Serial IDE Interface - Survey
There is a project in the brainstorming stage to create a serial IDE interface.
At this point, some questions need to be asked.
1. Is there any demand for this device?
2. What applications would this device be used in?
3. What features would be desired/required?
4. What interface is desired or would multiple, user selectable options be the
way to go?
I'll post more questions as I think of them.
Barry
way to go?
Barry
some time ago and it is VERY complex. Accessing the drive and reading
raw data to/from the drive is trivial. Supporting FAT16/32 so you can
read/write to the disk with a standard PC with Windows is the hard
part.
interface. At this point, some questions need to be asked.
options be the way to go?
> Barry
The applications are many, and demand could be high. A cheap, reusable way
to store data, would be really great for those now using EEPROM devices.
Features could be a simple serial protocol, 9600 baud, to send blocks of
data to it - the StampMem example is quite good, you can write up to 64
bytes in one command.
I'm not particularly fussed about supporting FAT16/32, it would be nice, but
not the end of the world if it didn't happen.
There is a video compression board, the MKV128, that supports FAT interface
to a HD to store images, you could take a look at that to see how it's
done - maybe a specialised IC.
Good luck,
Mensaje original
> De: Barry Michels [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=2LAgf7m2-hMQk3l4oAqW1IwqdtVYk2-hOPcFGB_kIQCq0JgUh5XmJOjZ2ScLxo8w3veYpHfma1llQA]bmichels@e...[/url
> Enviado el: martes, 07 de agosto de 2001 12:33
> Para: basicstamps@yahoogroups.com
> Asunto: [noparse][[/noparse]basicstamps] Serial IDE Interface - Survey
> IDE interface. At this point, some questions need to be asked.
> Barry
> from the same email address that you subscribed. Text in the
50 points each minute, 7 days is over 500,000 readings.
If I had a disk in the field for storage and
a Stamp in the office, I could do the data transfer
in a proprietary manner. not bad at all.
If I could download in the field with a PALM or other
portable device, (Stache Walkabout??) that too
would solve the data transfer needs.
Has anybody tried to connect to the HOBO(r) Transport
http://www.onsetcomp.com/ that uses the Palm ??
or the HOBO(R) SHuttle
http://www.onsetcomp.com/Products/Product_Pages/temperature_pages/2570
_HOBOshuttle.html
Dave
--- In basicstamps@y..., "Miguel Puchol" <mpuchol@w...> wrote:
> Hi Barry,
reusable way
devices.
blocks of
to 64
nice, but
interface
it's
> Good luck,
> Mike
Mensaje original
> > De: Barry Michels [noparse][[/noparse]mailto:bmichels@e...]
> > Para: basicstamps@y...
> > Barry
> > basicstamps-unsubscribe@y...
with. I've already looked into FAT16 and it looks very easy. I've already
built a file entry by hand with a hex editor just to see if I could do it
and make the OS read it.
It was brought to my attention that there is already an interface that
allows for low-level access to a drive. But, you have to manage head,
cylinder and sector addressing and you have to read/write the whole 512 byte
sector at once. I have in mind a higher level approach where you just tell
the interface what file you want to read/write and it will handle the
addressing for you. And, you can read/write as little or as much as you
want. The interface will store data in a static ram chip temporarily until
it needs to be written to disk or until a new sector is needed from the
drive.
The only application I could think of is data logging. Bill Weller
mentioned code storage so you could swap code modules and increase the
capability of a stamp. It would be nice to know what other uses there are
so the features could be set before construction starts. Application may
dictate the hardware approach.
I read through the I2C spec last night and it looks like the way to go. The
stamp can support it, there's no limit to the data per packet (except any
limit by the stamp), the speed is quite fast (81kbps) and the slave can
pause the master if it needs to - all on 2 pins.
Message: 3
Date: Wed, 08 Aug 2001 04:51:50 -0000
Subject: Re: Serial IDE Interface - Survey
Good luck on this project. I too looked into building this device
part.
___________________________________________________________
________________________________________________________________________
Message: 8
Date: Wed, 8 Aug 2001 10:02:38 +0200
Subject: RE: Serial IDE Interface - Survey
Hi Barry,
Good luck,
FAT tables:
http://www.csm.de/en_dosdrive.htm
And one that just logs data in proprietary format:
http://www.csm.de/en_ddlogger.htm
These are in the $500 price range. Up to 8 gigs on a sandisk card.
-- Tracy
