Prox sensor MORE DETAIL
All getting a bit complex....
The ONLY info we need is a go/no-go level at a certain point to indiacted
whern the level in the silo falls below a certain point. The type of product
varies in size and density regularly.
Sent: Monday, July 09, 2001 4:42 AM
Subject: [noparse][[/noparse]basicstamps] Re: RE:Prox sensor
> I'm not sure the goal has been well established yet.
> Is this silo used to store this material exclusively? If so,
> could you use sonar to determine the presence of this material
> and a the volume as well?
> George B.
> --- In basicstamps@y..., s premena <premzee@j...> wrote:
> > It would help if you could give the minimum amount of weight
> > you need to detect. And what sort of granular size.
> > For reliable detection I'd suggest some sort of vibrating
> > assembly [noparse][[/noparse]could be piezo] - the frequency and energy it
> > takes to drive it would vary as it was surrounded with
> > material. This assumes that the sensor enclosure material is
> > flexible. The vibration would also tend to clean dust off.
> > Is the stuff flammable? [noparse][[/noparse]static electric charge could be
> > an issue].
> > For just pressure you could have a capacitive bridge with
> > grounded outer plates which would squeeze toward an inner
> > plate. Here the issue would be what would stay uniform over
> > time squeezing and un squeezing. Perhaps silicone rubber
> > between aluminum plates would work.
> > Interlink Electronics has resistive material which changes
> > with pressure on it.
> > There are membrane elastomers used in keyboards which change
> > resistance with pressure.
> > Without knowing how much pressure - min and max - you are
> > trying to work with it's all up in the guessing region.
> > Date: Fri, 6 Jul 2001 08:28:42 +0930
> > From: "Tim Stockman, STOCKMAN ELECTRONICS" <stocky@c...>
> > I am looking for a circuit that will be suitable to detect the
> presence
> > of a granular fertilizer in a storage silo. Just need a go/no-go
> type
> > output eg whether the sensor is covered or not.
> > ________________________________________________________________
> > GET INTERNET ACCESS FROM JUNO!
> > Juno offers FREE or PREMIUM Internet access for less!
> > Join Juno today! For your FREE software, visit:
> > http://dl.www.juno.com/get/tagj.
> George B.
> > an issue].
> presence
> type
switch or hall-effect sensor on the outside is the most simple solution.
product
in brief:
LED emitter | silo | LED Detector
Daniel
From: Tim Stockman, STOCKMAN ELECTRONICS [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=IyiEPq6oc3q7uJd7S4K6zODgF5H6xYs0qb0gDMFN8pNTiXlRK65uTDZSdbHaaenKwEo1tTJIs5Hgop_EnMw]stocky@c...[/url
Sent: Sunday, 08 July 2001 20:26
Subject: Re: [noparse][[/noparse]basicstamps] Re: RE:Prox sensor MORE DETAIL
> George B.
> > an issue].
> presence
> type
Do You Yahoo!?
Get your free @yahoo.com address at http://mail.yahoo.com
for large ice making machines. The device has an IR transmitter/ receiver
pair mounted side by side. When the medium is close enough (ice in my case),
the reflection of the IR transmitter is picked up by the IR receiver,
closing a dry contact or a transistor depending on the model.
Brad Watts / AMT
E-mail BradWatts@a...
Web www.amt.nb.ca
From: D. Daniel McGlothin [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=oaa2joAsS5ilqNHG5lruXh1Jn5Sd8luHsCWShaTl2EolVAQzAlaOfmDBFjf6LsQQc2jEh3QYZs7NQQ]ddm_stamps@y...[/url
Sent: Monday, July 09, 2001 9:44 AM
Subject: RE: [noparse][[/noparse]basicstamps] Re: RE:Prox sensor MORE DETAIL
Would a simple through-beam photo-sensor work?
in brief:
Daniel
From: Tim Stockman, STOCKMAN ELECTRONICS [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=XxUBtoUw-gxNrANO28aA2zw7nGPq61vvoxBlUFFzkfsZdM9ZyXdDnMR-ESQ2AeaF8roiN0ohNzXaDknGEQ]stocky@c...[/url
> George B.
> > an issue].
> presence
> type
Do You Yahoo!?
contain dust that could coat lenses or windows making a light device
less reliable unless some type of self cleaning device is
incorporated.... which would up the cost and lower the reliability.
In addition, some fertilizers "clump" if the moisture content is not
controlled. At this point, this is unknown and has to be taken into
account. Can you engineer an (inexpensive) mechanical device that
would shake off this potentially corrosive stuff and assure it was
not present when the silo level is lowered?
If a sonar device were mounted high in the silo, you could sense any
level you wished and gather even more data than you require today.
But more importantly, your sensors would be up out of these elements
where they can more readily cope with such an environment.
George B.
--- In basicstamps@y..., "Brad Watts" <bradwatts@b...> wrote:
> I have used Omron proximity sensors for sensing when their was
enough ice
receiver
my case),
receiver,
> Brad Watts / AMT
> Web www.amt.nb.ca
> From: D. Daniel McGlothin [noparse][[/noparse]mailto:ddm_stamps@y...]
> To: basicstamps@y...
> in brief:
> Daniel
> From: Tim Stockman, STOCKMAN ELECTRONICS [noparse][[/noparse]mailto:stocky@c...]
indiacted
of product
> From: <gbrecke@y...>
> To: <basicstamps@y...>
> > George B.
> > > an issue].
> > presence
go
> > type
> > basicstamps-unsubscribe@y...
Subject and
Subject and
> Do You Yahoo!?
Subject and
not work. I would think the fertilizer dust / moisture would tend to corrode
the metal diaphragm found in most ultrasonic transducers.
What about a piece of pipe with a hole in it every so often. Pump air into
the pipe at a known rate of flow and monitor the pressure. The higher the
level of material, the higher the pressure. Of course you would have to
figure out how to keep the material out of the hole.
> This environment appears to be a nasty one. The materials probably
to guage distance. I would think that was a fairly lousy environment
for a piece of metal... so maybe it uses a stainless diaphragm or
at least a powder coated one??
--- In basicstamps@y..., Rodent <daweasel@s...> wrote:
> Unless they make a sonar unit with a plastic diaphragm, this
probably would
to corrode
air into
higher the
have to
device
reliability.
not
into
any
elements
corrosive, but it attracts moisture. In a silo alot of dust would be
created, which would find its way onto any exposed metal. Stainless would
probably hold up well, assuming you can find a transducer with a stainless
diaphragm.
> They mount some form of ultrasonic transducer on the back of trucks
> probably would
> to corrode
> air into
> higher the
> have to
> device
> reliability.
> not
> into
> any
> elements
