Ming Transmitter - No Basic Stamp???
Hello all!
My question is for anyone with experience with the ming
transmitters/receivers. Is it possible to cause the transmitter to
transmit without use of a basic stamp? I would like to interface a
transmitter with a motion detector (Which gives an active high with
motion detected.) I hope to have several of these detectors notify a
basic stamp indoors when motion is detected. But for the sake of $$$
I really dont want to tie a stamp to each detector module.
Any Ideas?
Thanks all!
StampBoi
Any Ideas?
Thanks all!
StampBoi
would be better if you had a pic chip or bs1, something in each sensor, this
way you could send a code, and the code would tell what sensor is going off
. maybe a 555 set up in each sensor to oscillate at a different freq. so by
using pulsin you could read the pulse width of each sensor and know what one
is going off just a thought.
Sent: July 21, 2001 2:52 PM
Subject: [noparse][[/noparse]basicstamps] Ming Transmitter - No Basic Stamp???
| Hello all!
| Any Ideas?
| Thanks all!
| StampBoi
| To UNSUBSCRIBE, just send mail to:
| basicstamps-unsubscribe@yahoogroups.com
| from the same email address that you subscribed. Text in the Subject and
| Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
power applied. Check this page out. I gives a schematic for the
transmitter, using a Holtek HT-12E encoder and you use the Holtek decoder.
HT-12F or something. Here is the page. The encoder transmits a 12 bit
signal, 8 of which are ID bits. The other four are the "word". I use my
basic stamp to accept the 4 bit word that is decoded, and you can use one of
the basic stamp outputs to control whatever you want to. It a very simple
design and you only need one stamp. The Encoders and decoders only cost
about 1.79 each.
http://geocities.com/SiliconValley/Orchard/6633/rfremote.html
See the page above
Have fun!
Dave
Dave's Web Page: Designed for: D and D Import Cycles, Norfolk VA
http://www.danddimportcycles.com
Sent: Saturday, July 21, 2001 5:52 PM
> Hello all!
> Any Ideas?
> Thanks all!
> StampBoi
--- In basicstamps@y..., stampboi@y... wrote:
> Hello all!
a
> Any Ideas?
> Thanks all!
> StampBoi
though!
From: stampboi@y... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=PwIdFYjG4pqABTUCIFifCvsN5liEl-PV7lcQ3l961DTGDQlGn63KP98PtQL_T0d4FeYhW4LmRGUA]stampboi@y...[/url
Sent: Monday, July 23, 2001 7:00 AM
Subject: [noparse][[/noparse]basicstamps] Re: Ming Transmitter - No Basic Stamp???
Thanks Guys for all the help!!
> Hello all!
a
> Any Ideas?
> Thanks all!
> StampBoi
