Servo consumes too much power — Parallax Forums
edited 2001-08-02 14:05 in General Discussion
Hi people,
I am making a photophobic robot for my final year engg.
project. I have a deadline to meet i.e. 6th august.
The problem that I am facing right now is that the servos are
consuming too much power. What I mean is that my 6 volts battery
drops to 5.2 in about 15 minutes of intermittent running. When the
voltage drops, the motors turn even when they are not expected to.
i.e. if I program it to run one motor and stop the other motor, still
the other motor runs. What can be the problem ???
I have given the vdd of the servos directly to the battery as for 5
volts, they rotate too slowly. Please help and thanks in advance.
Venkatesh Kanchan.
    edited 2001-08-01 14:25
    Venka. What is your 6 volt source power AA batteries, D cells? sub C nicads?
    I have a small robot using 4, C cell nicads (6V, 2000 mah) I use the generic
    cheapy servos (not micro) I get around 4 hr run times. This may give you
    some idea on what is possible for a battery size.
    You could try electric helicopter micro servos, if size permits.
    I presume you have tried differant servos? its possible there is something
    wrong with yours causing excessive drain.
    At 01:05 PM 8/1/2001 -0000, you wrote:
    >Hi people,
    >Regards,
    >Venkatesh Kanchan.
    >from the same email address that you subscribed. Text in the Subject and
    >Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
    Sincerely
    Kerry
    Admin@M...
    WWW server hosting [url=Http://mntnweb.com]Http://mntnweb.com[/url]
    Kerry Barlow
    p.o. box 21
    kirkwood ny
    13795
    edited 2001-08-01 14:30
    Without seeing the circuit, I would say it is back EMF from the
    motor that is being shut down. As a motor spins down, it produces
    current which glitches the control circuit. Diodes may correct the
    problem. I would also put ceramic caps across the motor terminals.
    Bill
    From: v_s_kanchan@s... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=0ob844NVWkrEP2lfkWvbHXTsCFFwsi3rdnsO3LfZFm2PONxVFuEoB5fhb4m1k2AKJEQFXQB8hPWWLwg4Khpe3VSZ]v_s_kanchan@s...[/url
    Sent: Wednesday, August 01, 2001 7:06 AM
    Subject: [noparse][[/noparse]basicstamps] Servo consumes too much power
    Hi people,
    Venkatesh Kanchan.
    edited 2001-08-01 14:43
    What size battery? A couple of standard servos with a small load should run
    an hour or more on 4 AA alkaline batteries. My mini sumo robot runs quite a
    while on 4 AAA batteries.
    edited 2001-08-02 07:41
    Hi
    Thank u for ur reply. I am using 4 AA batteries. The load is normal :
    plastic body, 2 ckt. boards, 2 servo, light wheels, and the battteries. It runs
    for 20 minutes, may be. What do u say ???
    Venkatesh Kanchan.
    _____________________________________________________________
    Sign up for FREE email from Simply Faltoo .Com at http://www.simplyfaltoo.com
    What other things are you running? LED's, LCD with backlight, ultrasonic
    detector?
    runs for 20 minutes, may be. What do u say ???
