IR/555 Timer Question????
Archiver
Hello everyone?
Does anyone have a diagram/schematic of the IR Detector and 555 Timer
circuit? I want to be able to detect something that is between 4 and
6 feet away.
Thanks in advance,
Frank G.
6 feet away.
Thanks in advance,
Frank G.
> 6 feet away.
Drive an infrared LED with a 555, running at 38Khz (or 36Khz, not
sure) Anyway, I think 38Khz is the frequency almost all IR remotes
operate on. Detect the modulated IR with an IR detector module
(RatShack has 'em) This module will reject everything except IR
modulated at the correct frequency (again, off the top of my head, I
think 38Khz)
The easy way:
The IR receiver module will output data when it "sees" IR from any IR
remote you have laying around. This data can be "smoothed" thru a
cap, buffered through a transistor, and you're done.
This may be a good opportunity for you guys to play around with the
Holtek IR encoder/decoder chips (The heart of many remotes and garage
door openers) The holtek chips come in IR and RF flavors...
Regards
Rich
--- In basicstamps@y..., Rodent <daweasel@s...> wrote:
> Glad you asked -- I need one also.
Timer
and
> > 6 feet away.
Do it like this:
sure)
<SNIP!>
> Timer
> and
> > > 6 feet away.
frequency of 38500. Range can be lowered by moving either side of that
frequency. If 38500 will not give you the distance you want with your
present IR transmitter then you need a transmitter with a little more power.
I don't think using the timer is not going to improve your distance because
you are using it only to generate a frequency.
Regards
Sid
Would you like me to build this project for you as well as design it
for you? You seem like a nice enough guy...
Sorry, Driving a 555 at 38Khz should not be to challenging. You know
what, I told you how I would do it. That should have been enough.
Instead of whining about my not giving you the fine details about
how to wire a 555, you should be thanking me for taking the time to
consider, and answer, your query.
You want to know how to wire a 555, go to ratshack and purchase the
mini engineers book about 555 applications. Get a datasheet from
National semiconductor, learn about the chip. The 555 is easy, trust
me.
I don't mean to be pompous, I received much help here, but, if you
consider my suggestions to be good ones, why not make it your
business to figure out how to use a 555? (one of the most versitale
chips ever made.) At 1/100 the cost of a BS2 it might really make
sense someday.
Next time I'll keep my suggestions to myself.
Ciao
> I think we grasp the concept -- does anyone have a DIAGRAM /
SCHEMATIC ??
> Do it like this:
> sure)
> <SNIP!>
555
> > Timer
between 4
> > and
> > > > 6 feet away.
tie up the processor with this task, especially since its a BS1. Since this
is for sumo, I'm not really interested in determining range, just where the
opponent is.
> If you are using Stamp, maximum IR range is acheived by using a detection
power.
because
designing and building the circuit for me, I have another task you can
perform... ()()
One reason we ask these questions is so we don't have to reinvent the
wheel -- the datasheet is helpful, but there may be other non-standard ways
of making it work better, not to mention some caveats as to resistor and
capacitor values.
As for Radio Shack, I don't believe they still carry the 555 book, and the
555 cookbook is long out of print.
And just remember, some of us are not as smart as you think you are...
> Yes, I do have the schematics to do this (called a "data sheet").
> me.
> sense someday.
> SCHEMATIC ??
> > Do it like this:
> > sure)
> > <SNIP!>
> 555
> > > Timer
> between 4
> > > and
> > > > > 6 feet away.
Besides, your making me feel guilty because I'm the one who asked
this question.
Hey Rodent, check out this link. I don't know if it will help you.
But I think it is what I'm looking for.
http://www.ee.washington.edu/conselec/Sp96/projects/mitchrob/final/fin
al.htm
> Keeping your suggestions to yourself sounds good to me. While you're
can
> perform... ()()
the
standard ways
resistor and
> capacitor values.
and the
are...
it
know
to
the
trust
> > me.
versitale
> > sense someday.
> > SCHEMATIC ??
> > > Do it like this:
not
> > > sure)
> > > <SNIP!>
and
> > 555
> > > > Timer
> > between 4
> > > > and
> > > > > > 6 feet away.
>capacitor values.
Did you look in your Stamp manual? Try page 119 in the Ver 1.8 manual. I
bet it's still in the Ver 1.9 manual too. This circuit also includes the
ability to modulate the output of the 555 as a bonus.
Jim H
+5, ground and one pin to the Stamp. They are anywhere from $1.35 to $2.60
in price from several sources including Al Williams and Parallax. If you
want to use a Stamp to drive the LED you can refer to the Parallax weekend
deal they had a while back:
http://www.parallaxinc.com/downloads/Resources/Weekend%20Special%20-%20IR%20
LED%20&%2040%20kHz%20Detector.PDF
If the link doesn't work, go to the main Parallax site and search for
"weekend."
> al.htm
I wouldn't - and won't - help any rude idiot...
Certain members here are now on my "idiot" auto-delete list.
You know who you are [noparse];)[/noparse]
Ken
with enough thrust, pigs fly just fine.
you're
task you can
> perform... ()()
reinvent the
standard
> ways
resistor and
> capacitor values.
book, and
> the
you are...
sheet").
design it
You know
enough.
details about
time to
purchase the
from
easy, trust
> > me.
if you
your
versitale
really make
> > sense someday.
DIAGRAM /
> > SCHEMATIC ??
> > > Do it like this:
36Khz, not
> > > sure)
> > > <SNIP!>
Detector and
> > 555
> > > > Timer
that is
> > between 4
> > > > and
> > > > > > 6 feet away.
> from the same email address that you subscribed with. Text
in the
particular command or in another section?
Is this the deal that shows you how to tune the frequency of the oscillator
with a Stamp? I think I ran across it in one of the Stamps In Class
documents a while back.
I think I might have a schematic of the 555 in an ancient Texas Instruments
manual. If I remember correctly, it shows you how to add external components
to adjust the frequency. If you need it let me know. If I can find it I
could scan the page and e-mail it to you.
Sid Weaver
Newzed@a...
Looks like its in the Stamp 1 App Notes v1.9 on page 119.
is a good site on the 555 chip. It'll help you pick resistor and
capacitor values for whatever frequency you're looking for, and it has
schematics on there..
Rory
> Does anyone have a diagram/schematic of the IR Detector and 555 Timer circuit?
fifty dollar microcontrollers do things that could be done with 5
bucks worth of parts.
Now before things get more out of hand, my reply to your query was
intended to be helpful.
I THINK WE GRASP THE CONCEPT... That's your way of thanking me for
taking the time to address your query.
When I needed a hand out here I never asked anyone to write the code
for me. I did my own research.
And as for my performing some unmentionable task for you, I would be
delighted. Make sure to give me a call next time you're around New
England. Me and you, we'll get together for some coffee...
What a dope
can
> perform... ()()
the
standard ways
resistor and
> capacitor values.
and the
are...
it
know
to
the
trust
> > me.
versitale
> > sense someday.
> > SCHEMATIC ??
> > > Do it like this:
not
> > > sure)
> > > <SNIP!>
and
> > 555
> > > > Timer
> > between 4
> > > > and
> > > > > > 6 feet away.
down and put the pencil to it and figure out what the component values are.
Funny how you don't think you'll ever need your old books -- at one time I
had a 555 cookbook as well as the Radio Shack deal, but they either got
tossed or piled into the back of the closet a long time ago.
Looks like the schematic the other guy found may work if you use their
detector circuit also, but it won't work as is with a 38 khz unit.
Instruments
components
Has anyone tried the 50% duty cycle circuit in the National application
notes?
> http://www.andy-clarkson.co.uk/555/
Please don't let that rude infant (probably should change his
name to "rodent ****" ) deter you from further participation in
this list. I appreciate the help you offer here, as I'm sure
99% of the members do...
Ken Ambrose
---- On Fri, 29 Jun 2001, iceninevt@y...
(iceninevt@y...) wrote:
> I just sit back and smile while you guys figure out ways of
making
with 5
query was
me for
the code
would be
around New
> What a dope
While you're
task you
> can
> > perform... ()()
reinvent
> the
non-
> standard ways
> resistor and
> > capacitor values.
555 book,
> and the
you
> are...
sheet").
as design
> it
challenging. You
> know
enough.
details about
the time
> to
purchase
> the
datasheet from
easy,
> trust
> > > me.
but, if you
your
> versitale
really make
> > > sense someday.
DIAGRAM /
> > > SCHEMATIC ??
> > > > Do it like this:
36Khz,
> not
> > > > sure)
> > > > <SNIP!>
Detector
> and
> > > 555
> > > > > Timer
that is
> > > between 4
> > > > > and
> > > > > > > 6 feet away.
in the
component values for 555 based oscillator circuits quite painless at:
http://www.csmicrosystems.com/timerdesigner/index.html
If you have the equipment to program a small 8-pin PIC12C508, I can provide
you with the assembly (or .hex) code to build your own 38KHz or 40KHz
oscillators.
Very stable, and quite inexpensive.
Using the 8-pin PIC for a 38kHz or 40kHz oscillator only requires 2 components.
The PIC, and ceramic oscillator. 555 timer circuits have a tendency to drift.
The
PIC oscillators are solid.
Here's a couple projects that show how these are used with IR LED drive
circuits:
http://www.rentron.com/Infrared_Remote_Control.htm
http://www.rentron.com/Infrared_Communication.htm
Bruce
webmaster@r...
Sent: Friday, June 29, 2001 12:48 PM
Subject: Re: [noparse][[/noparse]basicstamps] Re: IR/555 Timer Question????
> Gracias Sid. I've got the spec sheets and stuff already, just need to sit
> Instruments
> components
> from the same email address that you subscribed with. Text in the Subject and
No problem, Dave
Went looking for the book just in case. It was an old Motorola manual, not
TI, published in 1979. Indentally, dod you know there is a 556 chip which
has two 555's on it?
Best Regards
Sid
solution sounds interesting. I'm not hip on the PIC situation -- any
suggestions on beginner books?
> CS MicroSystems has a really nice (free) software application that makes
finding
provide
oscillators.
components.
drift. The
circuits:
use a 556 for this application as I want to have a central detector and fire
a left and right LED to determine direction.
I think we all had those books at one time or another. Last time I was doing
electronic stuff we had a whole room full of reference books, including
stuff on vacuum tubes.
not
Sent: Friday, June 29, 2001 1:45 PM
> Cool -- thanks Bruce. Got a 555 circuit working right now, but the PIC
David Bensons Easy PIC'n is one of my favorites, and definitely
a great starting point for someone new to the PIC.
http://www.rentron.com/books.htm#book3
Bruce
webmaster@r...
not processing orders.
Just to cover the bases, I've ordered from Rentron too. Excellent
service with LOTS of PIC information too.
Kevin (not affiliated with either site, just a satisfied customer)
"Webmaster@r..." wrote:
> From: "Rodent" <daweasel@s...>
> Regards,
> Bruce
> webmaster@r...
data book, but the pages are too yellow to make good copies ;-)
At 03:39 PM 6/29/2001 -0400, you wrote:
>For daweasel
>No problem, Dave
>Best Regards
>Sid
_________________________________
Mike Walsh
walsh@i...
Boy, you must be almost as old as I am.
Sid
1971 started as an engineering tech as I finished my degree. Been here
since. One of these days I'll leave and get a real job.
I was reminded about not being able to use calculators in college. I had an
AC theory class final and my boss offered to loan me his HP35 (first
scientific / RPN calculator) for the exam. WOW! I was going to skate
through this one! No, my professor nailed me before the exam started and
told me to pull out my Log-Log K&E. Gee, I miss those days .............. not!
At 05:46 PM 6/29/2001 -0400, you wrote:
>For walsh@caltech
>Sid
Mike Walsh
walsh@i...
>Quick search of 2.0c Stamp manual does not show it. Is it listed with a
It's Application Note #11 titled "Infrared Communications" in my ver 1.8
Manual.
Also App Note #12, "Sonar Range Finding."
Jim H
That thing must be fifty years old. There was a day when I used it
constantly as a capacitor design engineer. Ah me, such fond memories.
Have a nice weekend.
Sid
