Timing
Hello everyone [noparse]:)[/noparse]
Is the basic stamps clock readable in any way ? For instance what I really
want to do I would do like this in Qbasic.
Oldtime = TIMER
Clock:
a$=inkey$
if a$ = "" then Clock
print "Time =";timer-oldtime
The actual application is this. I have a stepper motor connected to the
shaft of a motion picture camera (Motion picture camera's have a
semicircular shutter so one rotation of the shaft is one frame). The
stepper motor is a Milford Instruments Bipolar stepper Driver set.
The stamp sets the rate at which the motor moves IE:-
200 steps at 2MS = 1 Frame at 1/5 sec
(the motor takes 400ms to turn but the shutter is only open for 200ms)
Now that's easy to calculate [noparse]:)[/noparse]
But I also have a "B" setting and a "T" setting .. On the "B" setting the
shutter opens until you let go of the button and the "T" setting the shutter
opens on the first press of the button and closes on the second. What I
want to do is time this event. Any ideas ?
Justin Pentecost
Focus Puller CML Listpig and Stamp Idiot
LONDON
Oldtime = TIMER
Clock:
a$=inkey$
Justin Pentecost
LONDON
No, there isn't an internal clock in the Stamp as there is in PCs. You can
synthesize a clock in PBASIC, but this becomes a bit tricky because you must
make sure that the timing through all execution paths is the same.
Another option -- depending on your resolution requirements -- is to use a
BS2p and one of the Dallas 1-Wire clocks that return time in seconds plus
1/256 of a second.
The BS2p is fast and has a lot of other neat features, including the ability
to interface very easily with parallel LCDs and I2C devices.
-- Jon Williams
-- Dallas, TX
-- AKA Jon McPhalen
-- Actor who appreciates good focus-pullers
In a message dated 8/6/01 7:34:02 AM Central Daylight Time, justin@k...
writes:
> Oldtime = TIMER
> Clock:
> a$=inkey$
> Justin Pentecost
to the 1-wire:
The Pocketwatch B
http://www.parallaxinc.com/html_files/products/BS_Accessories/solutions3_bri
ef.asp
Parkis' Time Machine (not sure if you can really keep time with it or not)
http://home.earthlink.net/~parkiss/
Time Keeper http://www.high-techgarage.com/products/
Also, if you need pulse measurement, a PAK-VII can keep a realtime clock
(until the power is off) but if you just need a clock, one of the other
devices is probably easier. The PAK-VII clock example is in
http://www.al-williams.com/awce/doclib.htm
Al Williams
AWC
* Easy RS232 prototyping:
http://www.al-williams.com/awce/rs1.htm
The stamp is deterministic, meaning that there are no interrupts or
hidden processes that can change the timing of a loop. It sounds like
your application the stamp will not have anything else to do while it
times the shutter. The following loop measures the time that P0 on
the stamp stays high. The loop executes ~1426 times per second (on
the original BS2). The debug statement converts the time into
milliseconds for display.
' snippet measures the time P0 stays high.
xc var word
loop2: ' 1426 loops per second, 7.013E-4 seconds per loop
xc=xc+1
if in0 then loop2 ' count until in0 goes low
debug dec xc**45960,cr ' ** converts the count to straight milliseconds
More on timing loops at:
http://www.emesystems.com/BS2speed.htm
-- Tracy
I use the Pocket Watch in a central heating control. It's easy to use,
because you can read a real clock.
Another way is to use a 4060 IC with a quartz. This gives you a 2 Hz clock
that you can manage with the Stamp. The only thing is to read the state of
the clock at least 4 times per second. This point depends on the rest of the
program.
Let me know if you want to have more information about that.
Best regards,
Phil.
Subject: [noparse][[/noparse]basicstamps] Timing
really
> Oldtime = TIMER
> Clock:
> a$=inkey$
the
shutter
> Justin Pentecost
> Focus Puller CML Listpig and Stamp Idiot <<<<<< you said that...
> LONDON
transmitter which lists the max modulation frequency as 4KHz. How would
this translate into a data rate?
Matt
[noparse][[/noparse]This E-mail scanned for viruses by Declude Virus]
out a light. The unit is powered by battery(4AA). In the shop it
counts fine on the demo board(nx-1000) but on stage it reaches 41
min. Any ideas?
adding a time source of some sort,I will just have to back up the
pauses so I can do multiples to get to the time I need.So that being
said I don't want the delay while one pause is running into another,so
can I put a cap in that line to that output so it won't do that.Yes I
also realize it will do nothing else while counting that pause.
Stan
