Help with a formula
Hello Group:
I have a big problem, I need to read a value and apply
the following formula to this value:
a=4.427157*SQR(x/3.14)
How can I do that Maybe I need a math cooprocesor or
something like that.
Please Help me.
Alberto Zamora Estrada.
Phone: (506) 220-6736.
Cell: (506) 374-3846.
Fax: (506) 220-8684
Investigaci
Please Help me.
Fax: (506) 220-8684
Investigaci
If you use a calculator to get rid of the SQR(1/3.14) you find
a = 2.498389 * SQR(x)
This is almost 2.5 * SQR(x) (-0.064% deviation)
If you can live with that use a = 5 * SQR(x) / 2 and see if that is accurate
enough.
Otherwise you must use floating point math or a copressor.
Take a look http://www.emesystems.com/BS2math6.htm for double precision
math.
Greetings peter
Oorspronkelijk bericht
Van: Alberto Zamora [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=syR8AVvn8IbKCIist6EaUC1JsBacvzmINN9G1dSk6AS_aczmByc6yjlzP4aKmKss6f-VrJw2ZTI5kTQxyg]azestrada@y...[/url
Verzonden: maandag 23 juli 2001 18:08
Aan: Grupo Basic Stamp
Onderwerp: [noparse][[/noparse]basicstamps] Help with a formula
Hello Group:
Please Help me.
Fax: (506) 220-8684
Investigaci
It is important to know the range of x, as well as how
you will be using 'a' later. Since the Stamp deals
only in integers, errors can accumulate quickly.
Remember that sqrt(x) * sqrt(y) == sqrt(xy). So
instead of figuring out the square root of x/3.14 and
multiplying by 4.427157, we can consolidate the right
side as sqrt(4.427157*4.427157*x/3.14). This
simplifies to about 6.24195 * x.
The ** operator, which Tracy at emesystems.com
explains very thoroughly, works well for fractions.
Removing the whole part of 6.24195 and multiplying the
fraction by 65535 gives a product of 15856, which we
can use with the ** operator. Some additional math
and trial-and-error tells us that the value of x can
be 0 to 10499 with this argument of **.
The code looks like this:
'{$STAMP BS2} ' change for BS2e/sx/p
x VAR WORD
a VAR WORD
FOR x = 0 TO 99
a = (x * 6) + (x ** 15856)
a = SQR a
DEBUG DEC x, " ", DEC a, CR
NEXT
This works well if you only need the integer, but if
that were the case 2.5 * sqrt(x) would have been fine.
You may want a value to be used with **, for instance,
and in that case the range of x becomes more
important. Check out what Tracy has on square roots
and come back if we can help more.
By the way, if the 3.14 in your formula should really
be pi, use 15649 where I used 15656.
Bob Pence
--- Alberto Zamora <azestrada@y...> wrote:
> Hello Group:
> apply
> Please Help me.
> Fax: (506) 220-8684
> Investigaci
your X value is well-bounded and you don't mind the integer result.
However, you can very easily do this with a PAK-II or a PAK-IX (the PAK-IX
is just like a PAK-II but it also does 5 channels of 10-bit A/D conversion).
The PAK-I could do this, but it doesn't have a built-in square root (the
example code shows how to do square roots "manually" though). The PAK-II
also adds 16 I/O pins. The PAK-IX (which is on sale right now) adds 8
digital I/O along with the 5 analog inputs.
To realize your formula on the PAKs you'd use the FCONVERT program supplied
(or downloaded from our site) to convert 3.14 and 4.427157 into 4 byte hex
numbers. Then you'd load Y with the 3.14, and load X (an integer) into the
PAK's X register. You'd make a call to convert the integer into floating
point and then another call do do the divide. On the PAKII/IX you'd make yet
another call to do the square root. Finally, you'd load the 4.427157 into
the Y register and call multiply.
This would leave a floating point result in X. You could convert it to an
integer. Pick it apart digit by digit (good for display), convert it to IEEE
format, or just leave it in floating point format (not much good for the
Stamp). Also, you could scale it (say multiply by 10 or 100) and then
convert to an integer if you wanted to see some of the digits after the
decimal point in the Stamp.
You can find several examples at http://www.al-williams.com/awce/doclib.htm
and the main page at http://www.al-williams.com/awce/pak1.htm.
Good luck!
Al Williams
AWC
* Read 8 pulses at once
http://www.al-williams.com/awce/pak7.htm
> From: Alberto Zamora [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=z7CMYDX5e8CM2HDKIKP0syEQhzNJdIZG9rigU3aIpCRaFZ_EgkcdpJERTjX5AwOdwS7UXMLZTNr3FgA]azestrada@y...[/url
> Sent: Monday, July 23, 2001 12:08 PM
> To: Grupo Basic Stamp
> Subject: [noparse][[/noparse]basicstamps] Help with a formula
> Hello Group:
> Please Help me.
> Fax: (506) 220-8684
> Investigaci
