Programing assistance needed with VB6 and BS2
Hello all,
I have a programming problem that I hope one of you can help with.
First of all me experince in this area is poor. What I need to
accomplish is take a set of 4 seperate numbered pairs and send them
to Visual basic through the serial port. Now I can do this with a
single numbe okay. The trouble is sending a data stream of 4 diffrent
sets of numbers. Here is my example. I send VB from stamp 15526012
which the VB program should break out into data1=1, data2=55,
data3=260, data4 = 12. Now each data feild can have a range from 0-
999. This would be great and I could do if all the sets of numbers
equated to three digits each, but as the world works this is not the
case. Anyway I hope I'm explaining what I want to accomplish. Recap
: take a number such as 1231018020 and turn it into data1 = 123,
data2=10,data3=180,data4=20. keeping in mind that each seperate data
feild could be a number between 0 and 999. Any and all hep is
appiciated. I've been trying to get this to work for a week with no
luck.
Shawn
luck.
Shawn
Not sure I completely grok your meaning. (ev1.net -- are you in Houston?)
However, a few things to think about. If your number is always between 0 and
999, why not use the dec3 modifier on SEROUT?
So:
w=71
x=1
y=22
z=450
SEROUT 16,84,[noparse][[/noparse]dec3 w, dec3 x, dec3 y, dec3 z,CR]
Would write:
071001022450
That would do what you want, right? The other choice would be to separate
them with commas or something:
SEROUT 16,84[noparse][[/noparse]dec w, ",", dec x, ","...,CR]
You can find a VB (and C++) example at
http://www.al-williams.com/stampcom.zip
Good luck!
Al Williams
AWC
* Connect a PS/2 keyboard to your Stamp
http://www.al-williams.com/awce/pak6.htm
> From: shawnusa@e... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=JxKt1qMmYfUk4vBKJOrqejvWSiM9j89LElyDP02DGXKOw-pob8oxSX5Xm5rGIrG_bb1tPFVKh8AY9SY]shawnusa@e...[/url
> Sent: Monday, August 06, 2001 9:01 AM
> Subject: [noparse][[/noparse]basicstamps] Programing assistance needed with VB6 and BS2
> Hello all,
> luck.
> Thanks
> Shawn
> from the same email address that you subscribed. Text in the
VB program can receive the string, then look for the commas to parse out the
individual numbers (using the VAL function).
-- Jon Williams
-- Dallas, TX
In a message dated 8/6/01 9:03:53 AM Central Daylight Time, shawnusa@e...
writes:
That was what I needed. I was trying to figure a way to add leading
zeros to the stream but was thinking in VB programming logic and not
BS2. Now I can use Mid(variable,x,y) and pull each one out! This may
not be the most efficent programming method, but it will work. Thanks
again!
O'h and yes, I do reside in the Houston area. Yourself?
Shawn
having difficulty in writing code to pull out the numbers from the
stream. I've tried all sorts of Len,mid and loops to pull out the
numbers from the stream and comma seperators. Yet to be able to get
that to work. However another Gentlman has given me another avenue to
add leading 0's to the numbers to help. Thanks for your input and if
you have code examples for vb to pars out numbers with comma
delimeters please share it. I have busted my chops trying to giure
out that route. Thanks again
Shawn
--- In basicstamps@y..., jonwms@a... wrote:
> You may want to have your Stamp insert a comma in between the
numbers. Your
parse out the
> -- Jon Williams
> -- Dallas, TX
Dim N()
N = split(X, ",")
Mark
Sent: Monday, August 06, 2001 10:08 AM
Subject: RE: [noparse][[/noparse]basicstamps] Re: Programing assistance needed with VB6 and BS2
> You could do something like this in VB (untested):
> Dim N(4)
> X = "33,1,17,101"
> SPOS = 1
> For i = 1 To 4
> CPOS = InStr(SPOS, X, ",")
> If CPOS = 0 Then
> ' error if I<>4
> If i <> 4 Then MsgBox "Error!" ' use your own code here
> N(i) = Val(Trim(Mid(X, SPOS)))
> Else
> NS = Trim(Mid(X, SPOS, CPOS - SPOS))
> N(i) = Val(NS)
> SPOS = CPOS + 1
> End If
> Next
> ' Now N(1), N(2), N(3), N(4) are what you want
> Regards,
> Al Williams
> AWC
> * Floating point A/D
> http://www.al-williams.com/awce/pak9.htm
> > From: shawnusa@e... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=OZ1qiwerlOp-UMFkUD4jeNQtbE1fdtiDbFWlxjRnaTu-BwKL9Qmp42aypGVSnNBMUl8G-1tpb1iZ]shawnusa@e...[/url
> > Sent: Monday, August 06, 2001 9:27 AM
> > Subject: [noparse][[/noparse]basicstamps] Re: Programing assistance needed with VB6 and BS2
> > This was my thinking as well. I being a beginner programmer, was
> > Shawn
> > numbers. Your
> > parse out the
> > > -- Jon Williams
> > > -- Dallas, TX
Dim N(4)
X = "33,1,17,101"
SPOS = 1
For i = 1 To 4
If CPOS = 0 Then
' error if I<>4
Else
N(i) = Val(NS)
SPOS = CPOS + 1
End If
Next
Al Williams
AWC
> From: shawnusa@e... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=m-YRIy3ZQ5h8tuFMXi5in5DDJKAiovASk6wThhQ-VmtH8SZGjdK3eVsR6oS8y0U_8fTqlZTM]shawnusa@e...[/url
> Shawn
> numbers. Your
> parse out the
> > -- Jon Williams
> > -- Dallas, TX
C++, Java, and ASM. I even have to watch to not write X$ all the time!
Al Williams
AWC
* Measure 8 pulses at once
http://www.al-williams.com/awce/pak7.htm
> From: Mark Schmidt [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=NNwzkLSNZZrr0O8b8mlVjAmSgljCXGrAoU6mrGcBZxnQq7TuGdFODsruvhJnEhrtpU5_Q-d__jm2WzI]mschmidt@g...[/url
> Sent: Monday, August 06, 2001 10:07 AM
> Subject: Re: [noparse][[/noparse]basicstamps] Re: Programing assistance needed with VB6 and
> BS2
> or
> Dim N()
> N = split(X, ",")
> Mark
> From: Al Williams <alw@a...>
> VB6 and BS2
You are in luck... VB6 makes this a snap with the use of the "Split"
function. Try the code below on for size...
Dim sBuffer As String
Dim sData() As String
Dim x As Long
' \\ This is your data buffer
sBuffer = "1,21,321,1,4555,8,7,321,456,8754,21213"
' \\ Parse the data
sData() = Split(sBuffer, ",")
' \\ Display the data in Debug Window
For x = 0 To UBound(sData)
Debug.Print sData(x)
Next x
The "Split" function fills an array with the data between the specified
delimiter. Easy (and pretty quick)..!
Hope this helps,
Jared Hoylman
VB Overdrive
http://vboverdrive.extreme-vb.net/main.php3
Sent: Monday, August 06, 2001 7:27 AM
> Shawn
> numbers. Your
> parse out the
> > -- Jon Williams
> > -- Dallas, TX
creates a delimited list.
Join(Array, Delimiter)
dim MyString as string
MyArray(0) = 1
MyArray(1) = 89
MyArray(2) = 75
MyString = Join(Array, ",")
MyString = "1,89,75"
Using split and join allows you to work with delimited list using
arrays (easier coding) then dumb the completed array back out as a
delimited string.
Tim
--- In basicstamps@y..., "Jared Hoylman" <electrolinx@y...> wrote:
> Shawn,
> Dim x As Long
> ' \\ Parse the data
> Next x
specified
> Hope this helps,
> Jared Hoylman
> VB Overdrive
> From: <shawnusa@e...>
> To: <basicstamps@y...>
and BS2
get
avenue to
if
> > Shawn
> > numbers. Your
> > parse out the
> > > -- Jon Williams
> > > -- Dallas, TX
> > basicstamps-unsubscribe@y...
Subject and
