CRT controller(?)
Hi all,
I've got two Toshiba TLC-271A rasterscan LCD displays for which I hope to
find a 'simple' interface.
These LCD's are 3 1/4" x 10" in size, 480x128 dots (or 80x16 chars) and they
are controlled by
four signals:
Clock (typical clockperiod 0.25 microseconds)
Data (new pixelvalue on/off outputted on each clockpulse)
Horizontal sync (typical period 250 microseconds, 244 us high, 6 us low)
Vertical sync (typical period 16 milliseconds, 0.25 ms low, 15.75 ms high)
I know the stamp can't handle that clockrate, but perhaps anybody knows of a
microcontroller(?)
that I could place between the stamp and the LCD.
I got a schematic build around a MC6845 CRT controller but I find that too
complex.
I ran a little testprogram using four datalines from the PC parallel port
and did manage to get some
picture. What I got was a moving black dot across the screen. Obviously the
clockrate output of
my program was far too low, but it showed me that the LCD's do function.
What I had in mind was to store the LCD bitmap in a 8K ram, and let a
microcontroller
generate the four required signals.
Anybody any suggestions?
Thanks.
Greetings peter
are controlled by
four signals:
microcontroller(?)
complex.
clockrate output of
microcontroller
Thanks.
Greetings peter
IP2022 would be good at. Have a look at:
http://www.brouhaha.com/~eric/ubicom/servid/
to see what is possible.
Chris.
> From: Peter Verkaik [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=nEpsZIjoDQ47sbD3bMQcmYKD9Gf7WE4BooympT3jYXbuFxXz5T1s4yxeLmCYOnCeFtOiWsd4DtmoCxqaM-ilQjw]peterverkaik@b...[/url
> Sent: Thursday, July 12, 2001 11:32 AM
> Subject: [noparse][[/noparse]basicstamps] CRT controller(?)
> Hi all,
> which I hope to
> chars) and they
> are controlled by
> four signals:
> high, 6 us low)
> 15.75 ms high)
> anybody knows of a
> microcontroller(?)
> find that too
> complex.
> parallel port
> Obviously the
> clockrate output of
> do function.
> microcontroller
> Thanks.
> Greetings peter
> from the same email address that you subscribed. Text in the
