EEPROM Full error
Hello,
I have worked with the STAMP2 for some time but I
have not had this error until now..My programs are
only about a 100 lines but I am using about 20 lines
of DEBUG Statements. I always get the error highlited
ion a debug statement. If I remove a couple of them
it works ok... Suggestions..
Thanks, Ray
Thanks, Ray
take up less room.
Sid
You can check on memory usage using CTRL-M
while in the Stamp editor. Remember, you only
have 2KB to work with, and having lots of text to
display will start eating up that memory in a hurry.
If you post your program to the list, I'm sure you'll
receive half a dozen great tips on how to streamline
your code. Another option would be to dump your
text to a serial EEPROM and just fetch it as needed.
I believe there are some examples of this in the Stamp
manual.
Best regards,
Steve
<<Hello,
Thanks, Ray·>>
> Ray, you might try using serout 16, commands instead of debug.
They seem to
> take up less room.
> Sid
Thanks Sid,
I did not realize that DEBUG took up
so much memory, I will have to redo
some of the program.
Ray.
statements is. I'm trying to cut down on mine with
subroutines for repeated items. For instance, three
times I have the statement:
DEBUG "To clear alarm, turn Mode switch to Off.", CR
By creating a labeled subroutine and making three
calls to it with GOSUB, the bytes consumed are reduced
from 222 to 96 (and to 73 if I can be less verbose).
This technique should help me stay within the margins
of the program slots I'm already using, since I'm
rather fond of my current implementation but must add
some features.
If you need minimal data to recover and are using the
BS2E/SX/P, consider using the shared memory area
(GET/PUT) and using an entire program slot for
messages. I have five or six data items I need to keep
track of (cycle number, process line, target
pressure), but could imagine calling a subroutine to
store these and then going to the message slot and
picking up when I return.
Bob Pence
--- rayw@m... wrote:
> Hello,
> highlited
> Thanks, Ray
> from the same email address that you subscribed.
> Text in the Subject and Body of the message will be
> ignored.
__________________________________________________
Do You Yahoo!?
Get personalized email addresses from Yahoo! Mail
http://personal.mail.yahoo.com/
Sent: Wednesday, July 18, 2001 1:20 PM
Subject: Re: [noparse][[/noparse]basicstamps] EEPROM Full error
> It's amazing how immense the space needed by DEBUG
> some features.
> Bob Pence
> > Hello,
> > highlited
> > Thanks, Ray
> > ignored.
> Do You Yahoo!?
> Reply,
Thanks Bob. Sub Routines seem like the way to go to save memory..
I will re do my programs to compensate.
Thanks Ray
Another way to save lots of space if you have lots of messages is to
store them in eeprom, and use a routine to read them out. Each
character in a literal string in a debug or serout command uses 14
bits of eeprom, while the same character stored in eeprom occupies
only 8 bits. Thus, you quickly reach a point where storage as DATA
in eeprom compensates for the small program routine it takes to read
it out.
alarm data "To clear alarm, turn Mode switch to Off.",13,0
aiuda data "call 911!",13,0
' subroutine to display message
' enter this subroutine with the start address of the message
display:
read address,char
if char=0 then displayexit
debug char
address=address+1
goto display
displayexit
return
Debug and serout are substantially the same. The debug command
automatically pushes the baudmode and the pin number onto the stack,
while in serout those values are fetched from the program eeprom and
then pushed on the internal expression stack. From then on out the
two commands are practically identical. For insight into how the
commands actually work, see Brian Forbes' book. It really gets into
the nitty gritty of this stuff.
-- regards,
Thomas Tracy Allen Ph.D.
mailto:tracy@e...
http://www.emesystems.com
>some features.
In testing with the Memory Map in stampw.exe version
1.1, I find only incidental differences in memory
consumption between DEBUG and SEROUT 16 statements. In
my small data set, it appears that one does not
consistently take more space than another.
SEROUT offers the advantage of transmitting
configurations other than 8N1 @ 9600, while DEBUG has
the advantage of opening up the debug window in the
Stamp Editor, rather than using Hyperterminal.
Bob Pence
> instead of debug. They seem to
> take up less room.
> Sid
> ignored.
Do You Yahoo!?
bobpence_2000@y... writes:
You can still use the DEBUG window(s) with SEROUT 16. You just need to open
a window manually (when the editor sees DEBUG in the code you just
downloaded, this happens automatically) and set the baud parameters to match
your program. I do this all the time -- saves the trouble of running a
separate terminal program.
-- Jon Williams
