicstamps@y..., "Christopher Bergeron"
(cigarette
work?
(I use a
wisest
> of the wise...)
> -CB
> Do You Yahoo!?
> Your problem is most likely the cigarette lighter adapter, they are
> probably the worst possible way of powering anything in a car. I
> would 1. keep the wires short 2. keep the wires big ,and 3. attach
> the wires directly to the battery (with fuses on both + and -). You
> can go to a shop that sells monster car stereo stuff and get
> everything you need.
Ditto: one more important note, make sure and fuse BOTH the positive and
negative wires going to the battery.
Dale Harwood [noparse][[/noparse] N4VFF ]
internet> dale@h...
ax.25> n4vff@n4vff.#cha.tn.usa.noam
#include <std_disclaimer.h>
(cigarette lighter adapter specifically) would cause an AC/DC
