help shiftin
Hi Wayne,
>How does shiftin suppose to separate a constant line status from "real
data" being sent?
It doesn't. It pulses a clockline and reads a datapin. It is up to the user
to keep the datawords synchronized.
If you use the command with a HC597 (an 8-bit parallel-in serial-out
shiftregister) you should always shift in
8 bits at a time (or multiple of 8 bits if you feed the QH output to the SI
serial input). If you shift in any other
number of bits you have to keep track of where you are. The HC597 has an
escape though. After the latching
the serial register is loaded with fresh data.
What you should figure out is: is your data fixed-length (7 bits, 8 bits, 16
bits ??), starts each dataword with a leading
zero bit?? Is the data coded in some special way to mark the end (perhaps 3
trailing zero bits)?? The variations are numerous.
Have you tried hooking up a datalogger to the data and clock to see what
happens when you hit the board?
Hope this helps.
Greetings peter
data" being sent?
Hope this helps.
Greetings peter
what I was doing at that time. (Sorry I am learning as I go.)
Come to think of it, after series of test I noticed there were never more
than a total of 9 bits between and including the 1st 0 and the last 0.
But when doing my test back then I think I was loading the bits MSB/LSB in
the wrong order.
Could you tell me if you see anything wrong with this code example?
mybit var bit
mydata var byte
Loop:
Shiftin <datapin>, <clkpin>, MSBPOST, [noparse][[/noparse]mybit\1]
If mybit = 1 then Loop
Shiftin <datapin>, <clkpin>, MSBPOST, [noparse][[/noparse]mydata\8]
<do what ever with the data>
goto Loop
Wayne Fulcher
wayne@d...
From: Peter Verkaik [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=BfKSKmuvfgrlQwWrp3l0WPuMxtJtOpXxG5-6UuiS4Styb4uidkPW5veFg5HhClUE0hLAqOSkGqqyKIIlw0a9IbKcUnM]peterverkaik@b...[/url
Sent: Monday, July 02, 2001 2:14 PM
Subject: [noparse][[/noparse]basicstamps] RE: help shiftin
Hi Wayne,
data" being sent?
Hope this helps.
Greetings peter
from the same email address that you subscribed with. Text in the Subject
As your clockline never changes we can safely assume it is an input.
mybit var bit
mydata var byte
Loop:
Why not just wait for the dataline to get low? Sounds likely that the board
pulls the dataline low
to notify the presence of data.
Assuming P0 is your dataline:
Loop:
If in0=1 then loop
Now you can use shiftin to read data.
It is likely though you now have to pulse the clockline BEFORE you get the
real data
As you mentioned that the clockline stayed low, the clockpulse should
start with a rising edge.
Low <clkpin>
Debug bin data,cr
goto Loop
Or you can use a manual loop setting the clockline low and high yourself to
have control
over what happens and figure out exactly when to shift the data in.
The 8 bits seems reasonable though.
This might help
Greetings peter
>Good point but where do I find the data sheet for a Motorola chip? The card
>has 2 - 20 pin Motorola chips on it. (I don't have the part number with
me.)
>Do they have some type of web site that has the specs for all their chips?
>The manufactures of the dartboard of course don't want to help me because
>they feel it's their proprietary technology.
Try http://www.motorola.com
and use their search function.
Changes are however that those chips are specially programmed
(like GAL's) in which case you must proceed your current quest.
Hopefully one of those chips is a serial out chip.
Greetings peter.
