Run Problem
I've been running a simple DC motor exercise program with no problem unless
I disconnect the 232 cable from my PC. The editor can be exited and my
program
still runs fine as long as the 232 cable is still plugged into the PC.
As soon as I disconnect, and try to run the program, it goes nuts firing
outputs indiscriminately.
Any thoughts?
thanks,
John Ruddock
program
Any thoughts?
thanks,
John Ruddock
Otherwise you can get spikes and the device might decide it is waiting for
input, or the "noise" of the disconnection is "programming" the device with
gibberish.
Otherwise check your electrical connections as well for ground problems.
Currently when the device is connected to the PC there is possibly of a
common ground between the Stamp, the computer and the power supply for your
motors that breaks when you unplug the RS-232 cable to the computer. You
then are getting ground voltage level shifts relative to the control logic
for your motors. I saw a lot of this with pinball games by one manufacturer
back in the 70's and 80's...
John :-#)#
>program
>Any thoughts?
>thanks,
>John Ruddock
>from the same email address that you subscribed. Text in the Subject and
>Body of the message will be ignored.
>Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
>Incoming mail is certified Virus Free.
>Checked by AVG anti-virus system (http://www.grisoft.com).
>Version: 6.0.265 / Virus Database: 137 - Release Date: 18/07/2001
Outgoing mail is certified Virus Free.
Thanks for the advice.
What I realized after you mentioned noise was that I was unplugging my 6'
long RS232 cable from my notebook
but leaving it plugged into the stamp. I unplugged at the stamp and it now
comes up running every time.
Maybe this info will help others. The stamp must be very susceptible to
noise.
thanks,
John Ruddock
Sent: Tuesday, July 24, 2001 7:39 PM
Subject: Re: [noparse][[/noparse]basicstamps] Run Problem
> Are you turning off the Stamp, disconnecting it, then turning it back on?
with
> gibberish.
your
manufacturer
> John :-#)#
unless
> >program
> >Any thoughts?
> >thanks,
> >John Ruddock
acting as an antenna and picking up noise. This noise on the ATN line
causes the stamp to experience spurious, 'random' resets.
Aaron
On Tue, 24 Jul 2001 18:54:25 -0500 "John Ruddock" <ruddock@a...>
writes:
> unless
> my
> program
> PC.
> firing
> Any thoughts?
> thanks,
> John Ruddock
