Pak vii & bs2
I'm needing help with using the PAK VIII with the BS2.
I wired the PAK VIII per the manual, connected it to
the BS2 and used the SERVO-BOT program to see if
everything functioned properlly. When I run the
program the servo goes to an extreme position and
stays there. No matter what value I input it produces
the same result. Even if the value is Zero, still the
servo moves to the same position. I've checked the
wiring and it is correct, according to the diagram.
Any suggestions on what is happening and how to fix it
would be very much appreciated.
Brian
__________________________________________________
Do You Yahoo!?
Make international calls for as low as $.04/minute with Yahoo! Messenger
http://phonecard.yahoo.com/
Brian
Do You Yahoo!?
