BS2E PWM Driving H-Bridge
All,
I've done some searching and tinkering and can't really get the PWM
statement on the BS2E to drive an H-bridge properly. All of the resources I
have found so far revolve around what Parallax has in the manual, which is
not what I want to do. PULSOUT works fine, and I've used this before to
control H-bridges with no problems. Any suggestions?
daweasel@s... writes:
Bill:
The PWM from the Stamp is not designed to drive H-Bridge circuits. The
intent is to create a quasi-analog output by charging a cap through a know
resistance. If you look at the PWM signal on a scope you'll see that it
looks random. It's the nature of the algorithm. Over a given period, the
duty cycle is as specified, but it's not regular -- something you need when
driving motors.
There's an old BS1 App Note called "Fun With Trains" that does motor control
directly (through a ULN2803). I don't know if it will work with your app,
but it's worth a shot.
-- Jon Williams
>In a message dated 8/7/01 2:22:32 PM Central Daylight Time,
>Bill:
>driving motors.
>-- Jon Williams
Bill,
You must first think of the Stamp PWM as a means for setting an
analog value. "quasi-analog" as Jon Williams puts it. There is
a quick and dirty way to do what you want, but it involves a few
external components.
R C
Stamp I/O >----/\/\----o----||----> GND
100K Pot o
> QA "quasi-analog"
o--/\/\--o |
| o---o o--|+\
| | | \----> PWM out to "H-Bridge"
| 1|\ 2 | o--|-/
o--| \o--o | |/U2
| |/ U1 |
o
o
> QSAW "quasi-saw"
o---||
>GND
.01uF
U1 - 74HC14
- tie ALL unused INPUT pins (3,5,9,11, & 13) to GND (pin 7)
or VCC (pin 14)
- connect a .01uF cap directly across pins 7 & 14
U2 - UA741 Op-Amp
R&C - R and C values should be those suggested in the Stamp Manual.
Note: Adjust the 100K Pot for a base frequency of aprox 3KHz.
Most ESC (Electronic Speed Controllers) use a base
frequency near 3KHz.
With this setup, you can send a PWM signal to your Stamp pin to
set your PWM level. Then you can process other code while this
circuit temporarily maintains the PWM level. You WILL need to
make periodic updates.
Beau Schwabe IC Mask Designer
National Semiconductor Wired Communications Division
500 Pinnacle Court, Suite 525 Mail Stop GA1 Norcross, GA 30071
schematic. Any way you can email me a GIF or something?
resources I
which is
to
> R C
> 100K Pot o
> QA "quasi-analog"
> o--/\/\--o |
> | o---o o--|+\
> | 1|\ 2 | o--|-/
> o--| \o--o | |/U2
> | |/ U1 |
> o
o
> QSAW "quasi-saw"
> o---||
>GND
> .01uF
> U1 - 74HC14
> or VCC (pin 14)
> U2 - UA741 Op-Amp
If you change your font to a "fixed-width" font, such as "Courier New", you
will be able to read ASCII schematics...
Jared Hoylman
VB Overdrive
http://vboverdrive.extreme-vb.net/main.php3
Sent: Tuesday, August 07, 2001 4:40 PM
Subject: Re: [noparse][[/noparse]basicstamps] BS2E PWM Driving H-Bridge
> Beau, thanks for the info, but I can't make heads or tails out of your
ASCII
> resources I
> which is
> to
few
> > R C
> > 100K Pot o
> QA "quasi-analog"
> > o--/\/\--o |
> > | o---o o--|+\
> > | 1|\ 2 | o--|-/
> > o--| \o--o | |/U2
> > | |/ U1 |
> > o
o
> QSAW "quasi-saw"
> > o---||
>GND
> > .01uF
> > U1 - 74HC14
> > or VCC (pin 14)
> > U2 - UA741 Op-Amp
>Beau, thanks for the info, but I can't make heads or tails out of your ASCII
Turn off your proportional spacing, or cut-n-paste it into Windows NotePad
