SPI interface
While we are on the subject of SPI interfaces, I have
been having quite a
difficult time interfacing with a serial LCD display.
The LCD is made by
Crystalfontz, here is a link to the specs
http://www.crystalfontz.com/products/632/index.html .
I have put the unit
into SPI mode and can't seem to successfully send any
data. What shows up on
the screen seems to be random jumble and is not always
the same length of
characters I have sent. I have tried every combination
of coding I can
think of. I even tried inverting the clock signal.
Some of the code I have
tried is listed below. (The program I wrote tries to
display a portion of
the ascii table in order) I am running Win 2k if it
matters. Has anyone had
success with serial LCD interface? Thanks!!
-Nick
DataP con 0 'Data Pin to Ser Disp
Clock con 1 'Shift Clock to Ser Disp
Command var byte
loop var byte
TOP:
for loop = 0 to 127
debug " sending=",loop," "
PAUSE 200
Command=loop
Shiftout DataP,Clock,msbfirst,[noparse][[/noparse]Command\8] 'Send ASCII
character
next
TheEnd:
goto TheEnd
__________________________________________________
Do You Yahoo!?
Get personalized email addresses from Yahoo! Mail
http://personal.mail.yahoo.com/
been having quite a
The LCD is made by
I have put the unit
the same length of
of coding I can
-Nick
Command var byte
loop var byte
TOP:
for loop = 0 to 127
PAUSE 200
Command=loop
character
next
TheEnd:
goto TheEnd
Do You Yahoo!?
not shiftout
> been having quite a
> The LCD is made by
> I have put the unit
> the same length of
> of coding I can
> -Nick
> Command var byte
> loop var byte
> TOP:
> for loop = 0 to 127
> PAUSE 200
> Command=loop
> character
> next
> TheEnd:
> goto TheEnd
> Do You Yahoo!?
Your link references to serial displays that also offer SPI mode at 18kHz.
The stamp shiftout command operates at a significantly higher frequency.
Try to set the clocksignal yourself low and high while shifting out the
data.
Use pause statement to get the required timing. That should do it.
Under features I find
Low speed "SPI" (Fclk max=18KHz) and "Inverted TTL" RS-232 for embedded
applications
Why not use inverted TTL RS232. This would mean you can use the SEROUT
command
using a single stamp I/O pin. Just a thought.
Greetings peter
Oorspronkelijk bericht
Van: Nick H [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=83qVPTU0UF-eOZeMckIjjCDWp4IOFBFMZ73k8Gf9ZVoY8hmuCTrO1l1VaUSjdWfoSIy_kJ962W3ZCYAofA]lightclb@y...[/url
Verzonden: woensdag 11 juli 2001 15:53
Aan: basicstamps@yahoogroups.com
Onderwerp: [noparse][[/noparse]basicstamps] SPI interface
been having quite a
The LCD is made by
I have put the unit
the same length of
of coding I can
-Nick
Command var byte
loop var byte
TOP:
for loop = 0 to 127
PAUSE 200
Command=loop
character
next
TheEnd:
goto TheEnd
Do You Yahoo!?
SPI. I didn't want to have to get a Serial
Communications chip. Thats why I did't use the serial
interface. Thanks though!!
-Nick
Sent: Wednesday, July 11, 2001 8:09 AM
Subject: Re: [noparse][[/noparse]basicstamps] SPI interface
> Nick I looked at your display it uses RS232 Serial
data so try using Serout
> not shiftout
have
> > been having quite a
display.
> > The LCD is made by
> > I have put the unit
any
always
> > the same length of
combination
> > of coding I can
to
it
> > -Nick
> > Command var byte
> > loop var byte
> > TOP:
> > for loop = 0 to 127
> > PAUSE 200
> > Command=loop
ASCII
> > character
> > next
> > TheEnd:
> > goto TheEnd
> > Do You Yahoo!?
Text in the Subject and Body of the message will be
ignored.
ignored.
Do You Yahoo!?
fine with one stamp pin 0 to 5 vdc
Nick H wrote:
> It can also be configured via jumpers(solder) to use
> -Nick
> From: "L .Gaminde" <lgaminde@t...>
> > not shiftout
> have
> > > been having quite a
> display.
> > > The LCD is made by
> > > I have put the unit
> any
> always
> > > the same length of
> combination
> > > of coding I can
> to
> it
> > > -Nick
> > > Command var byte
> > > loop var byte
> > > TOP:
> > > for loop = 0 to 127
> > > PAUSE 200
> > > Command=loop
> ASCII
> > > character
> > > next
> > > TheEnd:
> > > goto TheEnd
> > > Do You Yahoo!?
> ignored.
> ignored.
> Do You Yahoo!?
I agree with L. Gaminde, if you use the inverted TTL RS232 option that was
mentioned in the features
(as was the SPI), there is no need for a RS232 level converter chip. Inverse
TTL RS232 should work
fine directly on a stamp I/O pin using SEROUT.
Greetings peter
Van: Nick H [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=WGGSVbNpHz1UxO9a7OC5wmDrqgiu0P7I2oS_LkTFxkkh_KGljRlNM37-HNxVUFnzuuB3kosw-AzXDg]lightclb@y...[/url
Verzonden: woensdag 11 juli 2001 16:33
Onderwerp: Re: [noparse][[/noparse]basicstamps] SPI interface
-Nick
> not shiftout
have
> > been having quite a
display.
> > The LCD is made by
> > I have put the unit
any
always
> > the same length of
combination
> > of coding I can
to
it
> > -Nick
> > Command var byte
> > loop var byte
> > TOP:
> > for loop = 0 to 127
> > PAUSE 200
> > Command=loop
ASCII
> > character
> > next
> > TheEnd:
> > goto TheEnd
> > Do You Yahoo!?
ignored.
ignored.
Do You Yahoo!?
SPI because I didn't want to have to use a serial communications chip. The
Serial display is set to the right mode. Thanks anyway!!
-Nick
> Nick I looked at your display it uses RS232 Serial data so try using
Serout
> not shiftout
> > been having quite a
> > The LCD is made by
> > I have put the unit
> > the same length of
> > of coding I can
> > -Nick
> > Command var byte
> > loop var byte
> > TOP:
> > for loop = 0 to 127
> > PAUSE 200
> > Command=loop
> > character
> > next
> > TheEnd:
> > goto TheEnd
> > Do You Yahoo!?
_________________________________________________________
Do You Yahoo!?
Get your free @yahoo.com address at http://mail.yahoo.com
