Help building range unit
Hello,
I'm fairly new to Basic stamps and even electronics as a whole, but
my latest project (converting my old RC tank w/shorted out circuit
board into a high-speed all-terrain robot) is coming along quite
well. I have the LCD dislpay for feedback, switches and pushbuttons,
the microcontroller, and the motors are already built in. My motor
control and voltage regulator chips should hopefully be here in a few
days. that leaves one thing: range detection and obstacle
avoidance.
A while ago I purchased 2 Radio Shack infrared modules (276-137b) and
have found them useful for basic proximity detection at a set
distance. I believe they can be modified, however, by soldering a
wire directly to the infrared detector inside of the unit. Does
anyone have experience with changing these devices into range sensing
units?
I also noticed that Radio Shack has ultrasonic transucer senders and
recievers on their web page for $5 each. does anyone know how to use
these in a range sensing system?
If there are any other reccomendations for sensors I would really
like to know. I basically would like to have my robot to detect at
least 8 feet ahead, and have a 90* sweep using a stepper motor or
servo.
Thanks!
avoidance.
units?
servo.
Thanks!
http://www.acroname.com/index.html
They have many differant sensors for robots that will run with the basic
stamps. They also have working basic stamp code examples for each sensor
they sell. click on the link that says SENSORS under the "Our products" window.
I would recommend the Devontech Range sensor. It is an excellent sensor and
will pick up narrow obstacles that many other sensors will not.
At 07:44 PM 7/17/2001 -0000, you wrote:
>Hello,
>avoidance.
>units?
>servo.
>Thanks!
>from the same email address that you subscribed. Text in the Subject and
>Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
Sincerely
Kerry
Admin@M...
WWW server hosting [url=Http://mntnweb.com]Http://mntnweb.com[/url]
Kerry Barlow
p.o. box 21
kirkwood ny
13795
little while ago! That fits my specification perfectly! It's small,
should mount easily on a stepper motor for rotation, and
inexpensive! Thanks, i'll probably order one next week.
If there's any other reccomended sensors, I would still appreciate
the input, though this sensor looks really good!
--- In basicstamps@y..., Kerry Barlow <admin@m...> wrote:
> A great place to start is the Acroname website
basic
sensor
products" window.
sensor and
ultrasonic transudcers alone (without the board) with some form of
oscillation (555-timer circuit or crystal) and BASIC Stamp code,
maybe using the RCTime command? I know the kits don't cost much and
would be more efficient, but I want the transmitter to be placed a
few inches away from the reciever, and I definitely don't want to
start desoldering a pre-made board. I'll use a pre-made one if
necessary, but i'd prefer to have the scanning part as small as
possible. Thanks!
