RTD/Thermocouple transmitter?
Hey everyone,
I'm working on a project right now to monitor temperatures of various
bearings on a piece of equipment. There are 8 RTD probes which I need
to read and get the value into my stamp so I can pick up a permissive
relay to let the machine run if the temps are ok.
I'd like to use some sort of 4-20mA signal off the RTD's since the
stamp will be quite some distance away from the temp probes. I've
found several companies that sell RTD or Thermocouple 4-20mA
transmitters but the problem is the price. They want like $100 a
piece and I need to monitor 8 probes!
I was wondering if anyone had any schematics on how to build a 4-20mA
transmitter for a reasonable price and with reasonable accuracy based
around an RTD or Thermocouple (I could switch probes to thermocouple
type instead of RTD). Or even getting me going in the right direction
would be a great help.
Thanks in advance!
Tom
Thanks in advance!
Tom
them a short distance into a multiplexer and a Analog Devices Thermocouple
chip, then transmit the results via a wireless transmitter to a receiver
attached to the stamp. Of course, a cabled serin could do the same for a
little less $, but wouldn't be as much fun. Either of these would cost far
less than the multitude of transmitters.
The method in Scott Edwards' book might also be worth a look.
Chris
> From: tbanez@h... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=LGp2AhdJYqIcrn9zxXTTM_sVBjmm324JZzece4zh1L2BPwE4I8-oQAz4LBTi5NgKMnz7O5E5kz4]tbanez@h...[/url
> Sent: Wednesday, July 25, 2001 12:54 PM
> Subject: [noparse][[/noparse]basicstamps] RTD/Thermocouple transmitter?
> Hey everyone,
> which I need
> direction
> Thanks in advance!
> Tom
> from the same email address that you subscribed. Text in the
I am using LM34DZ temp sensors (1.83 ea) with a 30-foot cable into an ADC.
Seems to work quite well with my BS2. Have designed a board -Urio Jr. - that
has 6 SPDT relays, an 11-channel TLC2543 ADC and power supplies. Needs 4 I/O
lines from an external Stamp.
Sid
Newzed@a...
a beefy output (75deg F = 750mV out) accy .5 deg F. National semi app
data shows this device outputting to a long run of twisted pair.
Costs less than 2 bucks apiece at radioshack.com (cheaper than
digikey)
My 2 cents
Regards
rich
--- In basicstamps@y..., tbanez@h... wrote:
> Hey everyone,
various
need
permissive
20mA
based
thermocouple
direction
> Thanks in advance!
> Tom
pbasic code below illustrates how you do this.
Chuck
'Program used to measure voltage analog data using a CIRRUS LOGIC CS5522, 24
bit ADC chip
'PARALLAX BS2p24 reads I/O data from the CS5522 thermocouple input (0 to
100mv) channels 1 and 2
'Crystal CS5521/22/23/24 Datatasheet DS317F2 (May '00) page 43, figure 21,
for connection setup
'requires chromel/alumel thermocouple table in program #1, ktab.bsp
'5/7/01
'{$STAMP BS2p,ktab}
dathi var word 'thermocouple 12 bit high address
datlo var word 'thermocouple 12 bit low address
cojhi var word 'cold junction 12 bit high address
cojlo var word 'cold junction 12 bit low address
x var word
y var word
r var word
v var word
s var word
rhi var byte
rlo var byte
rn var byte
'BS2p pin connections to CS5522
SCLK con 11 ' ADC Clock
SDO con 10 ' ADC Data output
SDI con 9 ' ADC Data input
CS con 8 ' Chip select
high CS
pause 500
serout 14,16630,[noparse][[/noparse]254,255] 'turn on lcd backlight
serout 14,16620,[noparse][[/noparse]254,1]
serout 14,16620,[noparse][[/noparse]"Setup for reading a"]
serout 14,16620,[noparse][[/noparse]254,192]
serout 14,16620,[noparse][[/noparse]"thermocouple and a"]
serout 14,16620,[noparse][[/noparse]254,148]
serout 14,16620,[noparse][[/noparse]"cold junction room"]
serout 14,16620,[noparse][[/noparse]254,212]
serout 14,16620,[noparse][[/noparse]"temperatures."]
pause 5000
low CS
gosub RESET 'reset CS5522
shiftout SDI,SCLK,1,[noparse][[/noparse]%00001011] 'read configuration register
shiftin SDO,SCLK,0,[noparse][[/noparse]dathi\12,datlo\12]
debug " CONFIG:",cr,"bits 23 to 12 ",bin12 dathi,cr,"bits 11 to 0 ",bin12
datlo,cr,cr
dathi=%000000001000 'write cnfiguration register
datlo=%000000000000
shiftout SDI,SCLK,1,[noparse][[/noparse]%00000011,dathi\12,datlo\12]
datlo,cr,cr
datlo=%000000000000
datlo,cr,cr
dathi=%000001100001 'write cnfiguration register
datlo=%000000000000
datlo,cr,cr
dathi=%100100111010 'write gain register 1 (C/A thermocouple)
datlo=%000000000000
shiftout SDI,SCLK,1,[noparse][[/noparse]%00010010,dathi\12,datlo\12]
dathi=%010000000000 'write gain register 2 (LM334 cold
junction)
datlo=%000000000000
shiftout SDI,SCLK,1,[noparse][[/noparse]%00000010,dathi\12,datlo\12]
shiftout SDI,SCLK,1,[noparse][[/noparse]%00001010] 'read gain register 1
debug " GAIN:",cr,"bits 23 to 12 ",bin12 dathi,cr,"bits 11 to 0 ",bin12
datlo,cr,cr
datlo=%000010000011 'write channel setup registers 1 and 2
dathi=%000000001000
shiftout SDI,SCLK,1,[noparse][[/noparse]%00000101,dathi\12,datlo\12]
shiftout SDI,SCLK,1,[noparse][[/noparse]%00001101] 'read channel setup register 1
debug " SETUP:",cr,"bits 23 to 12 ",bin12 dathi,cr,"bits 11 to 0 ",bin12
datlo,cr,cr
store 1 'C/A thermocouple data table from 0 to 2000 C
serout 14,16620,[noparse][[/noparse]"BS2p40 reads a LM335"]
serout 14,16620,[noparse][[/noparse]"and C/A Thermocouple"]
REPEAT
shiftout SDI,SCLK,1,[noparse][[/noparse]%10001000] 'activate data reading of channels 1
and 2
pause 500
shiftin SDO,SCLK,0,[noparse][[/noparse]cojhi\12,cojlo\12,dathi\12,datlo\12]
r=(((cojhi<<12)+(cojlo>>0)))
debug " Voltage1 = ",dec r," counts",cr
v=(r/79)-273
pause 1
serout 14,16620,[noparse][[/noparse]dec v," deg C @LM335 "]
debug " Voltage1 = ",dec v," deg C @LM335",cr
s=2*v
read s,rhi
read s+1,rlo
r=(((dathi<<12)+(datlo<<0))*4)-200 'convert to lower 16
bits only
v=r
r=r+(rhi*256)+rlo
dathi=r.highbyte:datlo=r.lowbyte
' debug " Voltage2 = ",dec r," counts",cr
for x=0 to 2000 step 2
read x,y
if y=dathi then aa
next
aa:
for s=x+1 to 2000 step 2
read s,y
read s-1,rn
if dathi<rn then aaa
if y>= datlo then aaa
next
aaa:
s=s/2
debug " Voltage2 = ",dec v," counts ", dec s," deg C @LM2904",cr
pause 1
v=((s*18)/10)+32
serout 14,16620,[noparse][[/noparse]254,212,dec v," deg F @LM2940 "]
goto REPEAT
RESET 'initialize CS5522
shiftout
SDI,SCLK,1,[noparse][[/noparse]$FF,$FF,$FF,$FF,$FF,$FF,$FF,$FF,$FF,$FF,$FF,$FF,$FF,$FF,$FF,$FE]
dathi=%000000000000 'activate reset in configuration register
datlo=%000010000000
return
http://www.burr-brown.com
http://www.ti.com
and search for "loop transmitter"
to find the XTR105 and app notes.
Also, the LM10 is a venerable chip for making current transmitters.
Look at the app notes for it from http://www.national.com
-- Tracy
>Hey everyone,
>Thanks in advance!
>Tom
4-20ma conversion.
I am using PicBasicPro to program the
PIC14000 processor that has 7 onboard
16 bit a/d pins and an internal temp sensor.
I think I can program two of
these chips to a/d the 3 or 4 TC signals along
with a reference TC attached to the PIC14000,
and that would allow you to correct
the temps. The PIC4000 could send the
results to your STAMP by a serial
signal.
It all depends on how high your temps
are, how much resolution you need, and
whether my a/d can process the TC
signals without an opamp.
Caio,
Dave
> Date: Wed, 25 Jul 2001 16:54:22 -0000
> From: tbanez@h...
> Subject: RTD/Thermocouple transmitter?
> Hey everyone,
exceeds some value then you might use an IC with a thermostat control
on it. There are temperature sensing ICs that can
a) use external temperature sensor, in addition to on-chip
b) have non-volatile programmable switch points.
You can turn transmition of the temperature into a single state, if
you once program these. Tragically, I can't remember the part
numbers, but I think they were Dallas Semi. They might even give you
enough samples...
Park Hays Phone: (315) 456-3221 Fax: (315) 456-1793
EP5-131 MD-11A, Electronics Park, Liverpool, NY 13088
sufficient resolution. You will need to amplify and condition thermocouple
outputs for input to almost anything. You could spend your days working on
an op amp solution, then you would still need to figure out some filtering.
Chips like the AD594/5 do all this for you. Although the millivolt output is
small, it's more workable than microvolts, it will be fairly linear, and it
won't be noisy. I wouldn't discourage anyone from trying, but why re-invent
the wheel? People much smarter than all of us gave up on this years ago, and
developed the T/C input processors we see today.
Thermocouples are the tool of choice for industrial temp measurement for
scores of reasons. T/C input chips make them work for you easily at what is
still a much lower cost than most options. This method will still cost more
than $1.380, but it will get you where you need to be relatively
inexpensively, and in the same century.
On the other hand, if you find a way to input a T/C directly, please let the
world know...
Chris
> From: David Saum [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=gqO5MhToeFgGojMDB2VOTOraCpMQakxu_scO5eTZ7ZJ1_DTLv6HoihrGtGQV5wCLJJ9I_L7pqpAZenD1AQ]DSaum@i...[/url
> Sent: Thursday, July 26, 2001 10:13 AM
> Subject: [noparse][[/noparse]basicstamps] Re: RTD/Thermocouple transmitter?
> Here is another idea that does not require
> 4-20ma conversion.
> signal.
