Ground Problems
Archiver
Hi ,
I have been working on a project where I get an external input from
a source. I am reading this value using the "input" function. Using
this function I read the length of zero and length of high signal.
When I do not get any input the signal has to read zero, but it keeps
reading random values. I guess this might be because of the
difference in ground between the input signal and the power supply(I
use a seperate power supply for both). Please help me solve this
problem.
Mohammed
problem.
Mohammed
>problem.
If you want an input pin to always read low (or high) when no signal is
present, you need to pull it low (or high) with a resistor connected to
ground (or +5 volts). A 10K ohm resistor should do the job unless your
signal source is exceptionally weak.
Jim H
I will check it out right away
Mohammed
--- In basicstamps@y..., Jim Higgins <HigginsJ@s...> wrote:
from
keeps
(I
> >problem.
signal is
connected to
your
> Jim H
Problem Solved. I tied the two grounds together and added a 10k
resistor. Works perfectly.
Thank You
Mohammed
--- In basicstamps@y..., "Amin" <md_amin_99@y...> wrote:
> Hi ,
from
keeps
(I
> problem.
> Thanks
> Mohammed
>Hi All,
Excellent! Thanks for letting us know what worked.
Jim H
This might sound really wierd , but the stamp was working as it
was supposed to till today. now it has the same problem. Only this
time it does not read any input at all unless i ground the stamp
externally. If I see the operation through the debugger it works
right, but when u remove the ground pin from the parallel port,It
does not read any input. what do u think is the problemo..
Mohammed
> At 18:04 07/10/01, Amin wrote:
> >Hi All,
> Jim H
