INEX-1000. Real newbee question
Just got a few days ago a INEX-100 from my father.
Trying to figure out the schematics of the Scott Edwards Book "Prog.
& custom. the BS comp.".
I just wonna make an easy AND instruction with two switches which
will light a LED in the AND configuration. But, the light is on when
the button switches are open and when pressing 1 of the 2 buttons,
the lights goes out. I had to change the AND to OR and then the
lights goes out when pressing the two buttons together. It is not
possible to change the ground of the LED on the INEX-100 board (which
is different then the drawing in the book, page 79).
I think it is right to state that when an output goes high it "sends"
a 5 V signal out and when it is low it sends a "grounded" signal (-).
Is there a command that can changes (invert) a logic 1 (input)to a 0?
Or is there another mutch easier solution. I tried almost 3 hours to
change the way of working.
Thanks.
Tim.
Thanks.
Tim.
The led on the INEX is turned by outputting a 1 on a stamp pin.
The switches read a 0 when they are pressed, so they have a pullup resistor.
Lets define those states.
Switchopen con 1 'normally open switches with pullup resistors, switches
close to GND
Switchclose con 0
Ledon con 1 'led plus series resistor between pin (anode) and GND (cathode)
Ledoff con 0
Switch1 var in1 'switch on pin1
Switch2 var in2 'switch on pin 2
Led var out0 'led on pin0
Led = ledoff
Output 0 'make led pin an output
Loop:
Led = (switch1 ^ switchopen) & (switch2 ^ switchopen) 'led on if both
switches closed
Goto loop
End
The expression (switch ^ switchopen) gives 0 if the switch is in the normal
open state, and 1 if the switch is activated.
This would also function in case of normally close switches. Tou just then
redefine the switch constants.
Hope this helps
Greetings peter
Oorspronkelijk bericht
Van: daliti [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=qwDBPXSzAQisJbaPUWkvTI4Q5cUrUeeM5TyVVuy0XjWsRh562UdQ_lQ3PQHGlB2EunXW_lUS3PPfybyQY_JNOdU]peter.christiaen@s...[/url
Verzonden: zaterdag 21 juli 2001 23:16
Aan: basicstamps@yahoogroups.com
Onderwerp: [noparse][[/noparse]basicstamps] INEX-1000. Real newbee question
Thanks.
Tim.
