Question on stepper control — Parallax Forums
edited 2001-07-10 22:34 in General Discussion
Hello fellow Stampers,
My question is, can you control several stepper motors at the same
time with a Basic Stamp II? Would I need someting like Al William's
PAK VIII or something?
Thanks in advance!!!
Frank G.
    edited 2001-07-09 22:05
    You may run into timing problems if you have alot of code in your program
    loop that runs the servos. Servos like to see pulses every so often,
    otherwise they don't move properly. Chances are you would not have a problem
    unless you were monitoring alot of sensors and doing alot of math. Might
    look at the BOEBOT code to see how they work this out.
    I pondered this on one robot and offloaded the servo control to a BS1 -- all
    it does is receive a direction command from a BS2 and make the servos go
    that way.
    edited 2001-07-09 22:07
    Controlling 2 bipolar steppers would commit at least 8 I/O stamp
    pins. Having the stamp drive the steppers is a waste of resources.
    There are chips that simply require clock pulses and direction
    control. These chips work closely with driver chips, usually
    containing a few H-bridges. Some chips contain both the logic and
    drivers.
    You are not going to interface a stamp directly to a stepper. Doing
    so would kill it.
    So you're still going to need a bunch of pieces parts in between the
    stepper and the stamp. Might as well off-load the logic required to
    turn off the motor coils to a chip designed to do just that...
    If all you want to do is spin around some steppers you may not even
    need a stamp. Especially if you're willing to use the motors in a
    unipolar mode (5,6 or 8 wire motors can do this)
    Generate some pulses using a 555 (or whatever) 555 output pulses =
    4017 clock pulses. 4017 outputs as follows:
    Q0 = coil 1
    Q1 = coil 2
    Q3 = coil 3
    Q4 = coil 4
    Again, the 4017 decade counter does not have the oomph necessary to
    drive a stepper. The 4017 should turn on transistors which actually
    switch off and on the stepper coils. Using the 555 would also allow
    for speed control and reset.
    If you could get away with this the job could be done for about two
    bucks, not including the stepper.
    Despite the rantings of some, the 555 and 4017 are both (very) easy
    chips to use. There is a ton of data to be found out there. If this
    interests you, and you would like more specific information, please
    don't hesitate to ask.
    Regards
    Rich
    William's
    > Frank G.
    edited 2001-07-09 22:20
    DOH! I saw stepper and read servo. My bad!
    > pins.
    > William's
    edited 2001-07-10 06:23
    Rich,
    I do realize that I have to have some electronics between the stamp
    and the stepper. Now don't quote me. I am quite the novice when it
    comes to electronics. With the correct electronics between the stamp
    and the stepper. Couldn't I use one output pin to control the
    stepper. One pulse, One step. The quicker I send the pulses, the
    quicker the stepper moves from step to step. Wouldn't I have
    complete control as to how many steps to rotate the motor?
    > Q0 = coil 1
    > Q1 = coil 2
    > Q3 = coil 3
    > Q4 = coil 4
    Couldn't I substitute the pulses generated by the 555 for the output
    pin of my Stamp? That way I could use one pin for each motor.
    With that in mind, I guess I would be able to run several steppers
    with the right electronics of course.
    Has anyone tried this before? Was there any major timing problems
    with this kind of set up?
    I would like to see some more information about the decade counter
    and transistors. I have searched for some info, but with little
    progress. Do any of you have any schematics laying around with this
    555,4017,transistor set up for stepper control?
    Thanks again for all the help......
    > Regards
    > Rich
    > Frank G.
    edited 2001-07-10 09:49
    At 7/9/2001 Monday 04:17 PM, fwankg@y... promulgated:
    >Frank G.
    Hi Frank -
    You may want to take a look at the ELABS web site: http://www.elabinc.com/
    and take a look at their Stepper Motor Controller ICs. The EDE-1200 (Unipolar)
    or the EDE-1204 (Bi-Polar). All of the information required can be found in
    the data sheets and in the applications notes.
    Alternatively, you may wish to ask for their CD. The CD contains all of their
    products.
    Bruce Bates
    edited 2001-07-10 15:04
    Absolutely
    One thing, if you want the maximum torque available the stepper
    should be driven in its bipolar mode. In this mode all the coils are
    energised. To do this you need an H -bridge for a driver, and you
    need the logic to control the H bridge. An H bridge has to be very
    carefully controlled. If not, BOOM. This requires a bunch of parts.
    If you don't need the max torque the motor can provide then the
    stepper can be operated in its unipolar mode. Here, the stepper coils
    turn on and off, the polarity of the coils is not reversed, as in
    bipolar operation.
    Anyway, if unipolar operation is ok then your plan is a good, easy
    one. Select a pin on the stamp to provide pulses, input these pulses
    into a 4017 decade counter, or to a stepper controller IC (I don't
    know the part numbers offhand, data is at home, I'm at work. If you
    need the info I'll bring it in tomorrow, let me know).
    I like the 4017 plan because it's DIRT cheap, and will get the job
    done. All it takes is the 4017, 4 transistors, 4 resistors and
    diodes. Cheap radio shack parts.
    Come to think of it, there is a stepper controller that has all the
    logic built in, as well as the drivers. This is a bipolar (nice)
    controller, full/half step, direction control. 3 stamp pins,
    clock,enable,direction (I think) I'll see if I can remember what chip
    that was I saw. Maybe someone out here will see this and cough up the
    part number of the chip I'm thinking of. If not, I'll get it for you.
    I will email you with the part numbers and more info later today or
    tomorrow AM
    Regards
    Rich
    > Rich,
    it
    stamp
    > > Q0 = coil 1
    > > Q1 = coil 2
    > > Q3 = coil 3
    > > Q4 = coil 4
    output
    to
    actually
    this
    easy
    this
    please
    > > Regards
    > > Rich
    > > Frank G.
    edited 2001-07-10 21:57
    Rich,
    Thanks for all the help! I would like to see the information you
    have on the 4017 plan. But for what I'm doing, I think I am going to
    need full torque from the steppers. I would appreciate if you did e-
    mail me the information. Thanks
    Frank G.
    > Absolutely
    are
    coils
    > bipolar operation.
    pulses
    chip
    the
    you.
    > tomorrow AM
    > Regards
    > Rich
    stamp
    resources.
    > > Rich,
    stamp
    > it
    > stamp
    the
    pulses
    > > > Q0 = coil 1
    > > > Q1 = coil 2
    > > > Q3 = coil 3
    > > > Q4 = coil 4
    > output
    steppers
    problems
    necessary
    > to
    > actually
    counter
    > this
    > easy
    > this
    > please
    > > > Regards
    > > > Rich
    > > > Frank G.
    No problem, Frank.
    There was a reply to your query recommending this website
    http://www.elabinc.com/ as a source for bipolar stepper motor
    drivers. Take a peek, they do provide data sheets. I'll bring in some
    stuff and email you with some more info
    Regards
    Rich
    > Rich,
    to
    e-
    > Frank G.
    > > Absolutely
    > are
    very
    parts.
    > coils
    > > bipolar operation.
    easy
    > pulses
    don't
    you
    job
    the
    > chip
    > the
    > you.
    > > tomorrow AM
    > > Regards
    > > Rich
    > stamp
    > resources.
    > > > Rich,
    > stamp
    when
    > > it
    > > stamp
    > the
    > pulses
    > > > > Q0 = coil 1
    > > > > Q1 = coil 2
    > > > > Q3 = coil 3
    > > > > Q4 = coil 4
    > > output
    > steppers
    > problems
    > necessary
    > > to
    > > actually
    > counter
    little
    > > this
    (very)
    > > easy
    If
    > > this
    > > please
    > > > > Regards
    > > > > Rich
    > > > > Frank G.
