BS2 parallel comms
Thomas-
Asynchronous serial communication--SERIN, SEROUT e.g.--through
a (PC, right?) parallel port would be very problematic. The parallel
port doesn't have the supporting hardware to do the timing and
parallel <--> serial conversion functions.
I'd search for a synchronous serial solution using clock, TX and RX
as you said, but using SHIFTIN and SHIFTOUT on the Stamp side.
See http://www.lvr.com/parport.htm for loads of good parallel port
info.
Steve
On 4 Jul 01 at 2:42, thomas_seeker@y... wrote:
> ...I'd like to use a parallel port to do SERIAL comms with my BS2.
> If I recall correctly, I've seen someone else do this by bit
> banging the parallel port to provide clock, TX and RX. I figure I
> can use SERIN / SEROUT on the stamp side...
info.
Steve
I've lurked on the list a long while, and learned alot.
But now a question for you gurus:
I can use SERIN / SEROUT on the stamp side (and TTL inversion),
but maybe some of you have seen something like this and could
provide a URL for the parallel port side of it?
Thomas
shifting in/out, but that's not hard:
DATAIN:
FOR n = 1 TO 8
awaitHighClock: IF CLK = 0 THEN awaitHighClock
in_byte = in_byte << 1 + TX_pin ' assumes MSB first
awaitLowClock: IF CLK = 1 THEN awaitLowClock
NEXT
LOW ACK
RETURN
Oughta work...
On 4 Jul 01 at 17:40, thomas_seeker@y... wrote:
> ...(Here's where I'm unclear on Stamp program flow) DATAIN: for n = 1
> to 8 wait for CLK LO '** Anybody have an elegant way to do this? get
> bit from (PCs TX)RX pin wait for CLK HI next 'loop until byte full
> low ACK 'Flow Control pin return 'to main program
> So perhaps I'm not looking for SERIN/OUT or SHIFTIN/OUT.
> Thomas-
parallel
> info.
> Regards,
> Steve
Steve,
Thanks for the quick reply.
The problem I have with the SHIFTIN / SHIFTOUT commands is that they
expect CLK to be a stamp output - I want to control CLK from the PCs
parallel port.
Example:
(PC program flow)
Bring CLK line HI 'Request Stamps attention
Wait for Flow Control to go HI 'Stamp response
Put first of 8 bits on TX line
Bring CLK LO
Delay
Bring CLK HI
Loop 'Until all data clocked out
Wait for Flow Control to go LO 'Stamp ACK
Bring CLK LO 'Idle State
etc.
(Stamp program flow)
If CLK = 1 then COMM
COMM:
high ACK 'Flow Control pin
DATAIN:
for n = 1 to 8
get bit from (PCs TX)RX pin
wait for CLK HI
Anyway, thats my general idea, feel free to laugh at it if you must.
I just didn't want to get into the serial port programming on the PC
(I only have one that I don't want to use for the BS2, but I HAVE got
some unused I/O bits on the 3 parallel ports I'm using)
Thomas
Sent: Wednesday, July 04, 2001 13:40
Subject: [noparse][[/noparse]basicstamps] Re: BS2 parallel comms
> --- In basicstamps@y..., "S Parkis" <parkiss@e...> wrote:
> > Thomas-
> parallel
> > info.
> > Regards,
> > Steve
> Steve,
> parallel port.
> Example:
> (PC program flow)
> Bring CLK LO
> Delay
> Bring CLK HI
> etc.
> COMM:
> DATAIN:
> for n = 1 to 8
> wait for CLK HI
> Thanks,
> Thomas
SHIFTIN/SHIFTOUT?
If so, look at http://www.al-williams.com/awce/pak4pc.htm
Al Williams
AWC
* 8 channels of PWM: http://www.al-williams.com/awce/pak5.htm
> From: S Parkis [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=Bxeq7Kz6RPmytCPwECuRNiNIIfh21QzpUQjpxAUILA353ApJohCZmXMCi1pm8MQrJIO0uOctu7tYkbMh-A2W]parkiss@e...[/url
> Sent: Wednesday, July 04, 2001 12:58 AM
> To: thomas_seeker@y...; basicstamps@yahoogroups.com
> Subject: Re: [noparse][[/noparse]basicstamps] Re: BS2 parallel comms
> If you want the PC to clock the data, you'll have to do your own
> DATAIN:
> FOR n = 1 TO 8
> NEXT
> LOW ACK
> RETURN
> Oughta work...
