Com1 not responding!! PLEASE HELP! EMERGENCY!
OK, out of nowhere, everytime I try to load a code onto my BS2, I get
an error message saying "Basic Stamp II detected but not responding
on COM1." I've tried it on 3 computers, same thing. PLEASE HELP!!
Graduation project due on Friday!!!
-J
-J
results............ you have isolated the problem to the module and it
will need to be replaced.
Dave
Sent: Thursday, August 09, 2001 12:13 AM
Subject: [noparse][[/noparse]basicstamps] Com1 not responding!! PLEASE HELP! EMERGENCY!
> Thanks,
> -J
a fresh battery?
Steve
<<OK, out of nowhere, everytime I try to load a code onto my BS2, I get
Graduation project due on Friday!!!>>
receiving with the first stamp I had. It was defective, and everything
worked once it was replaced. Hope you can get this worked out!
Eric
From: samhell@s... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=i4XyW1Mb9KNLooJEFW_qqTdVazH6JmXZKRquq4HSj2nXXjuhXs4xkrKd9G8E6g17TfwOEby78Uy6o6HUecA]samhell@s...[/url
Sent: Thursday, August 09, 2001 12:32 AM
Subject: Re: [noparse][[/noparse]basicstamps] Com1 not responding!! PLEASE HELP! EMERGENCY!
I would try a known working stamp in the circuit ........if same
Dave
> Thanks,
> -J
-J
Sent: Wednesday, August 08, 2001 10:41 PM
> This may sound terribly simple, but have you tried
> a fresh battery?
> Regards,
> Steve
_________________________________________________________
Do You Yahoo!?
Get your free @yahoo.com address at http://mail.yahoo.com
This problem brings up an issue that seems to me to be
neglected concerning stamps. Static. And it's capacity to
damage chips, and the means to prevent that damage. I never
touch my chips unless I am wearing my grounding strap. Am I
being over-cautious?
Ken Ambrose
with enough thrust, pigs fly just fine.
---- On Wed, 8 Aug 2001, Joe Khachadourian (kach705@y...)
wrote:
> Switched batteries & used wall outlet as well.
> -J
> From: <PicProgrammer@a...>
EMERGENCY!
> > a fresh battery?
> > Regards,
> > Steve
my BS2, I
> get
responding
HELP!!
the Subject
> and
> Do You Yahoo!?
Subject
> and Body of the message will be ignored.
responding.
Could be that whatever else you have connected is pulling the voltage down,
keeping the stamp from firing up. Check Vin with a DC voltmeter -- it should
be at least 6-7 volts. Check Vdd -- it should be about 4.9-5.1 volts. If Vin
is OK and Vdd is low, something is loading down the regulator on the Stamp.
> > a fresh battery?
Not a bit. I have a friend who 'blew' a batch of 20 ICs, as he went by the
rule that 'with all this humid air you sure can't have any static on you'.
So, always use a grounding strap, or if not, grab the chips by the edge,
don't touch the pins.
All the best,
Mensaje original
> De: Ken Ambrose [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=5lxZ_lZijwxDnOltAFW8gk-7dc8mZxauX8_eIaPuleWdNXCkjZD-Vi1eVPQdhkrB89Q8FgCt]kenzo@u...[/url
> Enviado el: jueves, 09 de agosto de 2001 8:18
> Para: Joe Khachadourian
> Asunto: Re: Re: [noparse][[/noparse]basicstamps] Com1 not responding!! PLEASE HELP!
> EMERGENCY!
> Hi,
> Ken Ambrose
> > -J
> EMERGENCY!
> > > a fresh battery?
> > > Regards,
> > > Steve
> my BS2, I
> > get
> responding
> HELP!!
> the Subject
> > and
> > Do You Yahoo!?
> Subject
1) Are you feeding the Stamp +5V or unregulated voltage via the Vin pin? If
you are using Vin, check to see that the Stamp is generating 5V. If not, you
may have blown the regulator. Try feeding it 5V directly to the 5V pin and
leave Vin disconnected.
2) Measure the voltages on the SIN and SOUT pins to see if they look
reasonable. Remember that the Stamp "feeds back" the negative voltage from
the PC back to the PC. This will quickly show you if you have a bad cable.
3) Have you tried a different cable?
4) Did the Stamp ever work? If not, be sure to check for things holding COM1
open (like palm pilot software or a modem) or things holding COM3 open (most
PCs can't use COM1/3 at the same time).
5) Set the Windows software to explicitly use COM1 (you are sure it is COM1)
and set it for the exact Stamp type you have (BS2, BS2SX, etc). This reduces
some variables.
6) Does your cable or programming board have a short between pins 6 and 7 of
the DB9? (Check this on the PC end with an ohm meter).
7) Make sure ATN is connected (again with an ohm meter).
8) FedEx :-)
Good Luck!
Al Williams
AWC
* Floating point A/D
http://www.al-williams.com/awce/pak9.htm
> From: kach705@y... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=NXcpfhGpQqzTKICQzoKLkICoObwANThGwb21Tx3JEUmKzM80Me20qhZvLcz9hIqASribtSxGEjHapQ]kach705@y...[/url
> Sent: Thursday, August 09, 2001 12:14 AM
> Thanks,
> -J
