Wireless transmission.
Anyone know of an off the shelf transceiver that plugs into a comm port, for
sending and receiving data?
>for sending and receiving data?
I've used modules from www.maxstream.net for direct serial connection,
although they are a bit expensive ($150 each). As you've no doubt become
aware, most of the lower cost units require that a Manchester (or other
guaranteed time-variant) code be used. www.qwikradio.com has some
inexpensive 8-pin IC transmitters and receivers; however note that these do
fall into the latter category.
Todd Peterson
E-Lab Digital Engineering, Inc.
"IC's for BASIC Stamp Applications..."
(816) 257-9954 FAX: (816) 257-9945
www.elabinc.com
