Infared Circuit Question
I purchased a "Infared Emitter and Detector (1 pr)" Cat No. 276-142 from
Radio Shack. I can not get the emitter to work. The specs on the back of
the product says Reverse Voltage: 2V; Continous Forward Current: 40mA;
Radiant power Output: 0.5mW; Wavelength at Peak Emission: 915 nm. It does
not say anything about Forward Voltage - as the other LEDs I have purchased
do. I have been assuming 0.6 V in the formula to calculate my resistor
value ( 6v Supply - .6 ) / 40mA = 135.
I have a printed copy (somewhere) about someone's reference to infared
questions. It says that I can tune my radio to 540 AM and I should be able
to hear clicking noises if I hold up a remote control to it. Or that I can
use a cam corder to actually see the infared light from the remote control.
I have tried them both on the remote control for my TV - and it works.
I have tried connecting my Infared Emitter with a resistor; I've used a 555
timer - but nothing seems to be happening. On the 555 timer, I first got it
working with a normal LED, and then substituted my IR for the LED.
I don't have a lot of experience with electronincs. Any suggestions would
be appreciated in helping me with getting my IR to work.
Bryan Smith
Bryan Smith
forward voltage drop. May not work on some blue or white LEDs which can
be as high as 2-4V.
> Radio Shack. I can not get the emitter to work. The specs on the back of the
> product says Reverse Voltage: 2V; Continous Forward Current: 40mA; Radiant
> power Output: 0.5mW; Wavelength at Peak Emission: 915 nm. It does not say
> anything about Forward Voltage - as the other LEDs I have purchased do. I have
> been assuming 0.6 V in the formula to calculate my resistor value ( 6v Supply
> .6 ) / 40mA = 135.
resistor on it and
do some more testing. Nothing I do seems to make the IR emitter work.
Do you have any suggestions as to why the IR emitter does not seem to be
working ?
Have you used the Radio Shack matched pair - emitter/detector, or do you use
something else ?
Thanks for your previous input, I will try doing some more measurements as
you have suggested with the DVM.
==== Part of Original Message ====
> From: Mike DeMetz [noparse]/noparse]SMTP:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=EWjW6qqoh0paihIm9dFPuwMQU40nPI_-uFG-p-PsEv0O-oa3hutTSyji0aB6Rfntxg9LsPMfsZmO0azm]miked@t...[/url
> Sent: Tuesday, July 03, 2001 9:21 PM
> Subject: [noparse][[/noparse]basicstamps] Re: Infared Circuit Question
> Any modern digital DVM will have a Diode function that will show you the
> be as high as 2-4V.
> of the
> Radiant
> say
> I have
> Supply -
> > .6 ) / 40mA = 135.
> Body of the message will be ignored.
tolerance parts to get it to stay on frequency. I tried the deal in the
Parallax weekend kit I got, and it works really well. You use a Stamp 2 to
generate your signal for the I/R LED and use one of the Panasonic detectors
to detect it.
The camcorder trick with the I/R diodes does work. I have one of those
little cards from Radio Shack in my robot box that I use.
> I have tried various resistors; and I'm planning on putting a variable
> resistor on it and
> working ?
use
> something else ?
able
can
control.
555
it
correct way round? IR and visible light LED's often have the cathode
marked in opposite ways (IE, the short lead on a visible light LED
indicates cathode, but on an IR LED it indicates anode).
Original Message:
'snip...
> Or that I can use a cam corder to actually see the infared light from
> the remote control.
> works.
> used a 555 timer - but nothing seems to be happening. On the 555
Anode of my detector should be positive, but it does not say anything about
the emitter.
I will verify my circuit as you have indicated this evening. Thanks for
your input
> From: Peter Charles [noparse]/noparse]SMTP:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=G00PU5zjnGrPqEwPEEzcbkYaTfkIS1zgYu8KWOim647ITUrZrXX0neqFXVVozraa60x3epXrPDlqWmHsoBE]pcharles@m...[/url
> Sent: Thursday, July 05, 2001 10:21 AM
> Subject: Re: [noparse][[/noparse]basicstamps] Re: Infared Circuit Question
> Just a quick comment- are you sure you have the IR LED wired in the
> Original Message:
> 'snip...
> > the remote control.
> > works.
connect it to a resistor then to my power supply for a simple test ?
> From: Rodent [noparse]/noparse]SMTP:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=yMrmn7qACxCgIIjNRIB3-uFxNMd4G361pZOyF8syUCHgbnyTmT67hpIRkDVE0aEOxTr0rxMlt_uL5DA]daweasel@s...[/url
> Sent: Thursday, July 05, 2001 9:55 AM
> I tried the 555 circuit and it works so-so -- you have to use some tight
> detectors
> to detect it.
> > resistor on it and
> > working ?
> use
> > something else ?
> as
> able
> can
> control.
> 555
> got
> it
Yes, 38500 Hz is optimum frequency.
Sid - W4EKQ
should output I/R light. Your camcorder *may* see it -- I know the I/R
detector card from Radio Shack will.
Whether or not your detector will see it depends on the detector. If its a
simple phototransistor, it should see it. If its one of the I/R modules that
looks for a modulated signal it will not. Most of these detectors look for a
38 khz I/R beam -- constant I/R is ignored. If your receiver circuit works
with a TV remote, assume the problem is with the detector.
> Is there a certain frequency I must use to make the I/R LED work ? Can I
not
to
> > detectors
> > to detect it.
encoder/decoder chips. Way better than doing it with a 555. A snap to
use. Comes in IR and RF flavors.
I would hazard a guess and say these Holtek chips are the heart of
most of the IR remote control kits you see out there.(at a fraction
of the price). The chips are dirt cheap, require only a few external
components and are very easy to use. They will interface directly
with a STAMP as well as TTL.
Check it out at http://www.holtek.com. Follow the "consumer
products" link. The Radioshack.com commercial catalog also lists
these chips.
Back to work
BCNU
Ric
--- In basicstamps@y..., Rodent <daweasel@s...> wrote:
> You can power the LED from 5 volts DC (with the proper resistor)
and it
I/R
If its a
modules that
look for a
circuit works
work ? Can I
> not
test ?
some tight
deal in the
Stamp 2
> to
Panasonic
> > > detectors
> > > to detect it.
of those
> From: iceninevt@y... [noparse]/noparse]SMTP:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=XJXtvkn5w83MvcJJyF39MHiBzPwYEGMRpDyya6SGq9fpQqkCqkegkO_qtmj_3altjD35aNX4JrjA9ESEmQ]iceninevt@y...[/url
> Sent: Friday, July 06, 2001 3:38 PM
> If you really wanna do some cool IR stuff check put the HT-12 IR
> these chips.
> Back to work
> BCNU
> Ric
The HT-12A is an excellent IC for infrared remote control. This is what we
designed our original Fire-Stick I with. Here's a complete 2-page project
showing how to use the HT-12A with complete schematics for our original
Fire-Stick I: http://www.rentron.com/Fire-Stick-II.htm
This project shows how to pump-up the infrared LED for up to 100' operation
also.
-Bruce
webmaster@r...
